bigger tires
Discussion in 'Wheels & Tires' started by TacomaHog, Oct 9, 2012.
  1. Oct 9, 2012 at 10:52 AM
    TacomaHog
    TacomaHog [OP] Well-Known Member
    Tom
    New York
    2009 TRD OFF ROAD
    After market stereo with GPS and 10in subs and amp
    i just recently purchased 35 in dick cepek crushers but only have a 3in lift. will i be able to use these tires with out running into any problems. and if so what could i do to get around this without going with a larger lift?
  2. Oct 9, 2012 at 10:54 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Your going to have to do some major trimming and cutting to fit 35"s on a 3" lift. Even with a 6" lift you have to do some moderate trimming. :eek:
  3. Oct 9, 2012 at 11:06 AM
    TacomaHog
    Tom
    New York
    2009 TRD OFF ROAD
    ok cool. i have no problem trimming. are there any stickies with the diy instructions on trimming?
  4. Oct 9, 2012 at 11:59 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Not sure. Try doing a search on here but I believe you have to do a cab mount chop which gets pretty technical if I'm not mistaken.
  5. Oct 9, 2012 at 12:02 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    yep you will have to do it, i think most do it even with 33”s also i think you have to bend some of the inner fender, but i’m 100% not sure on that.
  6. Oct 9, 2012 at 12:05 PM
    rockgecko03
    rockgecko03 Well-Known Member
    Ben
    Rockwall, TX
    2000 4runner
    The best way to trim for 35's is to take your coil over out and cycle the suspension and cut everything out that the tire touches. Go ahead and remove the fender liners, beat back the pinch welds, and chop the cab mounts as there's no way you're going to get around doing those. As far as I know, there is not a "cut on the dotted line" template to tell you where to cut.
    EDIT:
    Also, what kind of wheels are you running? If you don't have the right backspacing, you'll need some spacers to keep the tire from rubbing your UCA and framerail.
  7. Oct 9, 2012 at 5:18 PM
    TacomaHog
    Tom
    New York
    2009 TRD OFF ROAD
    i dont have the wheels yet. but i will be making sure i have the proper backspacing. and thanks for the info its helpfull and much appreciated
  8. Oct 9, 2012 at 5:22 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The only 2nd gens I've seen running 35s on 3" of lift have an aftermarket front bumper, and have had to cut their fenders. Not the fender lining, the actual metal fender.
    RelentlessTaco and jhodge83 come to mind
  9. Oct 10, 2012 at 6:27 AM
    rockgecko03
    Ben
    Rockwall, TX
    2000 4runner
    There's also a couple of us who just installed a 1" body lift. The only metal I trimmed to clear 35s was near the firewall and it wasn't that much. I didn' even remove the fender flares. In order to beat back the pinch weld, you have to remove the fender liner as it covering the pinch weld. You may be able to just cut it and only remove the liner near the firewall, but I took mine out since it was really flimsy plastic and wouldn't be supported anymore. I didn't want it flopping around and getting ripped out by the tires.
  10. Nov 7, 2012 at 9:17 AM
    TacomaHog
    Tom
    New York
    2009 TRD OFF ROAD
    alright thanks for the input. im going to have some time cuz it is winter now and i am not going to be spending anymore time outside than i need to. northern new york SUCKS.
  11. Nov 7, 2012 at 9:29 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    i trade you? lol. i LOVE western NY winters! i just love winter all together!
