bigger gas tank
Discussion in '2nd Gen. Tacomas (2005-2015)' started by j1999t, Jul 29, 2009.
  1. Jul 30, 2009 at 12:29 AM
    slooowr6
    slooowr6 Member
    5gal is roughly ~45lbs. 60gal is ~540lbs. :D
  2. Jul 30, 2009 at 1:21 AM
    TACOMAN22
    TACOMAN22 Well-Known Member
    agoura hills
    Debadged TRD offroad, bhlm, black surround grill,
    K&N drop in air filter,flowmaster 40 series, blue interior neon, bhlm, color matched grill, alpine head unit w/ infinity reference series speakers, insane driver.....
    What? i never knew 5 gallons weighs less he 60 GALLONS.......
  3. Jul 30, 2009 at 1:47 AM
    tacoholic
    tacoholic Well-Known Member
    East Bay, CA
    Has he ever put gas in the tank??? :rolleyes:
  4. Jul 30, 2009 at 4:59 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Provided you could still get 20 mpg with an extra 500lbs or so
    I think you are a little high...Density for gas is about 6.073 lbs/gallon so about 30 lbs for 5 gals and about 360 and change for 60 gals.
  5. Jul 30, 2009 at 7:24 AM
    4getful
    4getful Senior Junior Member In Training
    Dan
    Gilbert, AZ
    09 DCLB 4X4
    6" Pro-Comp Stage 2, 35x12.50x20 ProComp Xtreme All Terrain, 20" KMC Revolvers, 4.88 Gears, Banks Exhaust De-Badged
    This however, would only be true if the outside temp is below 90 degrees f with a humidity lower than 80%!! If these are both higher then you would have to add .4893 per gallon x that by 1.5575 per degree over 90 / .0094 percent over 80 to get your true weight. If you have an aluminum tank that is exposed you have to factor in the heat that the tank would produce!! THEREFORE, HENCEFORTH, AND TO CONCLUDE I REALLY HAVE NO IDEA WHAT I AM TALKIN BOUT! LOL!I am just kidding with you! I gotta give you props for knowing the density of gas.
  6. Jul 30, 2009 at 7:32 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Well, technically it is filled with gas... 78% nitrogen, 21% oxygen, 0.9% argon, and 0.03% carbon dioxide with very small percentages of other elements. Now it's time to fill it with fuel!
  7. Jul 30, 2009 at 7:33 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I would take the props...but I only know that because JP-5 is about 6.8 lbs/gallon...and I know jet fuel is heavier...but I didn't think it was by that much...so I google fu'd it.
  8. Aug 2, 2009 at 4:58 PM
    tacoholic
    East Bay, CA
    :rofl: :rofl: That was really funny! :laugh: :rofl:
  9. Aug 2, 2009 at 5:48 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    :DWarning: increasing fuel tank to 40 gallons will provoke toyota into doin a 5 spring t.s.b. with more yellow stickers!
