Bigger tires on 2012 i4
Discussion in 'Wheels & Tires' started by comerzz, Jan 23, 2025.
  1. Jan 23, 2025 at 8:04 PM
    comerzz
    comerzz [OP] New Member
    Hey Guys!
    Looking to upgrade my tire size on my 2012 2.7L.
    Currently on 265/70/16. Whats the biggest I can run? Whats recommended?
    looking to do 32s or 33s
  2. Jan 23, 2025 at 8:06 PM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    255/85/16
  3. Jan 29, 2025 at 3:16 PM
    RonMx18
    RonMx18 Active Member
    Ron
    2012 Tacoma access cab 4x4 V6 6 spd man.
    Eibach pro coil overs set at 3", General Spring 3+1 rear leaf pack, Eibach extended rear shocks, Freedom Offroad Upper & lower Control arms.
    i just measured my 265/70R16 spare & its just about 30.5" tall mounted & weigh's in at 62lbs on a steelie, So it depends on how much room you have from center of "hub" to the fender well as the 255/80R16 mentioned above will be taller but thinner. You will have to measure or hope a local tire shop will give you input on this question but what ever you do stick with a "P"- metric tire NOT an "LT" 10-15lbs heavier per tire & your stock wheels are heavy enuf already (if steelies) and with yor 2.7L i doubt you wud be happy with the performance with anything bigger. IF you ever end up in "Amish country" you'll be pissed when the horse & buggy Amish are passing you on the highway & you got the pedal to the floor.
    The "pizza cutter" may be your 1 & only option .....
  4. Jan 29, 2025 at 3:39 PM
    OLDTRAP
    OLDTRAP Well-Known Member
    2021 TRD OR
    Stock
    Lift it 4 inches and put 34s. Buckshot Mudders. Do it.
  5. Feb 2, 2025 at 10:14 AM
    RonMx18
    Ron
    I like yor thinking !!! but he didnt mention lifting it so i took it as leaving it stock.
  6. Feb 2, 2025 at 10:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    Define 'bigger'. Width, diameter, both?
    Is this for looks or function? If function, what are you solving?
    Do you care about MPG?
    How much more sluggish do you want to make It?
    Are you willing to drop a few large to re gear?
