BigDaddy’s Buzzed Shop Builds, Beer, Smoking BBQ, Grilling, Cake an BS
Discussion in 'Other Builds' started by Bigdaddy4760, Jun 5, 2019.
Thread Status:
Not open for further replies.
  1. May 6, 2020 at 4:37 PM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    I’m sure this battery is near its end. It’s the stock battery and I gor the truck in 2016. I might just go buy a new one anyway. Any recommendations?
    MarX, wilcam47, lynyrd3 and 5 others like this.
  2. May 6, 2020 at 4:37 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    If that is the original battery you did good getting 4 years out of it. Sounds like it’s time to go battery shopping:thumbsup:
    MarX, wilcam47, Biscuits and 5 others like this.
  3. May 6, 2020 at 4:39 PM
    Bigdaddy4760
    Bigdaddy4760 [OP] Well traveled Older Than Dirt
    Maner
    Poolville Texas
    I got exactly 13 months out of the factory battery and I just got a durulast gold from autozone it had a hella if a warranty.
    lupard, Beretta4x4, MarX and 9 others like this.
  4. May 6, 2020 at 4:39 PM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    I’m a huge fan of the agm style battery but duralast gold has always done well for me it’s got a good warranty also.
    Beretta4x4, MarX, wilcam47 and 6 others like this.
  5. May 6, 2020 at 4:40 PM
    uhplifted
    Brian
    16 DCLB OR
    Yeah it is the stocker. Can’t complain if it’s life. Only died on me one other time when I was on vacation for 2 weeks. Time for a new one I suppose
    MarX, lynyrd3, Biscuits and 5 others like this.
  6. May 6, 2020 at 4:40 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    This
    lupard, Beretta4x4, MarX and 6 others like this.
  7. May 6, 2020 at 4:40 PM
    uhplifted
    Brian
    16 DCLB OR
    Duralast gold it is. Thanks fellas!
    Beretta4x4, MarX, wilcam47 and 8 others like this.
  8. May 6, 2020 at 4:43 PM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    4 years is good. Mines a 17 and it lasted either 13 or 24months. I cant remember.
    I did the Duralast gold also. Good warranty and needed it ASAP since I had to drive to work the next morning. I did bump up to the 27f from the 24 that came in the truck.
    I thought about going AGM but I dont want to have to put a battery tender on it regularly since our alternator cant charge them fully/properly. I'm going to add an AGM as a second battery with a dc-dc charger that can charge it properly!
    Beretta4x4, MarX, wilcam47 and 4 others like this.
  9. May 6, 2020 at 4:43 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    :thumbsup: If you wanna the best one imho it’s the platinum which is an agm. If your not running a winch or fridge imho wouldn’t be worth the investment but they last a lot longer. I had one for a bit it made the truck start a little faster but recently upgraded to a group 31.
    MarX, Biscuits, Pandaman59 and 2 others like this.
  10. May 6, 2020 at 4:44 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    I recently read ovtuning is working on a tune to increase the voltage an agm.
    Beretta4x4, MarX, StayinStock and 4 others like this.
  11. May 6, 2020 at 4:45 PM
    uhplifted
    Brian
    16 DCLB OR
    I don’t run either. I’ll just stick with the gold but thanks for the info!
    MarX, TomTwo, wilcam47 and 6 others like this.
  12. May 6, 2020 at 4:45 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    :fistbump:
  13. May 6, 2020 at 4:50 PM
    SuperBad
    Dallas, TX
    Truck stuff
    Yes its available with the new vf tuner. I need to look into charging AGMs more but someone commented that while you can get it to the right voltage theres apparently more to properly charging them. I'm not really sure on all of that. I have OVtune and will be upgrading to vf tuner so I will have the ability to bump the voltage for an AGM if I learn it will work properly. I've always planned on going to dual battery anyway and with a dc-dc charger your batterys dont have to match and can charge an AGM properly so I dont know what I'll end up doing now. electricity scares me and AGM's are expensive.
    Beretta4x4, MarX, StayinStock and 5 others like this.
  14. May 6, 2020 at 4:54 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Your absolutely right it scares me to so just the one biggin, I did the fuse to increase vomtage and just slapped on a cheap solar setup it’s pulling 14.5 in full sun that’s enough for me. But I’ve made it a habit at least once a month to hook it to a charger for a few hours.
    Beretta4x4, Nopro, MarX and 6 others like this.
  15. May 6, 2020 at 5:01 PM
    SuperBad
    Dallas, TX
    Truck stuff
    The fuse option would be nice if it was an option on 3rd gens. Charging control was moved from the fuse on 2nd gens to the ECU on 3rd gens... The DC-DC dual battery charger I think I'm going with(OGE/redarc setup) has solar input and control already so I just have to wire up a solar panel to it and I wont need anything else!
  16. May 6, 2020 at 5:09 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Pretty slick
  17. May 6, 2020 at 5:19 PM
    SuperBad
    Dallas, TX
    Truck stuff
    It is nice, just :spending:. Worth it to me though to have a second battery because I'll go out solo and having the second battery will make me feel a lot safer with everything I will be running. Plus if my starting battery takes a crap I can just swap them to get to town and replace the bad starting battery. Not as easy to replace an AGM on a trip so I feel like it may be the best dual battery option if the starting battery goes bad.
    Beretta4x4, Nopro, MarX and 3 others like this.
  18. May 6, 2020 at 5:21 PM
    uhplifted
    Brian
    16 DCLB OR
    All the damned Cato zones are pickup only right now it seems. Gonna call my local Ace auto store tomorrow as they’re closed today. The owner of that shop is always great every time I come in and it’s family owned. Hopefully they have what I need
    Beretta4x4, Nopro, MarX and 2 others like this.
  19. May 6, 2020 at 5:21 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    I like it, if I had an OR I’d go with a dual setup but the abs stopped that and SxS would make me nervous of cracking sheet metal.
  20. May 6, 2020 at 5:23 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Plutonium-fueled nuclear reactor.
    How am I the first person to drop the Back to the Future reference in this gang of misfits? Am I that immature?
    Nopro, MarX, SuperBad and 3 others like this.
Thread Status:
