Biggest 17 inch tire with 3 inch lift
Discussion in 'Wheels & Tires' started by Gloade16, Mar 15, 2013.
  1. Jan 31, 2015 at 5:48 AM
    Redbeard7050
    Redbeard7050 New Member
    Florida
    2015 pre runner 4x4
    What does CMC mean?
  2. Jan 31, 2015 at 6:00 AM
    DirtyTerp
    DirtyTerp Well-Known Member
    Randy
    Freeland, MD
    '14 DCSB MGM
    Cab Mount Chop, You cut back the cab mount to prevent your tires from rubbing on it.
  3. Feb 1, 2015 at 1:41 PM
    LBCdan
    LBCdan TACO --> TUNDRA
    Dan
    Long Beach , CA
    2018 Tundra CM 4x4
    Toytec Coilovers, TotalChaos UCA, Icon w/ Resi, Toytec Lift Shackle, Methods w/ 285/75/18 Tires.
    2012 TRD Sport PreRunner DCSB Bilstein 5100. OME 885. Wheelers 1.5" AAL : 285/70/17 Terra Grappler G2 w/ Method Standard 17x8.5 4.5"BS - no rubbing with mudflaps removed. Now... i havent had them offroad yet so I am sure I will rub with some major flexing..
  4. Feb 5, 2015 at 6:43 AM
    Jose627493
    Jose627493 Member
    Jose
    Texas
    2012 Tacoma prerunner
  5. Oct 21, 2015 at 6:38 AM
    2014tacom
    2014tacom Member
    2014 Tacoma Prerunner v6 2 wheel rwd
    how big of a tire can i run w/o a lift that won't rub? 265? 255? on 17s
  6. Oct 22, 2015 at 10:08 AM
    PUBCRAWL
    PUBCRAWL MIGHTY TACO
    Ontario, Canada
    Tacoma TRD DCLB
    275 / 70-R17 without a lift and stock wheels.
  7. Feb 7, 2018 at 6:06 PM
    BigZ17
    BigZ17 Member
    2006 Tacoma
    3 inch lift
    I’m running 295 70 r17 on a 3 inch lift and had to only trim plastic. I have a little over a 1/4 inch of space from the cab mount at any point of wheel lock or turning wheel. Get through mud holes just fine where I live and trails in Uwharrie. At full flex in my suspension I will run but most people with stock bumpers will. I don’t get why people panic so much about CMC especially on a daily driver. Don’t let these people scare you away I’ve been running this setup for a while now absolutely no issues. If you don’t plan on going off-road you literally have nothing to worry about. And if you do have to or decide to get a CMC it’s not an issue to get done just don’t think you HAVE to get this done to run 285s or 295s as long as you stay below 75 aspect ratio.
  8. Aug 7, 2018 at 1:39 PM
    cook-off
    cook-off Member
    3in lift, stock wheels running 255/75x17, I was going to go for the 285s but gave up on the .75 of an inch taller and 1 in less width to make sure I didn't have any rubbing issues at all.
  9. Aug 7, 2018 at 2:12 PM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Do you mind posting a pic? I've got a 2 inch lift on my longbed and am considering that size for my next set of tires. Current size is 265/70/17 and want to go just a little bigger.
  10. Aug 8, 2018 at 10:08 PM
    cook-off
    cook-off Member
  11. Dec 22, 2018 at 5:39 PM
    KenTRDSport18
    KenTRDSport18 New Member
    Khang
    2018 Tacoma TRD Sport extended Bed
    2018 Tacoma TRD Sport 3” lifted , Nitto Ridge Grappler 285x70R17 and 17x9 wheels I only needed to take off front mudguards and it barely rubbed but I trimmed about haft inch of plastic off on both front driver and passenger side to make sure it 100% clear
