Big enough frame hole for toyota to recall?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ticaz, Jun 28, 2022.
  1. Jul 10, 2022 at 2:42 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    If you're planning on keeping this truck for a while and you can afford it, now would be a good time to take a close look at anything else on it that might need to be repaired/replaced, including preventative maintenance items. Most dealers are pretty cool about replacing parts at no additional labor cost or at a reduced labor hours since they're more readily accessible and easier to work on with the truck stripped down.
  2. Jul 10, 2022 at 7:33 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    SAHWEEEETTTTTTT!!!!
    I can speak from my experience last summer. Automatically included is rear leaf springs, LCAs, metal brake lines. I paid for new shocks and springs, labour was zero for those items. I cannot imagine they wouldn't do other things such as you mentioned for parts or parts plus nominal labour, as you mentioned in that example there's a lot less work to get to the item needing replacing. I know my coolant was replaced as well, engine oil and trans fluid not. Not sure re the differential(s) as I didn't ask, but not a bad idea to query.
    I forget where I saw it, but IIRC the 10mm hole is what's needed to get a new frame. If it's 15mm or under they don't take it and give you the loaner on the spot.
    This. Mine only had about 117K on it so I wasn't needing anything that it would have paid to do other than the suspension work I mentioned above.
    PzTank likes this.
  3. Jul 14, 2022 at 1:11 PM
    MadRussian
    MadRussian Well-Known Member
    Metrowest MA
    2010 TRD OR AC
    In my case anything they took off they replaced at no labor cost. I got some lightly used shocks and they no problem putting them on. Also changed the water pump and a few other things at very low labor costs because of easy access. But a lot of the original rusty parts got bolted back on - skid plates and rear hitch assembly that i can recall.
    Definitely look into things you might want to replace in update.
  4. Jul 14, 2022 at 2:34 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    My frame was done at Towne Toyota in NJ. They wouldn’t replace a thing without charging me full labor rate.
  5. Jul 14, 2022 at 2:39 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Interesting during the start of the extended warranty I had several Trucks that had been repaired that were bought back with no problems.
    Slightly more then tool marks.
    As all dealers are independent so will avoid any frame swaps doing anything to wiggle out.
