Big Mistake, Need Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZachPrerunner, Feb 5, 2016.
  1. Feb 5, 2016 at 1:05 PM
    ZachPrerunner
    ZachPrerunner [OP] Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Okay so I ended up chewing the bolt up on the catback. Where can I find one of these bolts/part number? I think it messed up the threads on the y-pipe too. How can I fix this?
  2. Feb 5, 2016 at 1:09 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You need to get a tap to correct the threads for the hole that corresponds to your mauled bolt. The bolt should be available from a dealer.
  3. Feb 5, 2016 at 1:09 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    You might be able to chase the threads on the female end with a tap, but that bolt is smoked. Better call the dealer for the exact replacement, but you can probably get a temporary fix at the hardware store. It's going to be metric.
  4. Feb 5, 2016 at 1:50 PM
    ZachPrerunner
    Southeast TN
    Would a muffler shop be able to rig me up with something or should I take it to the dealer?
  5. Feb 5, 2016 at 3:07 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    God Damn!
    You didn't feel that chewing up shit?
    Always make sure the threads are clean and the threads are lined up properly ( this is esp true with exhaust systems ) before tightening. If it feels tight when screwing it in back it out and start over.
    Get a new bolt assembly from the dealer or online.
    I think that that yoke flange will need a thread insert or welded up and drilled and tapped. A tap may clean it up some, but it looks like toast to me and will be too weak for a proper torque even if it is cleaned up.
    ZachPrerunner[OP] likes this.
  6. Feb 5, 2016 at 3:10 PM
    Jaab
    Jaab Well-Known Member
    Captain Wiggles
    SW Ontario
    2005 Double cab short box 4x4 TRD Taco....
    OME 887, Dakars ARB bull Bar, M8000 winch,ABS mod, Locker mod, fog lights anytime mod, COMFY BMW sport seats, tweaked Airbag emulator,
    My mufflers hop is quick to fix that stuff cheap. Try one....
    billybob50 likes this.
  7. Feb 5, 2016 at 4:07 PM
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
  8. Feb 5, 2016 at 4:24 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    pull spring off that bolt. Go to the hardware store, get a bolt n nut thats the same length + a lil extra for the thickness of a new nut. Drill out flange holes. Use new bolt and nut with original spring, Tighten down so the spring is the same length as the non effed one.
    Simple, cheap, easy effective.
  9. Feb 5, 2016 at 6:26 PM
    billybob50
    Bob
    Retap the hole (clean it up) and get a longer heat treated bolt long enough to add a nut and lock washer on the back side. Flat washer on the head then torque it down with the spring. Easy peasy!
  10. Feb 5, 2016 at 6:29 PM
    Joe D
    Joe D .
    Damn Sak, time to cut back on the protein & supplements.:boink:
  11. Feb 5, 2016 at 6:33 PM
    AdamM
    AdamM Semi-pro aardvark wrangler
    Adam
    Edmonton, AB
    14 DCSB base 6MT 4x4
    After you run a tap through the flange, you might be able to get away with cutting down the bolt to just above where the thread is fucked up. Put a bevel on the end of the bolt and it should work, even if only temporarily.
  12. Feb 5, 2016 at 6:34 PM
    billybob50
    Bob
    I'm guessing, the last person who put that bolt in cross threaded it with an air impact gun!
    T4RFTMFW likes this.
  13. Feb 5, 2016 at 7:09 PM
    AustinPizzini
    AustinPizzini Well-Known Member
    Austin
    Huntersville NC
    006 ACLB SR5 ON KINGS
    285/75/16 Micky Thompson Baja MTZ P3, king 2.5 Resi coilovers, spiderTrax, cbi hood brackets, caliraised led pods, caliraised led bar in lower valance, UWS tool box, blacked out emblems, 18% tint, lots of audio stuffs
    I did the same thing. I just got a new bolt and nut. Easy as can be
  14. Feb 5, 2016 at 7:12 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    You ever had one of those bastards that never wants to come out?
    That's what 1" guns and welder are made for :welder:
  15. Feb 5, 2016 at 7:13 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Have you tried just using duct tape to keep your exhaust pipe together?
    Jaab likes this.
  16. Feb 5, 2016 at 7:13 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    Hey OP I have a few those bolts laying in my tool box if you need them. It'll take a few days by snail mail though.
  17. Feb 6, 2016 at 6:45 AM
    ZachPrerunner
    Southeast TN
    Actually, it was by hand with a 1/2 ratchet :anonymous:
  18. Feb 6, 2016 at 6:45 AM
    ZachPrerunner
    Southeast TN
    DM coming your way
  19. Feb 8, 2016 at 10:05 AM
    tgear.shead
    tgear.shead Well-Known Member
    I suggest a slight difference from what others have recommended;
    If the threads where the bolt drive into are NOT salvageable, then you want to get a replacement bolt that is long enough to fit TWO nuts on the end. The reason is that you are tightening it up against the spring, which means that there will be no positive lock when you "tighten" it. If you fit two nuts on it, then you can lock them together on the bolt.
  20. Feb 8, 2016 at 10:18 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    ding ding ding, we have a winner!
    you can also use a lock nut, but it has to be a deformed thread lock nut, since a nylon lock nut will just melt over time.
