Bigger rims and fuel economy?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1killerkaw, Jun 5, 2008.
  1. Jun 5, 2008 at 12:33 PM
    1killerkaw
    1killerkaw [OP] Well-Known Member
    08 Silver DC LB SR5 4x4 Tow Pkg.
    Pop-N-Lock, AFE OE Replacement Pro Dry S, 20% tint all the way around, 6000k Bi-Xenon HIDs, 3" Dynomax super turbo muffler, ATC LED Limited campershell, Bedrug, Suspension TSB.
    For those that have put bigger aftermarket rims on without lifting the truck, how much did your fuel economy change?
  2. Jun 5, 2008 at 12:51 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. Custom dents.
    I wouldn't think that getting a larger rim would aid in fuel economy. Unless you go to a shorter in over all height tire. Say going from a 30.6 to 28" tall. Even going to an aluminum rim of less weight I don't see it saving any fuel. Thats just my 2 cents.
  3. Jun 5, 2008 at 3:30 PM
    1killerkaw
    I realize that. My question is, the people that have gone with bigger aftermarket rims, how much mileage did you lose?
  4. Jun 6, 2008 at 6:18 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Ok sorry I missunderstood. I went from 16" to 17" wheels and from a 30.6" tire to a 33" and my mileage is has droped less than 1mpg.
  5. Jun 6, 2008 at 7:33 AM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    remember the larger tire... say from stock to a 33" you Speedo/Odo will be off by about 7%.
    Which means you are actually going 7% faster/farther than the speedo shows.
    (I don't think that i lost anything noticable after my lift)
    The rim might actualy aide in better milage if it is lighter than the OEM with the same tire size...
    hope this helps..
  6. Jun 6, 2008 at 9:34 AM
    CrashTest
    CrashTest Member
    2008 Access Cab V6 MT TRD Offroad
    WARNING!! Science Lesson
    Bigger doesn't necessarily matter. It depends on the wheel's Moment of Inertia(MOI). In rotational motion, the MOI is the analogue to weight for linear motion. Just like the smaller weight requires less force to push it in a straight line , the smaller MOI is requires less torque to set it spinning.
    The closer to the center of the wheel that the weight is concentrated, the lower your MOI and vice versa. You can in theory have a bigger wheel with a lower MOI than a smaller wheel of the same weight. Lighter materials, the design of the wheel, and the tire all affect the total MOI your engine has to deal with.
    In very general terms, increasing total tire radius will negatively affect fuel economy. Increasing wheel size and keeping tire size the same depends on the change in weight distribution and is very hard to determine without MOI numbers.
  7. Jun 6, 2008 at 4:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This is very good! But, given that the bulk of the weight is the tire, and the outside of the rim, seems very unlikely that you could achive a lower MOI with a larger rim. :)
  8. Jun 6, 2008 at 5:58 PM
    CrashTest
    CrashTest Member
    Agreed. Which is why I threw Not to mention, wheels meant for trucks aren't exactly known for their low MOI road racing qualities. You are either going for strength to handle off-road environments or a whole bunch of bling. :p
  9. Jun 6, 2008 at 6:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :thumbsup:
