Bigger tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacotrd19, Dec 22, 2019.
  1. Dec 22, 2019 at 11:06 PM
    Tacotrd19
    Tacotrd19 [OP] Active Member
    2019 Tacoma TRD Offroad
    Hey guys, I have a 2019 trd off road. I want to put a 3 and 2 lift on it and run 285/7516 tires with the stock wheels. I'm told that the tires will rub the UCA's. Is this true? Will spacers work?
  2. Dec 23, 2019 at 1:45 AM
    TacoMoose
    TacoMoose Well-Known Member
    2017 Tacoma OR
    with 0 offset wheels you wont rub, but if you have -10 or more then it will rub. so if you plan on running -10 offset or more, you will need spacers
  3. Dec 23, 2019 at 7:01 AM
    Tacotrd19
    Thank you for the advice.
    TacoMoose likes this.
  4. Dec 23, 2019 at 7:54 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Your stock OR wheels are +25 mm offset. An 1" wheel spacer will bring you to, same as 0 offset wheel. If that's what your looking for in a answer.
