BigDaddy’s Buzzed Shop Builds, Beer, Smoking BBQ, Grilling, Cake an BS
Discussion in 'Other Builds' started by Bigdaddy4760, Jun 5, 2019.
Thread Status:
Not open for further replies.
  1. Jun 3, 2020 at 8:20 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Mernin' John!
    Matt, good day to you Sir!
    Thanks Robert! I had to wait a while but you know what they say, good things come...........
    Thanks! Yea, the last pair didn't have the fill plates and rocks made their way through. I figured this would help.
  2. Jun 3, 2020 at 8:31 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Yes and already did.
  3. Jun 3, 2020 at 8:32 AM
    Bigdaddy4760
    Bigdaddy4760 [OP] Well traveled Older Than Dirt
    Maner
    Poolville Texas
    Just sickening with what you have to wake up to and see in America. Too many good family values and work ethics gone.
    My house is a safe zone. Firearms are always welcome and recommended. Face masks not required. I've always got a soda, cold water, or beer. My table is non-judgmental. Any family or friend who needs to chat are always welcome. We can talk, share a hug, a laugh, a cry, or just listen. If you're hungry, I'll feed you. I will always do my best to be available... you are always welcome!! This is a value that has been lost
    Pandaman59, irayfz6, samiam and 17 others like this.
  4. Jun 3, 2020 at 8:35 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :oldglory::plane:
  5. Jun 3, 2020 at 8:37 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Pool companies check for leaks in plumbing too ways. Pressure, and sound. First, to determine which run (return or delivery) the leak might be in, they will use the multi-port valve to disable various runs of plumbing and pressurize the lines with water first. It's less apt to damage something but it can also doesn't compress like air. They will throw a pressure gauge on the line and watch to see if it drops. Once they locate which run has the leak they have to locate it. Most leaks occur in joint areas, and rarely in a length of pipe, unless something crushes it. So what they do it they use a "deck mic" which is essentially a microphone inside what looks like a plunger end, connected to a device that has headphones. They will pressurize the line that the pressure drops in and walk very slowly around the deck laying the mic on it and listen. The leak will be a sound similar to a small straw blowing air with some gurgling because the ground around it is wet. Then you just dig around the area, expose the pipe, shut it all down and cut out the broken joint.
    Obviously, cutting through a concrete deck adds some money and work. Removing stone is not going to be easy in a pond. You could basically try to make your own deck mic setup but I bet you could get a stethoscope cheap, and literally listen to the ground or even inside the pond. Yes, you will hear it running but as you get closer to the leak it will get louder.
    You could try soaking the ground around the whole area and pressurise the line with a tire pump or very very low compressor pressure ( 40 psi or less, and a lot less if they are not glued connections ) and watch for bubbles. You'll need to really soak the ground though. This would also work inside the pond.
    3' deep is deep and will not have any effect on root matter except for shrubs and trees. Grass would not show any signs of benefiting, unless everything else is burnt up except for a single area.
  6. Jun 3, 2020 at 8:42 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    This ^^^^ FTMFW!
  7. Jun 3, 2020 at 8:43 AM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    :amen:
  8. Jun 3, 2020 at 8:44 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Good Morning Eric
  9. Jun 3, 2020 at 8:44 AM
    ALI3N_123
    Eric
    Austin, Texas
    Morning Maner. Here at the Toyota dealership brought my moms truck to be serviced
  10. Jun 3, 2020 at 8:59 AM
    wilcam47
    Will
    Bourbon state
  11. Jun 3, 2020 at 9:04 AM
    JennJenn
    JennJenn Remembering Rick ❤
    Jenn aka (dzzyneon)
    Boise, Idaho
    2021 Army Green Trd sport dclb!!~Sold~2008 Indigo ink TRD Sport DCLB!!
    o_O:smack:
  12. Jun 3, 2020 at 9:05 AM
    JennJenn
    Jenn aka (dzzyneon)
    Boise, Idaho
    Lol whatever! Not even close!
  13. Jun 3, 2020 at 9:06 AM
    JennJenn
    Jenn aka (dzzyneon)
    Boise, Idaho
    Morning Maner and friends!! ❣:)
  14. Jun 3, 2020 at 9:06 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    :wave:
  15. Jun 3, 2020 at 9:08 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    I used to work installing rural water lines, miles of them. I am familiar with pressure testing. The problem is I don't have valves to separate 4 different lines. This whole thing was installed some 50 years ago. Most of it it black plastic roll tubing. I don't know where the lines run underground, only where they start and end. It's a mess.
    Right now the pump is running every ~5 minutes, not good for the pump motor. I'm gonna unplug it and put my thinking cap on.
    Thanks for the suggestions fellas, keep 'em coming.
  16. Jun 3, 2020 at 9:17 AM
    Austinguy
    Austinguy #FreeManer
    Robert
    Texas
    First on race day!
    Secrets
    :thumbsup::fistbump::101010::oldglory:
    Pandaman59, samiam, JennJenn and 5 others like this.
  17. Jun 3, 2020 at 9:18 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Ok, I deserve that. I suppose. :devil:
    I tried to make up for being crude but NOOOOOOOOOO!
    Morning Jenn. Hope your feet feel better today. Maybe they just need to be massaged? :D
  18. Jun 3, 2020 at 9:22 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Austinguy, Pandaman59, samiam and 6 others like this.
  19. Jun 3, 2020 at 9:24 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Wait, did you say house well pump or pond? I need to go back and look.......
    Edit, ok, you said well and all I saw was pond...........
    With a well, I would look in the well head at the pitless adapter. Mine was the cause of the same thing about 10 years ago.
  20. Jun 3, 2020 at 9:26 AM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    Morning, crew
    :cheers::oldglory:
    Pandaman59, samiam, JennJenn and 6 others like this.
Thread Status:
