Big 3 Wire Upgrade question
Discussion in '1st Gen. Tacomas (1995-2004)' started by jammer, Apr 26, 2017.
  1. Apr 26, 2017 at 9:03 AM
    jammer
    jammer [OP] 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    I want to upgrade the wiring to the alternator and starter on my '03 3.4 Tacoma. There is or was a member named "Bama" that sold the Stage 1 Wiring Upgrade kit. I emailed him a couple of months ago, but never received a response so he may not be selling them anymore.
    Does anyone know the length needed for the following replacements:
    1. Starter to Battery
    2. Alternator to Battery
    Probably going to be using 4 gauge welding cable.
    Great write-ups on this.
    https://www.tacomaworld.com/threads/1st-gen-electrical-system-upgrade.311091/
  2. Apr 26, 2017 at 9:51 AM
    digitalferg
    digitalferg Well-Known Member
    Southern Utah
    2006 1G Tundra DC TRD 4x4
    boostedka and jammer[OP] like this.
  3. Apr 26, 2017 at 9:58 AM
    jammer
    Ben
    Bentonville, AR
    Thank you for the link. Exactly what I'm looking for.
  4. Apr 26, 2017 at 1:13 PM
    DELPIERO10
    DELPIERO10 Active Member
    JOAQUIN
    2003 RED TACOMA TRD OFFROAD
    Hi my friend, I am doing some improvements to my 2003 Taco, and Im looking for some goodlooking and functional cables and terminal, some like this what battery?
  5. Apr 26, 2017 at 2:16 PM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
  6. Apr 26, 2017 at 3:24 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Definitely go with the welding cable. It's easier to route and far more pliable than the normal 4G wire.
  7. Apr 26, 2017 at 3:25 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I always use 1/0 welding cable for the Positive and Negative
    #4 for the B terminal to fuse block
    Ritchie likes this.
  8. Apr 27, 2017 at 10:06 PM
    IceRaven06
    IceRaven06 New Member
    I work in car audio myself and done enough of these.
    there's 2 types of wire out there and what you're looking for is OFC (Oxygen Free Copper) or CCA (Copper Clad Aluminum). OFC will have the better current draw results and will stay cooler than CCA.
    4 ga wire is good for a starter if you want to beef up some current issues
    0 ga wire is the best
    As for setup goes, use which you think will be better for furture projects or just go 0 ga. There is another part of this buddy of mine found is that we try to do a big 4 upgrade. The extra wire is grounding the alternator to the battery. The guy says that it will produce better results than just a big 3 upgrades due to the alternator getting grounded at the battery and not through the engine block.
    boostedka likes this.
  9. Apr 27, 2017 at 10:16 PM
    Croth51
    Croth51 Croth Metal Works
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    16 Method NV,33 Bfg AT KO2, 14 in Fox shocks hydraulic bumps swayaway coilovers 50 in LED Lightbar A pillar Ditch lights ,Custom Skidplate,4 Hella Hid lights,Custom grille,7 in Pioneer touch screen Head unit, 12 in CT sounds Meso CT 1400.1 amp, kicker doorspeaker, 500 watt doorspeaker amp, white LED rocklights, LED pod Dustlight,
    I run 0 gauge OFC personally. And have 2 full-size AGM under the hood....
    Toynado likes this.
  10. Apr 28, 2017 at 1:12 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    If your going to ground the Alternator to the battery may as well do the starter as well .
    make a ground bus coming off the negative battery terminal
    I use the 1/0 because I get short pieces for free so the only cost is the lugs
