bigger replacement tires for my stock 06 tacoma
Discussion in 'Wheels & Tires' started by kohan25, Jun 15, 2009.
  1. Jun 15, 2009 at 6:24 AM
    kohan25
    kohan25 [OP] Active Member
    06 TACOMA SR5 4X4 TRD Speedway Blue
    lebra tonneau cover, avs bugshield, firefighter goober lights, custom stereo/scanner install
    I hate to ask this question since I have read so many posts about tires for a stock Tacoma but I will make mine a little more specific.
    I have an 06 Tacoma double cab, TRD 4x4, all stock. Original tires were 265/70/16. I read the biggest tire you can switch to without rubbing is 265/75/16 and that is what I would like to do. I cant really afford BFG all terrains so I was going with General Grabber AT2's. I wanted to make sure these will fit without rubbing as I read in one of the posts that different tires with aggressive tread patterns may rub even if they are the same size. Can anyone tell me if they are using these tires in this size. Thanks.
  2. Jun 15, 2009 at 6:25 AM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    I'm not personally but I'm sure there are a few on these boards that are running those tires stock with no problem.
    265/75/16 you should be safe regardless of what you get. :D
  3. Jun 15, 2009 at 6:28 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  4. Jun 15, 2009 at 7:09 AM
    kohan25
    Thanks for the quick replies. I did find the tire calculator after I wrote the question and it helped. I am going with it.
  5. Jun 16, 2009 at 7:06 AM
    kohan25
    Ok last question before I buy this Friday.
    When I explained to the tire dealer I wanted to bump up a size from my stock 265/70/16's to 265/75/16's and picked the General grabber at2's, he told me the stock tire is a 4 ply standard load compatable with my truck. the 75's are a 10 ply light truck tire and a 1/2" skinnier than the 70's which he told me would ride rough like a truck and sound loud. He really tried to discourage me from getting these tires. Is he right? Wouldnt a 10 ply be better? Will there be that much of a difference. Sound doesnt bother me as much as the ride.
  6. Jun 16, 2009 at 12:12 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    Bilstein 5100 CO's @ 1.75" - Icon UCA's - TSB Rear w/Bilstein 5100's - Air Lift System - Flowmaster 50 Duals(RIP...back to stock for now) - Avid Offroad Arctic Bar - Avid Offroad Nerf Bars - Leer 550 Bedcover - AVS Hood Protector(RIP) - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    He's generally right and I say generally because I haven't run those tires before. That tire is probably about 10 lbs heavier too which is all rolling weight and specced for mostly 3/4 and 1 ton trucks. Not necessary for Toyota trucks.
  7. Jun 17, 2009 at 7:12 AM
    kohan25
    Thanks. I am going with stock size for now and maybe think about bigger/different brand again when due for tires next time
  8. Jun 19, 2009 at 12:45 AM
    Black Rock Taco
    Black Rock Taco Well-Known Member
    Winnemucca and Reno, NV, Oakland CA
    2011 DBL Cab Tundra
    None, yet
    I live in rural Northern Nevada. I will not run anything less than an 8 ply rating on anything. Even a little Suzuki Samurai. Out here, in the Wild West, more plies will give you rock cut and puncture resistance. Otherwise, one will need to drive the local dirt roads excruciatingly slow. So the answer to plies needed for you truck is a function of where you live, and how/where you drive.
