Bigger tires, thoughts and input.
Discussion in 'Technical Chat' started by BohlaaH, Jan 11, 2016.
  1. Jan 11, 2016 at 11:32 AM
    BohlaaH
    BohlaaH [OP] Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    I have the 6" bds drop bracket lift with the fox coilovers Before you go off on my lift, I live in Canada so long travel is not if full use here. Anyways I want to run a larger size tire next time around. I am running 35x12.5 right now I will be putting on glass fenders and bedsides in the spring along with front and rear high clear bumpers by all-pro. Wondering what you have done to clear larger tires. I have flattened my pinch welds, trimmed the fenders, cut the cab mount(looking for more information on this, I am thinking of using 3-4 inch pipe to make the cab mount as small as possible). Let me know how far you have gone to get your tires as large as possible. I have 4.88 gears FYI.
  2. Jan 11, 2016 at 7:41 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Just continue to hammer, cut, burn, smash, whatever the tire hits.
  3. Jan 12, 2016 at 9:45 AM
    BohlaaH
    ALEX
    2015 TRD Sport DCLB
    the problem will be the cab mount mainly. any specs on how to fab a relocate bracket? I know a highly skilled welder who can make it up, or what did you do to eliminate the rubbing at full turn lock?
  4. Jan 12, 2016 at 10:46 AM
    PSU Taco85
    optional
    I just cut mine back to the bushing mount, it fits 36s full stuff
  5. Jan 12, 2016 at 10:53 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  6. Jan 12, 2016 at 11:20 AM
    BohlaaH
    ALEX
    2015 TRD Sport DCLB
    that's what I have done so far and need more... thinking of building a relocate bracket
  7. Jan 12, 2016 at 11:21 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  8. Jan 12, 2016 at 11:24 AM
    BohlaaH
    ALEX
    2015 TRD Sport DCLB
    will he see that or should I PM him?
  9. Jan 12, 2016 at 9:31 PM
    PSU Taco85
    optional
  10. Jan 13, 2016 at 7:51 AM
    BohlaaH
    ALEX
    2015 TRD Sport DCLB
    im not buying those I have some made, easiest thing to do. But I need more room, which is why I need ahe relocate bracket. Then I can do 37s in the future if the mount is moved. Good advice on not buying those tho. Know any members who did a relocate? or with some decent pictures of the bracket so I can steal the design?
