big tires vs fat bobs
Discussion in '5 Lug' started by Hinanomon, Oct 14, 2011.
  1. Oct 14, 2011 at 4:05 AM
    Hinanomon
    Hinanomon [OP] Member
    Pukalani
    2011 4cylinder 2wd 5 lug
    tints, sounds
    hi, i have a silver 2011 2x4 4cylinder 5 lug regular cab, im probably gonna go with the fat bob suspension lift and i was wondering if 31" tires would be too big?
  2. Oct 14, 2011 at 11:44 AM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    Total Chaos Mid Travel, Sway away coilovers,31x10.50x15 goodyear wrangler authority's
    I have 31's on my truck and I have minimal rubbing issues. If you run aftermarket wheels with the proper backspacing u should b fine. To get a bit more clearance remove the little metal black box bolted to the wheel well behind the plastic fender well
  3. Oct 14, 2011 at 12:11 PM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    did your truck fel sluggish when you put on the 31s
  4. Oct 14, 2011 at 12:18 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    it will feel sluggish unless you regear
  5. Oct 14, 2011 at 3:29 PM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    I have a 5spd so I didn't notice it too much
  6. Oct 14, 2011 at 3:57 PM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    I'll probably have to regear mine, but thats fine by me. ever better reason to get a locking diff. haha
  7. Oct 22, 2011 at 3:07 PM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    Ive heard a lot of mixed reviews on different brands of lockers. Were you thinking of an air locker?
  8. Oct 23, 2011 at 11:03 AM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    the ARB air locker is the best locking diff i've seen. one of my friends who owns a cherokee has an arb rear locker and it works flawlessly
  9. Oct 23, 2011 at 11:07 AM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    Only downside is price
  10. Oct 23, 2011 at 11:19 AM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    I'm more than willing to spend the money for it to work perfect every time
