BigDaddy’s Buzzed Shop Builds, Beer, Smoking BBQ, Grilling, Cake an BS
Discussion in 'Other Builds' started by Bigdaddy4760, Jun 5, 2019.
Thread Status:
Not open for further replies.
  1. Mar 21, 2020 at 9:36 AM
    Pandaman59
    Pandaman59 Well-Known Member
    Frank
    Arlington
    2017 DCSB
    :hattip:
  2. Mar 21, 2020 at 9:37 AM
    ashris
    ashris Well-Known Member
    Ashley
    Trying to fix my AC blower.. took off the unit everything looks fine- got wonky after the HU install? Anyone have a guess to what it could be?
    Pandaman59 and MattCowsmasher like this.
  3. Mar 21, 2020 at 9:37 AM
    ashris
    Ashley
    How ya doin man!
  4. Mar 21, 2020 at 9:39 AM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    All the places around here are doing curbside and carry out. Still get good food just gotta eat it at home.
  5. Mar 21, 2020 at 9:42 AM
    Kanyon71
    MI
    What’s it doing/not doing? You check the fuses? Also make sure none of the connectors are loose or unplugged.
  6. Mar 21, 2020 at 9:42 AM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Breweries here have started doing home delivery for beer! It’s great. Some of the ones that do food are doing to go orders too to keep people working too. Good stuff. I stopped by my local brewery yesterday for a few packs to go to try and support
  7. Mar 21, 2020 at 9:44 AM
    ashris
    Ashley
    The switch is not making any air blow out- checked everything and it seems to be fine... low through high isnt workin. And I recently replaced the HVAC thing under the glovebox
  8. Mar 21, 2020 at 9:51 AM
    Pandaman59
    Frank
    Arlington
    2017 DCSB
    Good and you.
  9. Mar 21, 2020 at 9:54 AM
    Kanyon71
    MI
    If you have a meter you can pull the plug at the blower motor or at the switch and see if power is coming through. If you’re not seeing power come through check all connections and fuses again (sometimes you need to check fuse with a meter may not look blown but can be). If you’re seeing power come through then check power at blower motor if you see powers there then the motor may have gone bad again.
  10. Mar 21, 2020 at 9:57 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Did you reconnect the switch panel when you put everything back after the HU install?
  11. Mar 21, 2020 at 9:59 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Known issue with resistors on 2nd Gen; had mine replaced around 90K miles on my '07. :notsure:
    https://www.tacomaworld.com/threads/fan-blower-motor.642691/
    EDIT: HU swap could just be coincidence?
  12. Mar 21, 2020 at 9:59 AM
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Pastrami will hit the smoker tomorrow morning, has to sit for 24hr with the magical pastrami rub.
  13. Mar 21, 2020 at 10:05 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Also something in there about the plug and bad connection (by design flaw :notsure: ) but if disconnected for HU swap, likely didn't make connection right on reinstall. I think this might be VERY LIKELY because you say it's not working at all? @ashris
  14. Mar 21, 2020 at 10:21 AM
    ashris
    Ashley
    Yeah I took it in to a local place just cause I don’t have the tools to really get in there... but the guys seem pretty stumped as well they’re testing it now. I checked the fuses and they’re all fine so that’s why I decided to take it in
  15. Mar 21, 2020 at 10:22 AM
    ashris
    Ashley
    But with the HU install we just used readharness from Crutchfield so no wires were really messed with ¯\_(ツ)_/¯
  16. Mar 21, 2020 at 10:24 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Electrics get funny...doesn't take much disturbance to make a poor connection do strange stuff. Hope your guys get it figured out for you. :hattip:
  17. Mar 21, 2020 at 10:26 AM
    ashris
    Ashley
    Thanks man!
  18. Mar 21, 2020 at 10:27 AM
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Don't you have to disconnect and remove the HVAC controller to install the HU? Not trying to be a smartass but is it possible a connection was missed during reassembly?
  19. Mar 21, 2020 at 10:32 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Truck fridge stocked with beer, water, Sammich stuff. Got the cheapo solar setup going works good if I need to use it.
  20. Mar 21, 2020 at 10:34 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Dude :bowdown:
Thread Status:
