Big news regarding mud guards!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thinkingman, Oct 12, 2011.
  1. Oct 13, 2011 at 6:02 AM
    Jeff3004x4
    Jeff3004x4 Well-Known Member
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    http://www.huskyliners.com Look them up for a Taco and check out the pics they do not appear to bulge out for mounting purposes. I may be interested in a set of fronts.
  2. Oct 13, 2011 at 6:41 AM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    They need to be flexible. These look like theyll break like stockers.
  3. Oct 13, 2011 at 8:48 AM
    thinkingman
    thinkingman [OP] Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    From HuskyLiner website:
    Manufactured from a highly durable impact resistant thermoplastic, our mud flaps will endure extreme weather conditions for the life of your vehicle.
    You don't hear Toyota making the same claim...I don't think I've seen cheaper OEM parts in my life.
    They appear to be shorter...I will get some specs
  4. Oct 13, 2011 at 8:50 AM
    thinkingman
    redmond WA
    MSRP is $39.99 per pair, according to their website.
  5. Oct 13, 2011 at 9:02 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    That's a lot better price than Toyota would charge for the OEM ones! Granted these are made of plastic too but for that price you can trim the hell out of them! Nice find and thanks for posting.
  6. Oct 13, 2011 at 10:18 AM
    thinkingman
    redmond WA
    Specs from the design engineer....
    The front mud guards are 11” wide and extend 9” below the fender. The rear mud guards are 11.25” wide and extend 9.25” below the fender. The mud guard has a slight taper and the width dimension is across the mud guard at approximately the area where the extension below the fender begins.
    I shot that out before adding the mounting information. We do use the factory mounting locations but use screws instead of push fasteners. There is one location where we feel one of the factory push fasteners is not needed--so it is not used. The material is flexible in that it can be bent without breaking--but it is rigid enough it will not “flap” while driving down the road. Flexibility is hard to describe in a manner that is commonly interchangeable from person-to-person.
  7. Oct 13, 2011 at 10:21 AM
    georgeandkanoa
    georgeandkanoa the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    are you a flyers fan after last night
  8. Oct 13, 2011 at 10:30 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Lost a bet with Boyd
  9. Oct 13, 2011 at 11:07 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
  10. Oct 13, 2011 at 11:40 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Will be purchasing a set of fronts next paycheck...
  11. Nov 15, 2011 at 8:30 PM
    stockplus
    stockplus Well-Known Member
    L.J.
    Way way north of Redding
    06 4x4 SR5 Access Cab
    TC, ToyTec, Boztec, All-Pro, ATO
    The Husky mud flaps arrived on Monday. They were delayed slightly by a problem with the mold but are apparently in full production at this time.
    The fronts are approximately 3-4" shorter than the stockers, slightly more contoured (with the tire radius) than OEM, cupped in shape, etc. It's pretty apparent in the pics. They are made of a hard plastic *similar* to OEM. Not being a material sciences expert, I couldn't tell you for certain what kind of thermoplastic it is exactly. They are also pretty rigid, close to stock if not moreso. They are not the holy grail flexible rubber flaps people were hoping for, but the price is pretty good and the fit is also quite good as well. They were relatively easy to install. The install package includes all the hardware necessary, decent instructions, and 3M clear film (which I didn't use). Where the guard meets the fender, OEM-style overlap occurs and it obscured any wear that had happened from my previous mud guard installs.
    I haven't installed the rears yet, but I held them up for comparison and they look to be about the same length as the old ones -- i.e., they are not significantly shorter compared with OEM like the fronts are.
    I can tell you that the backsides of the front flaps are just slightly slimmer in profile than stock. With the OEM flaps I had rubbing at full lock. There is no rubbing with these. YMMV.
    Hope this helps! :D
  12. Nov 15, 2011 at 8:35 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    x2.. im pretty sure the only reason my super long front mud flaps havent snapped is because they bend forward and back
  13. Nov 15, 2011 at 8:41 PM
    tacomtn
    tacomtn Well-Known Member
    TRD OR,OME,Deaver AAL
    Yeah, let's get a Group Buy going....
  14. Nov 15, 2011 at 9:24 PM
    OZ-T
    Peter North
    British Columbia
    I like how the inner part of the front flap ( furthest into the fender ) goes back away from the tire rather than bulge towards the tire like the OEM ones do .
  15. Nov 16, 2011 at 12:10 AM
    #35
    tacomtn
    Yo, Thinkingman.
    I emailed Husky asking if they'd like to do a Group Buy. I'm thinking (Man) if you emailed them, since you're the originator of the idea, they might be more likely to do it.
  16. Nov 16, 2011 at 12:18 AM
    #36
    acdronin
    acdronin Well-Known Member
    Damn those dont look half bad, and hell, at 40 bucks a pair, i'm not gonna sweat tearin em up like the OEMs
  17. Nov 16, 2011 at 12:28 AM
    #37
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    But they dont have sweet 4x4 logos!!! Dude... Thats killing it for me. haha nah but id be down for a group buy, Can you do front and rears?
  18. Nov 16, 2011 at 12:34 AM
    #38
    stockplus
    L.J.
    Right. These are my sentiments too. If you want/need mud flaps, then this is definitely an option to consider.
  19. Nov 16, 2011 at 12:47 AM
    #39
    gtdad66
    gtdad66 Well-Known Member
    Jesse
    West Ga
    2017 Tacoma Limited
    Front window tint, tool box, bed mat
    I wish they were much shorter for ground clearance!!!!
  20. Nov 16, 2011 at 8:18 AM
    #40
    Tdye82
    Tdye82 Well-Known Member
    Im interested. Tired of listening to my OEM flaps rubbing...
