Big oops, need advice...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Imageoguy, Aug 1, 2025 at 3:51 PM.
  1. Aug 3, 2025 at 7:20 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    That or his torque wrench had high internal friction, and doesn't click if he turned it too slowly.
  2. Aug 3, 2025 at 8:05 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Wet vs dry doesn't matter, torque wrench settings don't matter. Its about feel. You need to learn when to stop. He learned the hard way
    DES2009, GilbertOz and JohnDoeFasho like this.
  3. Aug 3, 2025 at 8:13 AM
    eherlihy
    eherlihy 2009 Access Cab TRD Off Road
    Florida or Massachusetts
    2009 TRD Offroad Access Cab in Silver Streak Mica
    If it were my problem, and I am glad that it is not, I would try to dig out the area where the crack is with a Dremel (create a V shaped groove), clean it with brake cleaner, and then try filling the groove with Aluminum brazing rods;
    https://youtu.be/y0RnAXVVWG4?si=RihKWYjs9gmZAPAa
    Then drill and tap the hole.
    It might not work, but then again, it might.
    ridefreak and hinmo24t like this.
  4. Aug 3, 2025 at 8:30 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I'd give the RTV a try. Wouldn't trust it long term. Might last just enough to get you to the Toyota dealer and into that 4th gen.
    Rob MacRuger, hinmo24t and b_r_o like this.
  5. Aug 3, 2025 at 8:53 AM
    Palomar Taco
    Palomar Taco Active Member
    Aaron
    So FL
    '23 Taco SR5 2wd Street Truck
    If you remove the head to repair by brazing or welding (which is your best option IMHO), you better take somewhere that can bolt it to a jig such that heating the aluminum does not warp or damage the shape & flatness of the deck. Otherwise, you may fix the leak only to have created a problem with sealing of the head gasket later.
    hinmo24t, isdjww and GilbertOz like this.
  6. Aug 3, 2025 at 9:14 AM
    JohnDoeFasho
    JohnDoeFasho Please be patient I’m autistic
    2009 TRD Sport DCLB
    OTT Tune
    It’s all in the hips
    Find a good mechanic you like man. Some things are better to farm out.
    joba27n likes this.
  7. Aug 3, 2025 at 9:44 AM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    'Bout to open a medium-sized can of worms here.
    46 FT-lbs sounds unreasonably high for this fastener in this location, going into an aluminum casting.
    Looking carefully at 2 pages of the 1GR-FE engine diagrams with lots of torque specs on them -- I suspect there may be a typo? Start on page EM-194 (you have to scroll way way down in this post: https://www.tacomaworld.com/threads/the-torque-spec-guide.318116/#post-8281783)
    All sorts of other bolts of approx. the same size seem to range from 6 to 24 foot pounds, max. For example, the #1 and #2 engine hanger brackets call for 24 ft-lbs. Timing chain cover bolts, ~17 ft lbs.
    This just a filter-screen holder, with a gasket no less, does it really need to be cranked to 46 ft-lbs or is this published figure just.. wrong?
  8. Aug 3, 2025 at 10:01 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I’m Definitely replacing the head before I’d spend 40k on a new truck.
  9. Aug 3, 2025 at 4:24 PM
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    I agree with you 100%. When I cleaned my VVT-i filters, I didn’t come anywhere near torquing that plug to 46 ft-lb. If I had to guess, I gave it no more than 15 ft-lb. It could be a typo, but if that spec really has the potential to crack the head like the OP experienced, that's one serious mistake. EM-194 clearly states 46 ft-lb though... who knows?
  10. Aug 3, 2025 at 9:24 PM
    Imageoguy
    Imageoguy [OP] Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
    Didn't reached 30 before the tension just went limp. Made a few more clicks and didn't feel any additional tightening so I stopped and hoped for the best, which unfortunately, didn't happen. I'm sure I wasn't at 46, I just finished adding the belt tensionner and ac compressor and it wasn't much more than that level of torque, if even that.
  11. Aug 4, 2025 at 10:53 AM
    Imageoguy
    2012 DCLB SR5
    Got a first quote, 7K to 10K CAD to change the head. Running Tacos with similar yrs and mileage are 9K to 18k CAD here. Tough choice, not sure when the bleeding will stop. Can't say mine is in the best of shape, cosmetically, got some rust and started perforating on the rockers and welded lots of cracks on the radiator support. Frame is in good condition though, and I dropped near 8k of parts in the last 3-4 years (redid suspension including BP-51 rears, refreshed drivetrain, new LCA's, alternator, idlers, brakes front and rear including calipers, front wheel bearing etc, all OEM except suspension). Anybody looking for a project in the Ottawa area, I might have one with good potential. Still weighing my options.
  12. Aug 4, 2025 at 12:55 PM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I was going to suggest the same thing. I'm thinking it'll probably need map gas instead of typical propane to get the area hot enough.
  13. Aug 4, 2025 at 3:27 PM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    That is a I don't want to do the work quote. Keep looking.
  14. Aug 4, 2025 at 4:15 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Man, sorry to hear about your troubles. I'm surprised to hear that a crack actually formed just from that. Regardless of the cause, it sounds like people already posted good recommendations for you.
    If this did happen to me, I'd pull the head and either tig it myself or just replace it, but we're probably in different situations. Whether you end up with a 4th gen or not, it's still worth fixing and either keeping or selling. It sounds like you were trying to follow the proper steps and, sometimes, shit happens. I can relate.
    IF you're digging this deep into the engine, consider installing the URD exhaust cam gear.
    Good luck and keep the thread posted.
  15. Aug 4, 2025 at 6:46 PM
    #35
    Palomar Taco
    Aaron
    So FL
    $7-10K is a ridiculous price to repair or replace the head!
    Glad i don't live in Canaduh...
    joba27n likes this.
  16. Aug 4, 2025 at 7:12 PM
    #36
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Wish I could say the same
    p.s. anyone looking to sponsor an rse mechanic with a wife and kid dm me;)
  17. Aug 4, 2025 at 8:02 PM
    #37
    Superdave1.0
    SoCal
    Pretty standard price here in the states. The shop is taking on a lot of risk with a head job on a newer, more complicated engine like the 3.5 Tacoma.
  18. Aug 5, 2025 at 3:50 AM
    #38
    Palomar Taco
    Aaron
    So FL
    Perhaps I'm wrong on my assessment for what all is involved. Anyone know the book hours for this job?
  19. Aug 5, 2025 at 5:36 AM
    #39
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    This high cost is the penalty for having OHC engines and heads, having to deal with all the valve train timing hardware. Replacing a head on OHV is much much simpler and cheaper.
  20. Aug 5, 2025 at 5:56 AM
    #40
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    Some here must think replacing a head amounts to Rocket Science. This design is very typical for a V6 engine, almost all are OHC these days and VVT isn't anything new. Nothing special about changing out a tacoma head compared to almost every other V6 made in the last 20 years, yes there's 4 pesky cams and allot of marks to line up, if that is intimidating then it's a decent price. IMO the price is high by about ($2~3K can). 8-12 hrs for a experienced mechanic to R&R both heads and replace gaskets. That's about 95% of the work the op needs and quite a few on here manage to do it with just the manual and zero experience with the inside of their motors.
    To the OP, good luck and I hope it works out.
