BigDaddy’s Buzzed Shop Builds, Beer, Smoking BBQ, Grilling, Cake an BS
Discussion in 'Other Builds' started by Bigdaddy4760, Jun 5, 2019.
Thread Status:
Not open for further replies.
  1. Sep 27, 2019 at 6:00 AM
    Bigdaddy4760
    Bigdaddy4760 [OP] Well traveled Older Than Dirt
    Maner
    Poolville Texas
    Good Morning Eddie
  2. Sep 27, 2019 at 6:01 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    It’s a cheap flimsy bought cart.
  3. Sep 27, 2019 at 6:04 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    The one I got from Princess Auto, kinda like your Harbor Freight is of great quality. I was surprise but how can you screw up on a welding cart?
  4. Sep 27, 2019 at 6:12 AM
    Martin64
    Martin64 Well-Known Member
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    Good morning.
    Tractor Supply wagon.
  5. Sep 27, 2019 at 8:33 AM
    Pandaman59
    Pandaman59 Well-Known Member
    Frank
    Arlington
    2017 DCSB
    A frame cage with a swivel boom that can attach to overhead hoist . :anonymous: edit : Telescoping Boom.
  6. Sep 27, 2019 at 8:53 AM
    Martin64
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    Crap....wrong picture. You can see the wagon in the lower part of the picture. I have thought about hanging it from an overhead but I don't weld enough to do something like that.
    Pandaman59 and Bigdaddy4760[OP] like this.
  7. Sep 27, 2019 at 9:14 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Think I am going to get this one. It can hold two small welders and plasma cutter with consumables storage
    lupard, StayinStock, JennJenn and 7 others like this.
  8. Sep 27, 2019 at 9:24 AM
    Martin64
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    I'm working on an old slab that's seen better days and I have to roll it in and out of a storage container on dirt. Add that the people before me knocked off one of the front wheels I pretty much had to go with bigger tires. I think if I had half your talent I'd go for something better.
  9. Sep 27, 2019 at 9:48 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    I might build one. Dang steel is so higher right now.
    lupard, Pandaman59, wilcam47 and 2 others like this.
  10. Sep 27, 2019 at 9:58 AM
    Martin64
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    I do like the cart in the picture. I'd like to get the plasma mounted with the welder and have consumables handy like that. I just don't like dragging the cord, leads and airhose everywhere. That's where I got the idea of doing an overhead. Then everything would be up off the ground and not near as cluttered.
  11. Sep 27, 2019 at 9:59 AM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Would air filled tires not make it more unstable while being moved?
  12. Sep 27, 2019 at 10:25 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I dont know if they have small enough tires that would hold the weight...The cart tires Ive seen are usually solid for heavy stuff.
    StayinStock and Pandaman59 like this.
  13. Sep 27, 2019 at 10:26 AM
    Kanyon71
    MI
    Ya same here, was just thinking it could get top heavy and tippy.
  14. Sep 27, 2019 at 11:18 AM
    Nopro
    Nopro Rhino pilot
    Stopher
    Pflugerville
    2014 dcsb Trd Offroad
    Icon stage 5 and 295’s
    Thought you said tipsy...:drunk:
  15. Sep 27, 2019 at 11:21 AM
    Kanyon71
    MI
    That's after some bubba mug beers. :)
  16. Sep 27, 2019 at 11:22 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    :cheers:
  17. Sep 27, 2019 at 11:32 AM
    Martin64
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    The wagon I have is wider than most so that adds to the stability. As long as the tires are up to pressure it does fine. I do have a couple small ratchet straps holding the welder in place.
  18. Sep 27, 2019 at 11:38 AM
    Nopro
    Nopro Rhino pilot
    Stopher
    Pflugerville
    Cut a few circles out of steel and bolt a bearing in the middle. Use a piece of 1” steel strap to make a hoop for a tread surface. Set the axle against the bottom of the frame and your wheels should be a little wider than the cart and strong enough to hold your truck.
  19. Sep 27, 2019 at 11:53 AM
    KENNY
    KENNY Well-Known Member
  20. Sep 27, 2019 at 4:43 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Seen this at Harbor Freight, clean truck
    lupard, StayinStock, JennJenn and 6 others like this.
Thread Status:
