Bigger oil filter better?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andbeyond, Jan 3, 2018.
  1. Jan 4, 2018 at 7:40 PM
    #41
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Another great reason to stay the hell away from fram.
    If you like the grippy texture though try your favorite size flavor in purolator Pure One, they have a yellow grippy "300grit" like powder coating on them. :thumbsup:
    Personally I never understood why filters needed nuts and grippy bits, use fresh clean oil to lubricate the o-ring, run the filter down till the gasket touches all around, do 1 1/2-2 full turns then 1/4 turn counter clockwise to ensure the seal is flat not pulled and you're done, filters should be able to easily removed with your non dominate hand. You should be able to see space between the filter reciver base and filter body itself, usually 1/32 -1/16 of an inch.
  2. Jan 4, 2018 at 9:47 PM
    #42
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    My knowledge is limited, but Wikipedia says the S65 "Uses a wet-sump lubrication system with two electrically operated scavenging pumps and a main oil pump replaces the three-pump wet-sump system used on the V10.". I know Porsche racing engines like the flat six in the 911 GT3 use a dry-sump with an external oil reservoir system and many scavenging oil pumps, so no matter how fast and how extreme you drive it, you'll always have oil. Extraordinary engineering, 500hp from a naturally aspirated six cylinder. Maybe the BMW S65 uses wet-sump lubrication with additional scavenging pumps for improved performance? Cool stuff...
    Key-Rei[QUOTED] likes this.
  3. Jan 5, 2018 at 1:12 AM
    #43
    Key-Rei
    Key
    Florida
    Huh, well I'll have to look into it then! :thumbsup:
    JoefromPTC[QUOTED] likes this.
  4. Jan 5, 2018 at 1:51 AM
    #44
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Oil/filter threads are awesome! :bananadance:
    TacoMeSir, Torspd and TomTwo like this.
  5. Jan 5, 2018 at 5:07 AM
    #45
    TacoMeSir
    TacoMeSir WiFi Guru
    Tim
    North GA
    2024 TRD Off-Road Hybrid Premium
    Stock
    That is one purdy motor for 200k! Nice! Mine just busted 140k and runs like a top and is my daily driver for the time being. I just love me some Toyota!
  6. Jan 5, 2018 at 5:18 AM
    #46
    TacoMeSir
    TacoMeSir WiFi Guru
    Tim
    North GA
    Stock
    The S65 does indeed use 2 scavenging pumps. They are electric and do an amazing job under hard cornering w/ track tires keeping that car glued to the ground. It pulls some G's and I would imagine that the oil system would be starved if not for these.
  7. Jan 5, 2018 at 4:24 PM
    #47
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I ran it once with 0w30. It burned the entire qrt of mmo. Haven’t used it since.
  8. May 19, 2019 at 3:56 PM
    #48
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    just ordered two 51515 XP's
    :bowdown:
  9. May 19, 2019 at 4:02 PM
    #49
    saugus
    saugus Well-Known Member
  10. May 19, 2019 at 4:06 PM
    #50
    Armed in Utah
    2003 Lexus LX 470
    I still use the OEM 'Yota filters......
    but I'm sure the Wix XP will work well too......
    have two 4.0L Tacos......pic...the '05
    B4 the 5100's....
    TheDevilYouLove likes this.
  11. May 19, 2019 at 6:38 PM
    #51
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    Just FYI - if you are using the common yzzd3 filter you are using an “oversized” filter anyway. The yzzd1 is what came stock.
    See the recommended fram size 3614 vs the oversized 3600.
    Same same.
    hdn4space likes this.
  12. May 20, 2019 at 1:31 AM
    #52
    HillJackJDS
    HillJackJDS Well-Known Member
    Dale
    2008 Tacoma 4WD
    I am subbing to read more later!
  13. May 20, 2019 at 5:56 AM
    #53
    vtdog
    vtdog Well-Known Member
    NH
    A $ 23 oil filter? At that price you better get a hand job (a least) when you screw it in. I buy Toyota OEM filters on the web for about $ 5. That means I could change the filter 4 times during the 5,000 mile change interval and still be ahead cost wise.
  14. May 20, 2019 at 6:07 AM
    #54
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    they buy $23 oil filters and change the oil every 5k miles is a crackpot idea,
  15. May 20, 2019 at 8:31 AM
    #55
    Armed in Utah
    2003 Lexus LX 470
    $6.75 for the Wix XP 51515 yesterday
  16. May 20, 2019 at 9:05 AM
    #56
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I can't wait to retire out there
    Armed in Utah[QUOTED] likes this.
  17. May 20, 2019 at 12:44 PM
    #57
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I guess it depends on your reason for wanting a larger filter. If you are following recommended service intervals with recommended oil, there is no need for a larger filter. But it sounds like you found some really cheap and want to save some money, so... generally if all the specs are the same as the original filter (thread size/pitch, ADBV yes/no, bypass pressure, filtration efficiency, etc), and it fits the mount without interfering with any suspension movement or anything else, and doesn't stick out too far and be vulnerable to damage... yes it's OK to use an oversize filter. Lots of people run oversize filters with upgraded oils in order to safely run longer oil change intervals, I'm doing this already. Keep in mind that oil filters are generally designed with some "headspace" (additional capacity) for those times when the maintenance can't be done exactly on time.
    vanhap likes this.
