Big news regarding mud guards!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thinkingman, Oct 12, 2011.
  1. Nov 16, 2011 at 11:13 AM
    #41
    MurfsTacoma
    MurfsTacoma Active Member
    Jordan
    Riverside
    05 Double Cab 4x4 TRD
    Grill, PushBar, BHLM, K&N, Delta 50 Flowmaster, A.R.E cover, 5100's
    My front driver is barely hanging on. Let's get a group buy goin. I know a couple of friends who would be in also. Way better alternative than paying hundreds for the OEMS.
  2. Nov 16, 2011 at 1:25 PM
    #42
    Fargin Bastage
    Fargin Bastage Member
    Fargin
    PDX
    2011 Tacoma 4x4
    Those look beefy, and pretty cool without the white 4x4. I'd be in for a set if there is a group buy.
  3. Nov 16, 2011 at 1:55 PM
    #43
    matts11
    matts11 Well-Known Member
    TN
    Those look great! Any thoughts on whether or not you could have reused the oem hardware? Any new holes to drill? And you were implying they are big enough to cover any wear marks left from the oem flaps where they rub on the fender flare?
  4. Nov 16, 2011 at 2:02 PM
    #44
    thinkingman
    thinkingman [OP] Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    I installed mine in, literally 5 minutes.
    You do reuse a couple of the factory screws and the hardware provided is good quality.
    No new holes!
    They do cover the same portion of the fender as the OE's and HuskyLiner provideds clear 3M tape to mask the painted sections if you want.
    These are a great compromise re length and much better quality material.
  5. Nov 16, 2011 at 2:08 PM
    #45
    Texio
    Texio Well-Known Member
    Austin, TX
    11 4WD DBCab SB
  6. Nov 16, 2011 at 2:08 PM
    #46
    stockplus
    stockplus Well-Known Member
    L.J.
    Way way north of Redding
    06 4x4 SR5 Access Cab
    TC, ToyTec, Boztec, All-Pro, ATO
    Good questions.
    No drilling is required. The flaps, both front and rear, re-use the existing OEM screws. One factory hole is not used on each flap (it is covered by the new flap, and there is no provision to use a fastener there). They include threaded clips and washered black oxide screws, two clips and two screws per each flap. One clip actually clips to the fender flare over an existing hole, and the other you have to prop up with your fingers behind another hole and use it like a nut.
    You could conceivably use the push-in fasteners with the Husky flaps, but you would need to enlarge the holes on them slightly to get it to work. The clip system may sound sort of hokey, but it works and I feel that it is at least as strong if not more strong than OEM.
    The fronts do a pretty good job of concealing the wear mark caused by the factory flaps. The rears show a bit towards the top of the flap, but it is not that bad.
    Hope that helps!
    :D
  7. Nov 16, 2011 at 2:10 PM
    #47
    Texio
    Austin, TX
    11 4WD DBCab SB
    Awesome, thanks for answering my unspoken questions!
  8. Nov 16, 2011 at 2:46 PM
    #48
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Looks good ! I tore off a front mud guard while reversing onto a curb, guess I'll just replace mine with a set of these.
  9. Nov 16, 2011 at 2:57 PM
    #49
    stockplus
    L.J.
  10. Nov 16, 2011 at 4:14 PM
    #50
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    I bet these won't wear on the flares like the OEM since there is no movement/rubbing
  11. Nov 16, 2011 at 4:38 PM
    #51
    thinkingman
    redmond WA
    Thanks to StockPlus for the pics and description....much better job than I'm doing.
    I am in contact with them and I started a poll to gauge interest before I setup group buy.
    Vote in the poll and I'll get things going.
  12. Nov 16, 2011 at 4:58 PM
    #52
    stockplus
    L.J.
    I am happy to help! We would not have these flaps without you. :cool: Thanks again!
  13. Nov 16, 2011 at 5:03 PM
    #53
    thinkingman
    redmond WA
    AWWWWWW......:cheers:
    So go vote the poll so I know how much support there is for this thing....
  14. Nov 16, 2011 at 5:06 PM
    #54
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Hmmm... I wonder if these will work with 285's?
  15. Nov 16, 2011 at 5:09 PM
    #55
    HarryTaco
    HarryTaco Well-Known Member
    Pacific NW
    2016 TRD OR DCSB 4x4 V6 MGM
    Bed Mat, Bak Revolver Tonneau,
    Yeah, am I going to lose my 4x4 functionality with these flaps? :p
  16. Nov 16, 2011 at 5:49 PM
    #56
    YotaMark
    YotaMark Well-Known Member
    Mark
    Mentor, Ohio
    08 Tacoma 4 cyl 5 speed 4X4
    Rear Gate security Mod (although I seldom take my eyes off it) "Harsh Ride" Shocks and Springs TSB performed by "Me" New Cooper Discoverer AT3s 265/75R16s (fit well) Front "Tacoma Mike" light mod! Rugged Ridge floor mats. Bought another set of D rings and installed them in my wheel well. Perfect! Just hit the big 6000 Miles 12/19/11, Installed an alarm system to go with my factory power door locks 1/21/12
    no big white 4X4
  17. Nov 17, 2011 at 5:43 AM
    #57
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    Are the rears also shorter than the OEM ones like the fronts are?
  18. Nov 17, 2011 at 7:10 AM
    #58
    Texio
    Austin, TX
    11 4WD DBCab SB
    Here's your answer. Hope this helps!
  19. Nov 17, 2011 at 7:25 AM
    #59
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    ^^^ My bad seen that post but skipped over the intro and went straight to the pics. :eek:
  20. Nov 17, 2011 at 7:44 AM
    #60
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Are they flexible? That has always been my biggest complaint on the stock ones is that they are not flexible at all and should not be on a truck if they can't flex under stress.
