Big drop in gas mileage 2.7L 2TR-FE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by popcornsetting, Mar 17, 2023.
  1. Mar 17, 2023 at 8:29 AM
    popcornsetting
    popcornsetting [OP] Member
    2009 Access Cab 4WD 2.7L 5-speed manual trans
    First time posting here! I would love some advice from folks familiar with the 2TR-FE.
    I've got a 2009 with 175k on it, recently I've noticed a considerable drop in gas mileage, from around 25mpg highway to 22-23mpg highway. It wasn't a gradual decline, I habitually reset my trip odometer after every fillup and noticed a sudden drop.
    Have cleaned the MAF and am planning to replace the spark plugs (~80k miles on the set) and spray out the throttle body next week. Also going to replace the two smaller vac lines on the resonator which have small cracks at the connection points and the PCV which has probably almost 100k on it.
    My question is, would any of that basic maintenance help fix such a large drop in mpg? Seems like it's running rich based on exhaust smell, am really hoping the spark change plus throttle body maintenance straightens it out but figured ya'll might have a better idea what could be going on. The check engine light isn't on, which makes me think it's probably not something like an O2 sensor or the secondary air injection pump, would it be worth seeing if it's spitting codes without the light? Thanks!
  2. Mar 17, 2023 at 9:59 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    Lots of things can affect mpgs but sounds like you are on the right track doing maintenance. Everyone loves to jump to extreme conclusions, good to see someone doing the basics first. Vac lines 100% fix if they have cracks/leaks, and yeah it's time for a PCV and plugs. From my own experience I did PCV & plugs around the same mileage and some of my best tanks were shortly after that so it is possible they are contributing factors.
    Without knowing where you live, it's not unusual to lose a couple mpgs just due to colder winter temperatures, winter blend gasoline, and cold air making your tire pressure drop just a couple psi. I track every single fill-up in my own spreadsheet (yes I am an unabashed data nutjob) and no matter what else I change, winter temperatures are the #1 cause for mpg drop. Driving like a maniac is #2, tire pressure is #3 in my opinion.
    Do your maintenance and keep watching the mileage but I wouldn't sweat it too much. Wait until spring/summer and see how things change over time. Good luck and welcome to Tacoma World!
  3. Mar 17, 2023 at 11:34 AM
    winkeldc
    winkeldc Well-Known Member
    2014 Reg Cab 4x4
    Lots of things can cause that as mentioned. Could be not engine related as well; frozen or sticking calipers, bad wheel bearings, basically anything that going bad takes more power to keep the truck moving. I routinely lose that on winter blend fuel though. Are you using oil? Coolant?
  4. Mar 17, 2023 at 11:53 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    1-2 mpg is nowhere near a big drop. My 4.0 fuel economy always drops a bit here and there sometimes. Could be a bad batch of gas, weather etc. Many small variables can drop a few MPGs. Even slightly low tire pressure could lose you a few MPGs
    I would log some more miles before freaking out.
    Black97v6MT likes this.
  5. Mar 17, 2023 at 12:05 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  6. Mar 17, 2023 at 1:11 PM
    popcornsetting
    It's been about 5k miles since I noticed it drop has been consistently lower the whole time so figured it might mean something I should look into.. thanks for the advice! Probably mostly just winter blend gas like ya'll been saying above but haven't noticed anything that significant in prior winters.
  7. Mar 17, 2023 at 1:13 PM
    popcornsetting
    Nah not losing coolant or oil, no visible oil leaks
  8. Mar 17, 2023 at 1:24 PM
    robson1015
    robson1015 Well-Known Member
    Bob
    New Concord, Ohio
    2009 base tacoma- regular cab- 5 speed
    25mpg to 23 mpg - could be as simple as bad gasoline.
    Try a different brand of fuel
  9. Mar 17, 2023 at 6:51 PM
    TacomaMaine86
    TacomaMaine86 Member
    Maine
    2006 Red SR5
    Did anyone mention the air filter? Depending on driving conditions and dirt in the filter, it can greatly affect mileage.
    Black97v6MT and Steves104x4 like this.
  10. Mar 17, 2023 at 7:36 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Clean the maf
    jem122594 likes this.
  11. Mar 17, 2023 at 7:51 PM
    TacomaMaine86
    Maine
    2006 Red SR5
    Thanks, didn't catch the abbreviation reading first time through.
  12. Feb 17, 2025 at 3:04 PM
    jem122594
    jem122594 Well-Known Member
    Joseph
    2007 Tacoma 2.7 auto 2wd
    I know this is a old thread, but I am curious if you ever figured out your issue or got your fuel mileage back I have a 2007 with the 2.7 motor and seems like fuel mileage is terrible compared to my diesel f250 I bought this Toyota to save on fuel I’m only getting 17mpg and I’m easy on it. New cat converter assembly as I had a P0420 code and that fixed it. I have no other codes. I will say I bought this truck with a known blowed head gasket and swapped out a low mile motor in it “88,000thousand” but like I said not the mileage I expected and I’m on flatland on the coast
  13. Feb 17, 2025 at 6:49 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Broken parking brake cable, maybe.
