BIG Failure, Not sure of cause!
Discussion in 'Suspension' started by Monty, Feb 15, 2009.
  1. Feb 15, 2009 at 4:19 PM
    Monty
    Monty [OP] New Member
    North Carolina
    07 Dbl Cab 4WD
    3" Toytec spacers + added leaf.
    HELP PLEASE!!! I installed a Toytec 3" spacer lift on my '07 after 4k miles. Also added a leaf on each side. I noticed a couple of years back a banging sound when I turned the wheel to either extreme. Never thought much of it. 2 years later I am having a grinding sound in the front end. Dealer changed hub bearing to no avail. Sound shows up when the truck (the suspension is cold). 1,000 miles after the hub bearing the sound is constant. I went under the truck AND>>>>####**** I PULLED ON THE HALF SHAFTS AND BOTH ARE LOOSE ON THE DIFF END. The driver side shaft wiggles and comes out of the diff about a 1/2". Passanger side is less. WHAT'S GOING ON??? My thought is that the steering went to an extreme and didn't hit the stop pad, and in turn pulled on the shaft. BUT WHY did this happen? Only my guess. BTW, the 4WD is difficult to go back into 2WD now. HELP PLEASE!!!!!!!!
  2. Feb 15, 2009 at 4:24 PM
    Brunes
    Brunes abides.
    Rotorhead
    I'm going to guess you did not put new Upper Control Arms or a differential drop on when you installed the lift??
    The drive line angles can be affected by even just 3 inches of lift in these trucks...and if you stressed the diff side enuf- you may have fried it.
  3. Feb 15, 2009 at 4:27 PM
    Monty
    North Carolina
    07 Dbl Cab 4WD
    I put the diff drop in. No new upper control arms. Toytec says absolutely nothing about needing to do anything, but the driff drop is recommended only to address the U joint wear.
  4. Feb 15, 2009 at 5:58 PM
    PPD934
    PPD934 Well-Known Member
    Western Kentucky
    06 silver double TRD
    Running bars, tinted window (, TSB mod ,885 coils, OME shocks up front, AAl and procomp 9000 out back, partially debadged/black out the others, weathertech floor mats, grillcraft grill, TRD skid plate
    I have a noise on in my front end also when its cold, it last about 2 blocks and goes away. sounds more like a rubbing noise than a grinding noise. not real extreme by any means. I have the toytec three and a diff drop as well. No other problems with the truck going in and out of 4 wheel drive.
  5. Feb 15, 2009 at 6:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Sounds like the diff bearings. Have the dealer check them.
    Ooops...I forgot........
  6. Feb 15, 2009 at 6:43 PM
    Monty
    North Carolina
    07 Dbl Cab 4WD
    Seems to b the same as mine but mine might be further along. You get to look forward to my more extreme issues. I'm wondering if Toytec screwed up in any way. I spoke to them, they played dumb. Did u do any research?
