Big Three Wiring Upgrade - 2nd Gen Tacoma - Writeup with pictures!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ramonortiz55, May 3, 2020.
  1. May 19, 2020 at 5:38 PM
    #41
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    i like this
  2. May 28, 2020 at 7:58 AM
    #42
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Subd
    Is the wire used stranded flex or stranded solid conductor? Is it pliable or does it hold shape/bends?
    I got the blue n crusty on my terminals, and I think it's dirty power cables I've added to accessories, or poo poo battery from wheeling and sloshing around lol
    Would love a pre-made kit for this. Pretty well over my DC power days, have the tools and knowledge, just not the cares anymore to sit down and craft one up.
  3. Jun 10, 2020 at 2:25 PM
    #43
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    thanks so much for this writeup @ramonortiz55! i have been wanting to do this and gathering parts for this for a while. this thread showed me what i needed to know to get it done!
    rather than work from a pre-made harness i ran cable to starter and alternator individually and then attached cables together with zips and loom. i did not try to get it all neat and tidy like Ramon. it's tough to get this big ass 1/0 routed back where the oem wire came from.
    this job took me a full day and i ended up with low voltage codes. i think the nut on the post in the fuse box was not torqued down because moving the wires around on the post and re-torquing solved the issue.
    also redid stereo power cable on the anl fuse (not connected in image) and wiring to the blue sea fuse box.
    i just received a powertray but i'm not sure if it will work with the sc reservoir. i'm happy with how things are at the moment.
    deanosaurus likes this.
  4. Jun 10, 2020 at 2:35 PM
    #44
    ramonortiz55
    Ramon
    Texas
    stock
    I am glad it worked out for you bud!
  5. Jun 14, 2020 at 6:13 AM
    #45
    centurion
    centurion Well-Known Member
    Northern New Jersey
    2006 Tacoma TRD Sport,double cab, 4X4, auto, speedway blue
    Air-Raid air filter, de-badged,custom grill,hood and tailgate struts
    If you have the factory tow package doesn't it have a better alternator? If it does is the electrical components heavy duty?just curious, looks like a good upgrade to support more electronics.
  6. Jun 14, 2020 at 7:22 AM
    #46
    ramonortiz55
    Ramon
    Texas
    stock
    it does! i completely forgot about that :anonymous:
    4x4cajun likes this.
  7. Jun 22, 2020 at 1:33 AM
    #47
    Mudman
    Mudman Well-Known Member
    Cerritos
    08 4X4 TRD Sport
    Thanks for taking the time to post this. I wasnt necessarily looking to upgrade per se, but replace some wires. My battery to ground, battery to engine wires are super corroded, and need to be replaced. This write up will be a huge help.
  8. Sep 25, 2020 at 9:24 PM
    #48
    Jimmy92870
    Jimmy92870 Well-Known Member
    Texas (DFW)
    07 DCSB PreRunner
    Nice write up. Got a couple of questions. How come you didn't replace all the wires to where they were originally at? Does this way work better? Also did you leave the small ground wire on the shock tower or was that upgraded as well.
    Slashaar likes this.
  9. Nov 11, 2020 at 8:28 PM
    #49
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Subbed for future reference. :thumbsup:
  10. Feb 7, 2021 at 8:21 AM
    #50
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Regarding that black wire UNDER the fuse box:
    Where does the other end go? Is this the positive feed for the cabin fusebox?
  11. Feb 14, 2021 at 3:43 PM
    #51
    ConCise870
    ConCise870 New Member
    2009 Tacoma Prerunner V6 Double-Cab
    Somebody mentioned the idea of an auxiliary battery for powering "extras" like a winch and other electronic upgrades/mods. Would this circumvent the need for this whole situation?
  12. Feb 15, 2021 at 2:02 PM
    #52
    Slashaar
    Josh
    Kansas City, MO
    This is for current draw across the board. The thicker gauge wires are better for energy transmission, especially if you move to a larger alternator.
    ConCise870[QUOTED] likes this.
  13. Feb 16, 2021 at 12:50 PM
    #53
    Hankstarr
    Hankstarr Member
    2006 White Tacoma Access-cab 2.7L 4x4
    2019 Sport Black alloy wheels swapped for stock LED Headlights LED Turn signal lights CAN bulb correction device Fog Lights added Radio ripped out...- replacement coming soon?
    Hey all,
    I understand that these drop in kits are not available anymore and I also get that it's a lot of check twice and cut once to get this to work... got it.
    That said, does anyone else have one of these that has not been installed and could do a little diagram of gauge and approx lengths of the cables?
    I see the pictures for a relative reference, I'd just like to have a place to start ballparking without pulling the old one out first.
    I would consider trying to make a few of these if I can make one for myself as I'll need to buy a heavy duty crimper.
    Thanks for any help.
    I've got be honest, I've never been a "car guy" but I've done a million other little jobs in my 50yrs that have made me appreciate mechanics and mechanical workings. I love working on my truck now and trying to figure out how this does that.
    Thanks for all the tips I've acquired from this site so far and I look forward to mining more info.
    Cheers
    patrick
  14. Mar 11, 2021 at 9:54 AM
    #54
    Lineback
    Lineback Well-Known Member
    2013 Tacoma DoubleCab TRD
    5 x 285/65/R18 Nitto Trail Grappler mud tires on 18" XD wheels (full sized matching spare) Bilstein 5100s with 3" spacer lift Prinsu roof rack Secondary air filter mod ARB Deluxe Bull bar front bumper + ARB LED fog lights ARB Recovery point Warn 9.5xp winch with steel cable SOS Concepts angled rock sliders with kick-outs 2 x Baja Designs LP9 Pro mounted to ARB bumper AVS window vents Interior knob mods Toyota bed mat Toyota hood deflector Toyota bed cargo divider Steelcraft 33250 Rear tail light cage guards Reverse light LED mod Wet Okole seat covers WeatherTec floor mats Tail gate anti-theft mod COMMS: On-board 2 meter VHF HAM radio (Boafeng F8HP mobile) + Bluetooth integrated mic External antenna: Nagoya UT-72 Super Loading Coil 19-Inch Magnetic Mount spotter radios: 2 x Cobra ACXT1035R FLT Gear: IFAK EMT Trauma wound kit 5lb fire extinguisher
    Glad I read this post. I just added a new Warn 9500xp winch, but I have not yet upgraded anything else in the OEM wiring. Made the mistake of grounding the winch to the frame next to the battery at first, now I understand why. Which alternator are you running? Any other "must do" upgrades or best practices when running a winch ?
  15. Mar 12, 2021 at 10:20 AM
    #55
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Yeah, just remember both electrical paths going and returning to the electrical source should be equivalent. You won't necessarily hurt anything with your winch, you just won't get to take full electrical advantage of the motor and will be limited by the pipe diameter in the electrical path either coming or going. I am running a rewired OEM 250amp alternator. Nothing really must do, you can just slap it on and wire it directly to the battery with the appropriate gauge wire for the length of your run. Just pull your winch specs and then google wire gauge capacity specs and there are plenty of tables that come up to show you the length of voltage drop per gauge needed.
    ARoman83 and deanosaurus like this.
  16. Mar 12, 2021 at 10:30 AM
    #56
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    I'm only waiting on some 4AWG 3/8" lugs before I do this myself. I'll post a writeup with dimensions and material sources. Depending on how it goes I may consider putting a few more together for funsies.
    ARoman83 and ryfox0276 like this.
  17. Mar 15, 2021 at 9:24 AM
    #57
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    Does the battery ground wire interact with anything or go straight to the engine block?
    I’m relocating my battery to passenger side so I can put a bigger dual battery in the larger driver side space. I plan to extent the stock charging wire across to my starter and find a new ground over there. Can I use the stock ground for my aux battery?
    ARoman83 likes this.
  18. Mar 16, 2021 at 4:31 PM
    #58
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    It goes to the starter (not the block directly) and the ground point next to the stock battery location in the engine bay. Look at the last photo in the first post - it shows the shorter negative leading to that ground point in the bottom right corner of the picture.
    There are some other pictures here: https://www.tacomaworld.com/threads...ig-3-plus-closed.391316/page-29#post-23206848
  19. Apr 23, 2021 at 4:06 PM
    #59
    cmoterboat
    cmoterboat Well-Known Member
    Carson
    2006 Silver Tacoma TRD
    resurrecting this thread because jeepcables.com (also toyotacables.com) just released an upgrade kit for our trucks. I could not find an install vid for it, so I'm here.
    I just installed a similar mod on my 88 cherokee XJ. It did wonders for starting/windows/locks. Everything with a motor seems to run about 50% faster.
    So if you're gonna do this, look for a low gauge cable with as many copper strands as possible. Electrical current flows on the outside of materials. One solid copper strand flows less than many strands woven together. I don't know how that works, but thats what I remember from high school physics. you would also want to put a fuse between the alternator and whatever you connect it to. just in case. I would think a line to the starter is the most impactful.
    Our trucks are likely to benefit less from this kind of mod. Toyota engineers were smart, but it couldnt hurt anything. I'm curious if anyone who has done this mod has noticed any improvement in the other electronics on board.
    Taco 422 and deanosaurus like this.
  20. Apr 23, 2021 at 5:03 PM
    #60
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    I haven't looked at those kits but the one shown here, as you note, has an issue with fusing.
    I recently did a fairly detailed writeup on a Big 3 for the 1GR here - https://www.tacomaworld.com/threads...lights-hood-lights-aux-panel-and-more.712981/ - that shows a "proper" Big 3 on our trucks to include preserving the factory wiring path through the factory fusebox.
    ARoman83 and cmoterboat[QUOTED] like this.
