biggest over all diameter...no lift..
Discussion in 'Wheels & Tires' started by freesample, Feb 10, 2009.
  1. Feb 10, 2009 at 5:40 AM
    freesample
    freesample [OP] Well-Known Member
    Newfoundland, Canada
    09 Tacoma Double Cab TRD Sport LB
    Visors, Deflector, Husky Liners, too expsensive for good ones :(
    quick question... what the biggest over all diameter i can go with with no lift? should i keep it same as stock with my 265 65 17 on 17 rim and then go with a 285 65 16 or a 265 70 16? or can i go bigger?
  2. Feb 10, 2009 at 6:35 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How wide are your rims?
  3. Feb 10, 2009 at 6:40 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Generally speaking: 265/75/16... but it depends on some stuff...
  4. Feb 10, 2009 at 6:47 AM
    freesample
    um 9 or 9.5 i think.. what ever is stock...buut i'm looking at getting some new rims when i downsize to 16in for my not winter tires... im leaving my winter tires on the stock 17s
  5. Feb 10, 2009 at 6:50 AM
    freesample
    says to keep diameter within 3%..is this true?
  6. Feb 10, 2009 at 6:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    For a stock truck with no lift, Yes.
  7. Feb 10, 2009 at 6:52 AM
    freesample
    and with a 3 in lift i can go to what percentage?
  8. Feb 10, 2009 at 7:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    About 7%.
  9. Feb 10, 2009 at 7:21 AM
    freesample
    ooohhh ok..so once that shags up the speedo and shit...do you need to recalibrate for new tire size or jsut leave it?
  10. Feb 10, 2009 at 7:30 AM
    Janster
    Jandy
    Lancaster, PA
    For wider tires - the speedo isn't changed.
    When you get wider tires on, watch your tire pressure. You may need to run lower tires pressure to ensure proper tread wear. You can check the tread wear with chalk lines on the tread/pavement.
  11. Feb 10, 2009 at 8:30 AM
    freesample
    oh ok... didn't think it would..i'm staying with 265..just maybe changing diameter
