Bigger Tires for my 5 lug
Discussion in '5 Lug' started by justinh384, Nov 4, 2013.
  1. Nov 4, 2013 at 10:29 AM
    justinh384
    justinh384 [OP] Active Member
    Justin
    Wrightsville, GA
    2009 Tacoma reg cab 5 lug
    I have a 2009 Tacoma reg cab 5 lugger. My stock tires are beginning to wear out. I was just wondering what issues there are with 235/75r15s for my truck. I would also like some tire recommendations and would like to see pics of 5 lugs with that size tire on them. The tires that I'm getting do not have to be an aggressive all terrain tire, but I'm not throwing that option out of the window.
  2. Nov 4, 2013 at 8:33 PM
    Mr.Schertz
    Mr.Schertz Well-Known Member
    TEXAS
    08 single cab 4banger
    tint,removed badges,custom letter chop and rephrase
    im very pleased with the 235's that I put on. it will affect your highway speeds over 70mph. It seems to bog down a little bit when giving it gas at speeds over 70mph.
  3. Nov 5, 2013 at 6:28 AM
    jtye
    jtye Well-Known Member
    DC
    08 Super White 5 lug
    Fog lights, fatbob's 5lug lift, Cragar 15x7, 31x10.5 Gen.Grabbers, Wet Okole
    Goodyear wraglers, good cheap tire. Still get just over 25 MPG, smoother ride. Really no reason not too...except i want to go bigger now...
  4. Nov 13, 2013 at 1:00 PM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    you can run up to a 31 on stock rims without spacers and rub only a slight bit. After that size you need more offset on the rim and a lift.
