biggest tire i can get by with??
Discussion in 'Wheels & Tires' started by chays, Apr 18, 2012.
  1. Apr 18, 2012 at 8:31 AM
    chays
    chays [OP] Well-Known Member
    mississippi
    2005 tacoma dc 4x4,2012 tacoma trd ofr 4x4dc
    moto metals and more!!
    dont have alot of time to use computer.
    so here what i have 2007 ac cab long bed 4x4
    installing billies at 1.75 with stock coils.
    should level truck out from my measurements.
    have the stock sport chrome spoke wheels 16".
    can i get by with 285?if not what the biggest i can run?
    also what if i get aftermarket wheels,what can i get by with.
    thanx in advance for any help!!
    chays
  2. Apr 18, 2012 at 8:33 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    IF STOCK, no lift: 265/75-16... 32"... It is an inch taller than stock, and won't rub.
  3. Apr 18, 2012 at 8:37 AM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    If you have the lift at 3" with LR UCA's the 285's will fit with the off road rims w/o a spacer but you rub the front of the UCA at full lock both ways on the steering. You have about a 1/4 between the tire and the UCA at the top. If you can live with not turning all the way to lock and going to stay on the street you can probably make it. I wouldn't off road it and flex the suspension with that setup until you get spacers. UCA will hit the tire at full droop.
  4. Apr 18, 2012 at 9:54 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    You guys are forgetting to mention that he'll require rims with more backspacing to run 285's otherwise he'll be rubbing the UCA more than a horny dog on his masters leg.
  5. Apr 18, 2012 at 9:55 AM
    medic2230
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    I mentioned I was running toyota off road stock rims. But that is what is really needed to fix the problems with rubbing with flex. I'm running mine like that temporarily till my spacers get here.
  6. Apr 18, 2012 at 9:57 AM
    DrewH
    DrewH Well-Known Member
    Sport rims are 17"
  7. Apr 18, 2012 at 9:58 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I still wouldn't run it on the street with stock rims just in case.
    But yes, looking back I did notice you said you were rocking Spacers. My bad. :p
  8. Apr 18, 2012 at 10:02 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Just another FYI because I keep seeing the same people posting the same answers.... 265/70/17's on stock sport wheels can rub
    Here is the proof.....see my frame? See my LCA?
  9. Apr 18, 2012 at 6:34 PM
    go8soccer
    go8soccer Memba
    Grovetown, GA
    '08 Super White DC LB Prerunner Sport
    Leaf TSB, front Billie 5100's (1.75"), 265x70x17 BFG Rugged Terrain
    Do you have any type of lift? If you have Billies, what height are they set to?
    From what I've seen, if you have them set to 1.75+, you shouldn't have any rub with 265/70/17's
    I don't have any proof on this... yet, so feel free to prove me wrong :notsure:
  10. Apr 18, 2012 at 7:05 PM
    chays
    mississippi
    i am running 265 70 17 on a 2012 with no lift at all.
    just would like to run 285 on this truck.
    chays
  11. Apr 19, 2012 at 4:36 AM
    XXXX
    sKiP
    05 Prius
    this.....
    Caster has more to do with wheel rubbing then lift and like Ant said the lift does not matter unless you adjust the bump stops
  12. Apr 19, 2012 at 4:55 AM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    I occasionally rubbed with my 265/70s too before the 5100s went in. It was very sporadic- perfect storm kinda thing.
    OP, you can also try a 275/70r17. You should fit those with little to no trouble.
  13. Apr 19, 2012 at 6:55 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    3" lift, wheel spacers, trimming of plastic, and a cab mount chop and you won't rub during normal driving with no flexing.
  14. Apr 20, 2012 at 4:46 AM
    Rainman998
    Rainman998 Well-Known Member
    "The QC" AZ
    SEXY 2010 Double Cab 4x4 TRD Off Road
    Waiting for my sugar mama to hook it up
    Perfect thread cause I'm needing new tires. I'm thinking of going 265-75-16's on my off road. Hopefully they won't rub
