Biggest Tire on 07 TRD Sport
Discussion in 'Wheels & Tires' started by gb1194, Oct 14, 2009.
  1. Jan 7, 2013 at 6:38 AM
    #281
    phantomblackgto
    phantomblackgto Well-Known Member
    Martin
    Parkville, MO
    2012 MGM TRD Sport 4x4 DCSB
    TRD exhaust, Debadged, Tacoma door sill protectors, Weathertech DFL's, Twoplankers center console organizer, Escort S2 cordless radar detector, AFE Pro Dry S air filter, Ultra Type 62 wheels 17x8 et +10 w/ 108mm - 106.1mm hubcentric rings, 265/70/17 Goodyear Wrangler Duratracs, Bilstein 5100's - front set to .85, Nfab 2" step bars w/ LineX coating
    275/60/17 is actually smaller in diameter than a 265/65/17 and about the same weight (if not even a little less). While the slightly wider stance may cause a little more rolling resistance, I'm not sure why your mileage would have went down 2 mpg. And, your speedo should only be off by about 2% (actual speed 1.2 mph less when speedo at 60 mph). Are you sure you didn't mean 275/70/17?
  2. Jan 7, 2013 at 6:42 AM
    #282
    phantomblackgto
    Martin
    Parkville, MO
    You realize those rears are almost 1/2" taller than the fronts? I noticed you have 4x4. I'm no expert, but that might not be too good on your diff when running in 4-wheel drive.
  3. Jan 8, 2013 at 6:25 AM
    #283
    henrilepuf
    henrilepuf Well-Known Member
    henri
    Northwestern Paraguay
    tacoma 2014 4x4 DCLB
    Sure, I realize that; the mechanic said there's no inconvenience.
    Moreover my use of the 4WD is restricted, only to go out of some deep mud.
    My initial idea was to fit out the truck with 4 Cooper 275/70x17, but the front wheels might rub when turning the wheels.
    Have a nice day
    Henri
  4. Jan 20, 2013 at 7:28 PM
    #284
    Sager
    Sager New Member
    Jay
    Santa Barbara
    06 PreRunner 2.7L
    I am finnally ready to replace my stock tires after 45k miles - looking at BF All Terrains. Can I replace my stock p245/75r16 tires with 17" tires and stock rims without a lift? Thanks for any help here!
  5. Jan 21, 2013 at 5:43 AM
    #285
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Yes
  6. Jan 30, 2013 at 7:01 PM
    #286
    Matt Dornak
    Matt Dornak New Member
    Texas
    08 off road trd
    I have an 08 double cab off road tacoma. Wondering
    If I can fit 285/70/17 with a 2.5" leveling kit?
  7. Jan 30, 2013 at 7:03 PM
    #287
    Matt Dornak
    Texas
    08 off road trd
    Wondering if I can fit 285/70/17 on my 08 tacoma with a 2.5" leveling kit
  8. Jan 31, 2013 at 6:15 AM
    #288
    henrilepuf
    henri
    I think it will be OK. Although it will be quite tight when you turn the front wheels, especially in off road driving.
  9. Jan 31, 2013 at 8:12 AM
    #289
    TexasTacoma37
    Wheel spacers, trimming, and a possible cab mount chop
  10. Feb 2, 2013 at 4:23 PM
    #290
    ONTHEEDGE
    ONTHEEDGE Active Member
    Nova Scotia
    2012 Tacoma TRD
    HID's, Ready Lift 3" Front 2" Blocks in Rear, Pro Comp 5182 17x9, Genral Grabber AT2 265/70 17, Weatertech Mats, Toneau , Skid Plate,
    Hi I'm a newb to the Tacoma World site, and as always am opening up with a question. I am looking at putting new wheels and tires on come spring, also going to get a Pro Comp level lift. I am thinking about going with 17x9" wheels and a 285/65/17 tire, I think this would look good, but was wondering would I have any rubbing issues with that wide of a tire and wheel with just the level lift? Also wondering I put the 160K Toyota ECP warranty and wondering if the lift will affect it.
    Thanks
    ONTHEEDGE
  11. Feb 5, 2013 at 5:54 PM
    #291
    HanleesTacoma
    HanleesTacoma Well-Known Member
    NorCal
    2013 MGM Prerunner V6 SR5
    Window Deflectors with (Tacoma) Logo Visor Yakima Locking Bike Rack Mount N-Fab Nerf drop step bars 2" tube Powder-coated Black 4" Maxtrac Spindles Steel braided extended (front) brake lines Bilstein 5100 Adjustable Front Shocks 1.6" Eibach Coil Springs 3-4" Bilstein 5100 Extended Rear Shocks 2" Toytec Progressive 3 Leaf AAL (made by Deaver Leaf Springs) 2" Rear Blocks Steel braided extended (rear) brake lines 1.5" rear wheel spacers Black TRD NORCAL Bedside Vinly Stickers from Sockeye Monkey 10g Powder-coated BLACK Skid Plate with TRD Logo from Matt123 (Black) Plastidip emblems Go Rhino Xtreme Rack Sport Bar Lightning Series (Black) 4" 18watt CREE LED Flood/Spot LED Work light (x4) Powerbass BTA8 150W 8" bass tube with built-in amp plus remote control 32" 180W CREE LED Bumper Light Bar Flood/Spot combo Bully Matte Black Exhaust Tip. Inlet diameter: 2.875", Outlet diameter:3.75", length 9" Redline Hood Struts (Black) Plus kit True Edge (Black) Riveted Textured Fender Flares
    Originally Posted by ryan c [​IMG]
    Im sure this has been answered somewhere but if some one could help me out that would be great. What offset/backspacing do i need to rock 285 70 17s without rubbing? I have 2" lift. I think someone said -6mm and 4.5" will work. Any help would be great. I have the tires. Want to buy rims but want to make sure they dont rub. Thank You!!
    Quote:
    Originally Posted by KPT [​IMG]
    You'll have a lot of cutting and chopping to do with only 2" of lift. even with 3" of lift and the properly backspaced wheels (4.5"), people still have to trim to avoid rubbing.
    KPT, Thanks for the knowledge you gave to us all here in this forum..We really appreciate your help. Just need some advise, Ok so I just purchased a set of Toyo Open Country AT II tires (285x70x17) and I was wondering if my wheel size/specs are fine. Planning on buying a set of KMC XD Spy (17X9) 6X5.5 OS: -12mm BS: 4.53"..I have a set of 1.5" wheel spacers on stand by just in case I'll need it. Right now my truck is in the shop and getting (Maxtrac spindles on) so I'll have 4" front and 2" rear lift. So my question is, will I still have any problems with tire clearance/turning radius/rubbing issues?. Thx again for your help!.
  12. Feb 5, 2013 at 5:59 PM
    #292
    TexasTacoma37
    285/65/17 is a very peculiar size. Are you sure you weren't looking at 285/70/17?
    And no modification voids your warranty. The dealership has to prove that the modification directly led to the failure of the part.
  13. Feb 5, 2013 at 10:11 PM
    #293
    ONTHEEDGE
    Nova Scotia
    2012 Tacoma TRD
    Thanks for the reply but the reason i was looking at 285/65 17's was they r pretty much the same radius as the 265/70 17 except they r wider looking at Yokohama's
  14. Feb 6, 2013 at 5:38 AM
    #294
    TexasTacoma37
    Those wheels specs are good to go for the 285/70/17's and the spindles. Might have to remove the mud flaps but that would be it.
    There are some folks on here running 285/60/18 with no lift, so I would expect that with the lift and the 285/65/17's that you'll be fine if you run wheels with 4.5" of BS.
  15. Feb 6, 2013 at 5:39 AM
    #295
    ONTHEEDGE
    Nova Scotia
    2012 Tacoma TRD
    Right on thanks for the info
  16. Feb 7, 2013 at 8:42 AM
    #296
    HanleesTacoma
    NorCal
    Thanks for the feedback KPT!. Really appreciate it sir.
  17. Feb 7, 2013 at 9:22 AM
    #297
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
  18. Feb 11, 2013 at 12:29 PM
    #298
    mikea
    mikea Active Member
    Illinois, west of the Fox
    07 DC TRD SPORT 4x4
    Weather tech, salex center console organizer
    Keith I'm looking to add rims and tires to my 07 DC sport with stock suspension. I want a 16" aftermarket rim, with a 265/75/16 tire. Do I need 4.5 BS on the rim? Will I rub at all?
    I'm considering Duratracks, FR Destinations......thanks
  19. Feb 11, 2013 at 12:57 PM
    #299
    TexasTacoma37
    You'll want between 4.5 and 55.5 of BS. Possible minor rubbing on the flaps, but most folks have none.
  20. Feb 11, 2013 at 1:00 PM
    #300
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Damn that's a lot of BS :)
