Bigger filter on oil change?
Discussion in 'Performance and Tuning' started by Duck760, Mar 27, 2010.
  1. Apr 23, 2010 at 8:37 AM
    Workman
    Workman Well-Known Member
    06 access cab, off road, V6
    I used the ones I got at the dealership while buying spark plugs. The filters were about five dollars so I figured WTH.
    As far as fram goes, I used a ph8a on my 92 F150 for 80K, no oil related issues. Uncle uses a ph8a on his 88 Ranger and has for the last 280K:eek: DONT believe everything you see on You Tube/internet.
  2. Apr 23, 2010 at 11:12 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    are the K&N filters reusable like the air filters?
  3. Apr 23, 2010 at 2:32 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    No.
  4. Apr 24, 2010 at 4:53 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Hey: be really REALLY careful about swapping filters! It's not just a question of threads and seals matching up.
    Older engines used bypass filters: they bypass a portion of the oil from the filter in normal operation, all the time. I'm not sure if PH8A is bypass or a full-flow design (nor what Toyo expects) but I DO know I used them on my '68 Mustang! They were the standard for Fords throughout the 60's, probably their first filter when they went to cartridge designs.
    Also even full-flow filters may have a bypass to let oil flow if back-pressure across the media builds up. If the PH8A is too low vs. Toyo's design specification then it could open up on cold starts when oil is thicker; maybe even all the time if the engine operating pressure is higher than what it was designed for. If you have access to a Fram book, compare specs for both the PH8A and the stock fitment filter, paying close attention to bypass designs and pressures!
    As far as Fram's go I've prolly got 2 million miles on Fram filters, in 7 or 8 cars/trucks in all kinds of driving conditions. Never a problem, can't argue success and I'd recommend them to anyone, but the PH8A was not designed expecting more than 3-4K drain intervals so I wouldn't suggest going beyond that. However, nothing says you can't change the filter at 3-4k and top up the oil, which is a very good thing as it refreshes the additive package and lets you go even longer before a full oil change!
