Big Three Wiring Upgrade - 2nd Gen Tacoma - Writeup with pictures!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ramonortiz55, May 3, 2020.
  1. Apr 23, 2021 at 6:13 PM
    #61
    cmoterboat
    cmoterboat Well-Known Member
    Carson
    2006 Silver Tacoma TRD
    Very nice. Great write up. I'll look at that one when I eventually do the mod.
    deanosaurus[QUOTED] likes this.
  2. Apr 23, 2021 at 6:27 PM
    #62
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Was just looking at these, and the wires they compare (factory to jeepcables) look like the exact same internal size with a thicker casing....
  3. Sep 9, 2021 at 8:46 AM
    #63
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    I see the photo you are talking about. I think it is showing the OEM cables uses thicker strands versus ToyotaCables using finer strands. Should mean their cables are more flexible and when you are talking 1/0 that is not a bad thing.
    Slashaar[QUOTED] likes this.
  4. Dec 13, 2021 at 6:27 AM
    #64
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    If anyone has done this and their stock wires are good, I'll buy them! Send me a pm! My positive wire broke going into the fuse box, and my negative clamp broke off. TIA
  5. Jan 1, 2022 at 11:20 PM
    #65
    Mr. Pauly
    Mr. Pauly New Member
    2015 Grey Tacoma TRD
    3” Bilstein 5100 lift 33” Yokohama Geolander A/TS RCI 12” Bed Rack for CVT Tent Warrior Cab Rack CVT Awning
    So there are a lot of factors when it comes to Voltage Drop, Flicker, and Ampacity of cable to any source. Keys to remember; how many electrical components are hooked up to one cable, how long each component is running, and what’s running at the same time. We often build very conservative to actual load/s. Assuming your driving at night with all lights/fogs on, juicing up 2nd battery or backup source, running winch, and blasting 12” Subs to AC/DC (my choice) all at the same time… it might actually be a good idea to do this to your power supply. Wouldn’t want the fogs in the rear to go out or dim while on a steep embankment tied to a tree. Or just stop the song till you make it out (kill the mood)… You would need to have a lot running at the same time to warrant anything bigger than stock cable. The only thing from my experience that warrants larger cable is audio equipment because it’s a constant large draw and typically far away from source. Hope this helps.
  6. Jan 2, 2022 at 5:50 AM
    #66
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    The major factor for my initial proto/install (not the kit found in this thread) was not necessarily the conductor size but the terminal quality. I found that the factory stamped lugs were corroding away to nothing and the stamped battery-side connections in particular were allowing corrosion to creep way up into the factory wiring. The cost delta between equivalent-to-factory conductors and 1/0 and 4 AWG was actually pretty marginal, so it was a "Why not?" proposition. (The cost of a factory replacement harness compared to a custom solution made me puke blood).
    I agree that in terms of conductor size only, most people probably don't need to up size, but then again most people with plate bumpers, sliders, and farm jacks won't ever get the full benefit of those, either.
    IMO the major benefit of a Big 3 upgrade for most people is corrosion resistance and modularity, with conductor size being a bonus.
    Mr. Pauly[QUOTED] likes this.
  7. Jan 2, 2022 at 6:32 AM
    #67
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Head lights, heater and plow motor so far has not come to a stop when I lift the plow.
  8. Jan 5, 2022 at 10:18 AM
    #68
    Mayak1957
    Mayak1957 Member
    Tony
    Connecticut
    09' Speedway blue, DCSB TRDOR taco, 6spd Man.
    2WD Low module, Foglights anytime, Ultimate headlight Upgrade.
    So what’s everybody’s opinion on the “big 7”wiring upgrade kit for our trucks? Considering
    www.JeepCables.com now offers there “big 7” upgrade kit with an external fuse to avoid routing the increase in current capacity through the smaller fuse box wiring.
    Planning on a wiring upgrade to pave the way for future winch, air comp, and misc electrical additions. I like the kit approach for its simplicity, but would go diy if need be.
    dborrer likes this.
  9. Jan 5, 2022 at 11:01 AM
    #69
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    System maximum current doesn't change without changing the alternator to a higher amperage alternator AND increasing system load (with e.g. a seriosly monster sound system, outer space life support systems, or whatever). If you upgrade from the standard alt (90A? 100A?) to the tow package alternator (130A) you can easily replace the fuse to match with the OEM tow fuse. If you change to an aftermarket high amp alt (I've seen up to 300A) you can source and replace the factory fuse just as easily.
    I'm not sure how that kit would run, necessarily, since either way you should be running the alternator hot to the fusebox feed, which is fused internally and bussed to the battery and the rest of the system.
  10. Feb 24, 2022 at 7:48 PM
    #70
    moosetrial
    moosetrial Member
    quick question, why not just connect to the battery and then have the battery/alternator connect to the fusebox (w/ a proper fuse of course)? The only reason I ask is that the audio guys keep saying hooking directly up to the battery is that much better for the audio and will be way easier to install.
  11. Feb 24, 2022 at 8:07 PM
    #71
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I have a question for the class. Does the stock wiring incorporate a fusible link to the starter or alternator?
  12. Feb 25, 2022 at 4:14 AM
    #72
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    It does not.
    Superdave1.0[QUOTED] likes this.
  13. Feb 28, 2022 at 11:12 PM
    #73
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    @deanosaurus made a reference to it, and I will be more vocal about it … that middle wire going from the battery to the alternator should not be unfused. If that wire gets a short you can possibly blow the battery and/or the alternator. The shorter wire goes to the fuse box which is fused, then it goes to the alternator. Thus, you dont need a high amp fuse. 100-amp fuse should be sufficient.
    TwistedOmYoga likes this.
  14. Mar 1, 2022 at 4:09 AM
    #74
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Given the problems with the setup shown in this thread I'm not sure why it's still stickied.
  15. Mar 1, 2022 at 6:27 AM
    #75
    moosetrial
    moosetrial Member
    I'm about to do a slightly modified version of this. Does the shorter wire going from the battery to the fusebox also touch the alternator wire inside the box? (when completely stock) or does it have to first pass through the fuses in the box before flowing to the battery?
  16. Mar 1, 2022 at 7:19 AM
    #76
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Yo! I looked up your write up and the discussions here and here and was completely unaware of the flaw in Bamatoys wiring setups. The wiring I have was one of the originals from Bamatoy as @henryp mentioned here. . Ill put together a sketch soon to ensure that I understand how this wiring is really meant to be to not ignore the original fused setup.
  17. Mar 1, 2022 at 7:44 AM
    #77
    ramonortiz55
    Ramon
    Texas
    stock
    wait. i blew my alternator fuse back last fall doing unrelated stuff, if i bypassed the alternator fuse how else would it have blown?
  18. Mar 1, 2022 at 7:54 AM
    #78
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    No telling without knowing what you were doing or what might have accidentally touched what - that fuse is on the input bus for the fusebox, so it could have been any number of things.
    Here's a post with an abridged diagram:
    https://www.tacomaworld.com/threads...ghts-aux-panel-and-more.712981/#post-25425658
  19. Mar 1, 2022 at 7:56 AM
    #79
    ramonortiz55
    Ramon
    Texas
    stock
    thank you.
  20. Mar 1, 2022 at 8:00 AM
    #80
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Taking a second look at the abridged diagram, if you had the alt running to the battery running to the fusebox, it's entirely possible that the fuse blew due to current going through it "backwards" (from stock configuration) from the alt - the alt would have simply been on the wrong side of the circuit (leaving the battery and the rest of the fusebox outputs unprotected by the fuse, which is the problem with the configuration presented in this post and others on TW).
    Here's the abridged diagram of the correct configuration:
    Note that if the generator is coming in through 2C, the fusebox output (the line disappearing off the bottom of the diagram) is unprotected by the alt fuse, and an overcurrent flowing from 2C would have still blown that fuse without protecting the output.
    moosetrial likes this.
