Bigger wheels for a 6” lift?
Discussion in 'New Members' started by tacoguy117, Jul 25, 2018.
  1. Jul 25, 2018 at 7:00 PM
    tacoguy117
    tacoguy117 [OP] Active Member
    Nathan
    2013 Black TRD 4x4
    Flowmaster Dual Side Exit Exhaust S&B Cold Air Intake Armordillo Grille Guard Bolted fender flares Smoked Projector Lenses LED smoked taillights & 3rd brake light N-Fab step rails Powder coated 4Runner wheels 3” Icon coil-over suspension lift
    im a newbie when it comes to lift installations, so I’m not gonna sound like I know a whole lot lol and pardon my ignorance. If I am considering a 6” lift with lifted struts instead of just adding blocks on OEM ones, am I going to have to get larger wheels? I’m also thinking about adding 1.5” hub centric spacers. I have R17’s.. but the stock wheels are R15’s I believe. I’m only asking because they’re powder coated and I’d hate to see them go bye bye lol. I’ve seen a few people with 17” wheels with 6” lifts just fine.. The recommended wheel and tire size for my lift is listed at 33x12.5 R-17 but just wondering on here to be sure. I just got new tires and they sit an inch taller above the ones that My truck Had prior but still had the 17” wheels. Thanks!
  2. Jul 25, 2018 at 10:21 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    First of all,if you want a 6 inch lift you will need a drop bracket lift. Secondly wheel size may vary from lift to lift. I have a R/C 4 inch D/B lift which I have 17 inch wheels and a Zone 4 inch lift requires 18 inch wheels.If I was gonna put a 6 inch lift on my truck I would put 35 inch tires on it.
    BassAckwards likes this.
  3. Jul 25, 2018 at 10:25 PM
    Bishop84
    Bishop84 Well-Known Member
    17's can fit but they always suggest 18's to clear the new knuckle. Spacers would probably help but I've never tried it on a 6" lift.
    The new TRD Sport 17's are actually smaller in the drum and contact easier than prior gens, so it depends on wheels and other factors.
  4. Jul 26, 2018 at 3:01 AM
    tacoguy117
    Nathan
    2013 Black TRD 4x4
    I was looking at the R/C 6” lift kit with the N3 struts added, instead of using the strut spacers. But I’ve also read a lot about lifts for R/C and some people are saying 4” is a max and 6” is pushing it when it comes to Tacomas
  5. Jul 26, 2018 at 3:29 AM
    tacoguy117
    Nathan
    2013 Black TRD 4x4
    It says on the recommended specs “33x12.5 R17”.. and my current tire and wheel setup is 31.6x10.4 R17” and I’m just wondering now if the tire thickness and width would be enough
  6. Jul 26, 2018 at 3:56 AM
    buckhuntin-tacoma
    Dennis
    Quincy IL
    4 and 6 inch lifts are ok as long as you do a drop bracket...otherwise 3 inches is pretty much the limit without jacking up your angles. The D/B will keep your angles true, however the D/B is probably not the way to go if you’re gonna do a lot of serious off-roading.
  7. Jul 26, 2018 at 4:55 AM
    tacoguy117
    Nathan
    2013 Black TRD 4x4
    Thank you for the information. You said you have a R/C lift kit, right? Are the struts made of steel or aluminum? Just wondering because I’ve seen them rust sometimes on other people’s vehicles and I’m curious if they’ve switched their design
  8. Jul 26, 2018 at 6:45 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
