Biggest/beefiest tire rim combo on a stock suspension 2nd gen?
Discussion in 'Wheels & Tires' started by igoldin74, Jun 7, 2022.
  1. Jun 7, 2022 at 4:05 PM
    igoldin74
    igoldin74 [OP] Member
    So the subject pretty much sums it up what is the biggest setup i can safely run on a stock suspension 2nd gen trd sport taco?
  2. Jun 7, 2022 at 4:12 PM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    depends what you're using it for, and how much you might be willing to cut from the fender/cab mount.
    there's endless threads on this exact question, I believe completely stock without any modification is 265/75/16. might be 265/70
    igoldin74[OP] likes this.
  3. Jun 7, 2022 at 4:18 PM
    igoldin74
    It would be 95% on road usage and I am not willing to cut anything
  4. Jun 14, 2022 at 11:38 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    265/75R16 or 265/70R17 would be the largest you could safely running without needing to modify anything, that being said, if you have stock mudflaps you may need to remove them as the corner of the tire could catch at full lock.
