Biggest Tire on 07 TRD Sport
Discussion in 'Wheels & Tires' started by gb1194, Oct 14, 2009.
  1. Nov 29, 2011 at 1:11 PM
    #201
    Wombat401
    Wombat401 McFly!
    Savannah, GA
    11 Black 4x4 SpDCLB
    Weathertech mats, Antenna-X stubby, MotoMetal 957s on 265/70/R17 Nitto TGs
    It's a 4wd sport so stuck with the limited slip
  2. Dec 10, 2011 at 5:48 AM
    #202
    wrench91
    wrench91 New Member
    Larry
    KY
    12 tacoma trd sport
    What are TSB Leaf????
  3. Dec 10, 2011 at 7:30 AM
    #203
    Blkturbo!
    Blkturbo! Well-Known Member
    Sean
    Henderson, NV
    08 Tacoma; 05 Seadoo RXP; 94 Turbo Supra
    Icon Coilovers, Downsouth UCAs, rear Icon "2.5" shocks and Toytec single AAL. Still gotta do exhaust, dark headlights and re-gear the rear diff.
    It stands for Toyota Service Bulletin - as in, a toyota recall on the rear suspension/leaf pack. Having the TSB service done apparently gives the truck a little boost in height, as with adding any aftermarket lifting leaf for the rear.
    Ive never had the TSB done...only a Toytec AAL.
  4. Jan 8, 2012 at 8:32 AM
    #204
    hakabo
    hakabo Well-Known Member
    Jacob
    Concord, NC
    08 urban runner 4x4
    These do fit on my 2007 w/out rubbing. have not gone offroad yet, but numerous steering locks in and out of driveways...
  5. Jan 22, 2012 at 11:05 PM
    #205
    bfred13
    bfred13 Member
    brittany
    04 tacoma trd
    Lift
    We had 265.75.16 on our truck and it rubbed bad when we turned sharp
  6. Jan 24, 2012 at 1:24 PM
    #206
    Royce99
    Royce99 Taco Samurai
    Royce
    Houston
    2012 MGM Prerunner SR5 Debadged
    Just getting started.
    Hey Everybody...I just bought some Moto Metal 951's mounted with 285-70-17 tires. I'm not sure if I should go with a leveling kit or a full 3 inch lift. If any of you have advice or pics of a similiar set-up it would be much appreciated!
    2012 SR5 Prerunner
  7. Jan 24, 2012 at 1:28 PM
    #207
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    As a general rule you should avoid leveling kits (spacer lifts) because they can lead to a harsh ride and/or damage you ball joints. And to fit the 285-70's the closer to get to 3" the better of you will be.
    Hopefully the wheels you bought have 4.5" of backspacing?
  8. Jan 25, 2012 at 3:47 AM
    #208
    Royce99
    Royce
    Houston
    @KPT...The wheels are Moto Metal 951. 4.5 backspace and -12 offset. Mounted on Falken Wildpeak a/t.
    Thanks for the advice...
  9. Jan 25, 2012 at 3:12 PM
    #209
    Yellowshark
    Yellowshark Member
    Ed
    Canada
    2012 4x4 V6 SR5
    I just bought XD series 17x9 rims and mickey thompson tires off of my buddy's TRD. I have a 4x4 SR5 double cab, and it looks like the offset is huge compared with the stock rims. I beleive the offset is 4.5" and the tires 265/70R17. do you guys know if there is a difference in the lift between the TRD and the SR5? I'd appreciate any comments on it.
  10. Jan 25, 2012 at 3:13 PM
    #210
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    both should be the same ride height
  11. Jan 25, 2012 at 3:14 PM
    #211
    johnw
    john
    orlando florida
    rim set up looks correct i would stick towards a 3" lift for the least amount of rubbing
  12. Jan 26, 2012 at 5:44 AM
    #212
    TexasTacoma37
    The 4.5" is the backspacing, not the offset. And with a 9" wide rim and 4.5" of backspacing, the wheels will stick out 3" more than stock (1" due to backspacing, and 2" due to width). Does that seem about right visually?
  13. Jan 26, 2012 at 6:59 AM
    #213
    Royce99
    Royce
    Houston
    I found a shop to do the lift, just have to make the time to leave my truck there. I wish I had the know how to do it myself!
  14. Jan 26, 2012 at 3:08 PM
    #214
    Yellowshark
    Yellowshark Member
    Ed
    Canada
    2012 4x4 V6 SR5
    Sounds about right, I will stick a spacer and check the clearance all around it, I'd hate to spend the money on tires and get stuck with them. My buddy got these tires off his TRD, I do not think his model has more than an inch or so over the SR5 model.
    Thanks for the reply.
  15. Jan 26, 2012 at 3:11 PM
    #215
    Yellowshark
    Yellowshark Member
    Ed
    Canada
    2012 4x4 V6 SR5
    The TRSD has bilstein suspension, and I can actually see a spacer between the coil and the flange. I'll do more digging and will post pics of how it looks and where it rubs when I get to it. thanks!
  16. Feb 4, 2012 at 3:19 PM
    #216
    broodtaco
    broodtaco Member
    Rick
    Fort Worth
    07 Toyota Taco Regular Cab
    31X9.5R15 Goodyear Wranglers. 15inch MB Motoring Wheels.
    I have a 2007 Regular Cab 5 Lug and I fit 31X9.5R15s on it... I think I could even go wider.... but, the 31s rub when i turn sharp. I forgot to mention the backspacing is 3.7 I believe... don't quote me on it though.
  17. Feb 12, 2012 at 2:57 PM
    #217
    db2
    db2 Well-Known Member
    2016 TRD Sport DC
    Ok, so I read through this whole thread. And I still haven't figured out my question. I'm probably just dumb. But, I'm doing a 3" lift, and I am trying to figure out if I can run a 285/70/17 on the stock TRD Rims without any other changes. Or do I need to add a backspacer? I am doing the spacer lift but don't do any offroading so I'm not too stressed about damaging anything. Any help would be appreciated! Thanks!
  18. Feb 12, 2012 at 2:58 PM
    #218
    TexasTacoma37
    Need a spacer
  19. Feb 12, 2012 at 11:01 PM
    #219
    db2
    2016 TRD Sport DC
    Wow. That was fast! Thanks! Do you know up big of an adapter? Would I need longer lug studs?
  20. Feb 13, 2012 at 6:25 AM
    #220
    TexasTacoma37
    1.25" spidertrax hub-centric spacers. They come with longer studs built in.
