Big problem (I hope not)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by techteacher, Nov 23, 2012.
  1. Nov 23, 2012 at 10:36 PM
    techteacher
    techteacher [OP] Member
    Tim
    Tustin, Ca.
    `07 PreRunner
    FJ 17" rims
    Own a 2007 PreRunner. Went though the tutorial to disable the DRL`s. Cut the red/green wire - works. Had the bright idea of a switch to turn them on if I wanted 2. Bought a lighted 3 terminal switch so when the drls are off so is the light on the the switch. After wiring correctly (I thought) it didn`t. Got the the constant 12 volt from the white /blue wire, connected the load or drl wires and ran a ground as the instuctions indicated. Worked but backwards. drls still on durring day and off when driving at night Here`s the bad part - While switching wires to see if I could fix it I got a spark and now the truck won`t start, automatic gear shift won`t go out out park, no radio,blower,windows, but I have all lights but turn signals, door locks. Checked fuses, those that operated the working circuits were ok, those that didn`t, didn`t. Any ideas? I`m in a real bind here
    Thanks,
    Tim
  2. Nov 23, 2012 at 10:42 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    How did you check the fuses? Use a test light if possible. Hook it to a known good ground an check for power at both sides of the fuse.
    Did you check the underwood fuse panel as well as the inside fuse panel?
  3. Nov 23, 2012 at 11:07 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You have two fuse blocks, one under the dash and one under the hood.
    Some of those systems are protected by fuses at both locations. The shifter not coming out of P indicates that the brake light circuit is dead.
  4. Nov 23, 2012 at 11:19 PM
    techteacher
    Tim
    Tustin, Ca.
    `07 PreRunner
    FJ 17" rims
    Wiring is bachk to stock, used a test light on all fuses, brake lights work. Told you this is weird.
  5. Nov 23, 2012 at 11:25 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    how do you have DRL's in an 07? unless they were added aftermarket your truck didnt come with them. i think you fucked your security system up... nice knowing you.
  6. Nov 24, 2012 at 5:43 AM
    techteacher
    Tim
    Tustin, Ca.
    `07 PreRunner
    FJ 17" rims
    The truck came with the drl`s, can see additional wiring added. I bought it new from the dealer and it was like that
  7. Nov 24, 2012 at 5:45 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    The ign1 fuse does all the problems u described. Check that fuse
  8. Nov 24, 2012 at 6:32 AM
    techteacher
    Tim
    Tustin, Ca.
    `07 PreRunner
    FJ 17" rims
    Did the battery thing, no go. Possiblbe fusable link but some functions work, some don`t The security system light flashes and I manualy took apart the shift tower and pushed in the plunger to get it into nuetral. Guess I`m off to the dealer, trucks on it`s way. Gotta be a fuse I`m missing.
  9. Nov 24, 2012 at 6:33 AM
    techteacher
    Tim
    Tustin, Ca.
    `07 PreRunner
    FJ 17" rims
    Checket it but I`ll give it another go. THANKS!
  10. Nov 24, 2012 at 6:38 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    As said above ,check the IGN1 fuse. Its located under the dash. This is the fuse that is usually blown when you cant get it to come out of park.....along with the other things you mentioned.
  11. Nov 24, 2012 at 6:42 AM
    techteacher
    Tim
    Tustin, Ca.
    `07 PreRunner
    FJ 17" rims
    Didn`t work
  12. Nov 24, 2012 at 8:12 AM
    techteacher
    Tim
    Tustin, Ca.
    `07 PreRunner
    FJ 17" rims
    That`s not a ign. 1 fuse on the panel is it. You`re saying it`s up under the dash where you can`t see it?
  13. Nov 24, 2012 at 8:16 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    I know my 07 pre runner did not come with DRL. Are you positive its not an aftermarket set up?
  14. Nov 24, 2012 at 8:28 AM
    boomer6
    TN
    Tacoma TRD Offroad
    Its on the dash panel............on my truck(its a 2011) so might be differant ............The IGN1 is second row down.........third fuse in from the left. Its a red 10 amp fuse. Hope this helps.
  15. Nov 24, 2012 at 8:51 AM
    techteacher
    Tim
    Tustin, Ca.
    `07 PreRunner
    FJ 17" rims
    It is a factory set up, optional. Toyota part # It`s not the headlights that are on but but the turn sig. yellow lights. They`re on all the time. There is a tutorial on this site to istall this harness and disconnect if you want to. Mine came installed new.
  16. Nov 24, 2012 at 8:52 AM
    techteacher
    Tim
    Tustin, Ca.
    `07 PreRunner
    FJ 17" rims
    Thanks for your help - it`s at the dealer now - ugh
  17. Nov 24, 2012 at 8:59 AM
    boomer6
    TN
    Tacoma TRD Offroad
    Hope they get you going.Please let us know what they find .
  18. Nov 24, 2012 at 9:04 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The DRL were available back in 07... came on mine and was listed under optional equipment.
  19. Nov 24, 2012 at 9:33 AM
    techteacher
    Tim
    Tustin, Ca.
    `07 PreRunner
    FJ 17" rims
    Definately - hope no one has this issue. If I would have just cut the wire and didn`t try some fancy stupid light - highsight is 20/20
  20. Nov 24, 2012 at 2:19 PM
    techteacher
    Tim
    Tustin, Ca.
    `07 PreRunner
    FJ 17" rims
    Definately a dealer option, toyota part # on harness tag. Eventually it yellows the turn signal lense and will start to bubble the inside of the lense That`s why I`m turning mine off. Search DRL install tutorial and then search diconnect, same guy. Cut the red/green wire to disconnect. It works, just don`t be a dummy me and put a switch in.
