Biggest Tire on 07 TRD Sport
Discussion in 'Wheels & Tires' started by gb1194, Oct 14, 2009.
  1. Apr 29, 2010 at 12:30 PM
    #41
    WPTaco
    WPTaco Well-Known Member
    Nige
    Colorado
    08 D.cab Sport, 6 speed
    Westin bull bar and side steps, K&N intake, Gibson cat back, Moto metal 951's, A.R.E lid, TSB springs, 5100's, Hella 500FF, Grillcraft grill, maglight mod, debadged
  2. Apr 29, 2010 at 2:59 PM
    #42
    vermintrex
    vermintrex Well-Known Member
    Vancouver
    TRD SPORT Shorty
    BFG A/T KO 265/70/17, '11 FJ wheels, 5100's all four corners, Eibach springs, 1/4" Taco lean spacer, Leer 100XR, WeatherTech liners, trimmed mud flaps and I farted in it.
  3. Apr 29, 2010 at 3:04 PM
    #43
    WPTaco
    Nige
    Colorado
  4. Apr 29, 2010 at 4:14 PM
    #44
    vermintrex
    Vancouver
    TRD SPORT Shorty
  5. May 2, 2010 at 1:00 AM
    #45
    forgedgreen
    forgedgreen Member
    what about 5 lug max tire size?
  6. May 9, 2010 at 5:36 AM
    #46
    Nightfury
    Nightfury Well-Known Member
    Evan
    Bismarck, North Dakota
    Factory running boards, Toyota (DeeZee built) toolbox, Code Alarm 5152 remote starter, Bronze TRD rims, more to come....
    Someone before me did touch on this a bit, but I would like to elaborate a bit.
    The two different tire sizes are much like taking a turn all the time. They spin at different circumferences, causing your differential to take a lot of stress. Over a short period of time, this isn't a big deal. But if you are doing something, like replacing one of your half-worn AT/MT tires because of unrepairable damage, then you really should replace them in a pair, because even 6 or 7 32nds of an inch difference in tread can cause damage over the 15k left on the non replaced tire.
    Example: Your left rear tire has 6/32nd less than the right rear tire that you just replaced (running 265/75/16). Instead of 8.29 feet in rolling circumference, it is 8.19 feet. Therefore, it spins 458 times more each 60 miles. This isn't a huge deal if you have an open differential, but if you have a posi (which, I guess is more of an F-word thing) then you'll burn up clutches pretty quickly. Or it can cause your ABS to behave strangely in the winter. If that tire is on the front of the vehicle, it can cause pull issues and bizarre braking all the time.
    This is an extreme case, but it is something to keep in mind when putting larger tires on your Tacoma, and neglecting your spare or replacing a tire damaged on the trail.
  7. May 15, 2010 at 9:23 AM
    #47
    yv1650c
    yv1650c Active Member
    Carlos
    Venezuela
    Hi, Im Hilux User, I tink its almost the same model than TACOMA. OEM is 265/65R17 s, do you think I can go with the 265-70? thanks
  8. May 15, 2010 at 9:47 AM
    #48
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    on mine at stock height i had 285/70/17 on stock sport rims i also had to use a 1/4 inch spacers so it didnt touch the uca. and only rubbed at full lock in reverse. if that helps you any
  9. May 17, 2010 at 7:52 PM
    #49
    attolev
    attolev New Member
    brad
    Columbus, GA
    10 4x4 Double Cab Sport
    TKO 275/70/17
    275/70/17's fit with no rubbing (BF Goodrich TKO's) - 191.72 per tire at Sam's on 5/11/2010
  10. Jun 9, 2010 at 10:56 PM
    #50
    NBKACAL
    NBKACAL New Member
    08 Tacoma
    Lighting, Grille, Intake, and Exhaust
    I have an 08' tacoma with a 3" RevTek Lift and I'm looking into purchasing 18" Rockstars on some Nitto Trail Grapplers and I need some help in choosing the size of wheel spacers to avoid any rubbing. I noticed that they vary in sizes ranging from 1" to 2". Please Help
  11. Jun 17, 2010 at 4:56 PM
    #51
    TroutSlayer
    TroutSlayer New Member
    Spokane, WA
    2008 DCSB TRD Off Road
    TRD Seat Covers, Flowmaster Catback, AFE CAI, 3" TC Lift, 275/70/18 OCMT
    The 18" XD Rockstars that are 6 on 139.7 (5.5) have a 5" backspacing. You will want to be around 4.5" backspacing to not have issues rubbing on the upper control arm, so a 1" wheel spacer will be sufficient. What size tires are you running? I have 275/70/18 mud terrains with a 3" lift and 4.75 backspacing.
    You could go with 20" XD Rockstars and not need wheel spacers because the backspacing is right on. You would have to go with a different tire though. A 285/60/20 Good Year DuraTrac would work.
  12. Jun 20, 2010 at 12:26 AM
    #52
    eight3one_offroad
    eight3one_offroad Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
  13. Jul 12, 2010 at 10:43 AM
    #53
    08koas is my name
    08koas is my name Member
    Jon
    Southern West Virginia
    08 double cab V6 off road sr5
    K&N, removed charcoal filter. changed mass air flow sensor. Quick throw shifter
    Let me jus say that after much reveiw, online an calling around. That the Hankook Atm-10 is by far the best tire I have found in any appilication... :D It's got handleing that you wouldn't beleive, VERY aggresive on road an off! Quite, looks good, an supposed to have a 50k tread life, we'll see I guess.. But the side wall design is awsome on a mattle black wheel. An the price is a sure bet. Got them from dicount tires for 128.40 a tire.
    265/75/16 impressive at 90 mph in the curves!:ohsnap:
  14. Jul 12, 2010 at 11:03 AM
    #54
    kramer2k
    kramer2k Well-Known Member
    Jacksonville, FL
    08 DC PreRunner TRD OR
    Do you have a link to that tire? I'm trying to find it and I'm coming up empty. Would that size, the 265/75/16 fit on the 16" TRD OR wheels?
  15. Jul 31, 2010 at 1:33 PM
    #55
    karlstaco
    karlstaco New Member
    Karl
    Calgary, Alberta
    off road package
    3inch lift,18 inch v-tech rims,32pro comp at tires,roof basket,roof lights
    i have 18s and 275s. i have a lil rubbing but i needed to get offset rims to fit them
  16. Aug 11, 2010 at 2:44 PM
    #56
    Ridendirtywhips
    Ridendirtywhips Well-Known Member
    Sacramento
    06 prerunner
    So the 255/75/17 MT will fit?
  17. Sep 7, 2010 at 7:06 PM
    #57
    jdeutsch
    jdeutsch Member
    I have a 2010 Double Cab 4wd SR5. Stock tires are P265/75r16. I got the alloy off road wheels and plan on keeping them. However 75's a pretty skinny and want to go wider and taller prefably. I know the stock OFF Road pkg is P265/70R16. I was wondering if anybody had any 275's to show in a pic? And if they will fit without getting a lift.
  18. Sep 16, 2010 at 1:15 PM
    #58
    Dale B
    Dale B New Member
    Boise, ID
    05 Tacoma 4X4 TRD
    I have 2005 Tacoma Access cab 4X4 with TRD. I currently have Eagle rims with Bridgestone 265/70/17's They do rub going over a dip. I called Trie rack and it seems that you have to be careful of the offset of the wheel. I'm sure the stock rims have the correct offset, but if you go to after market rims be careful.
  19. Sep 17, 2010 at 5:07 PM
    #59
    cannoncox
    cannoncox New Member
    NM
    2011 TRD Sport 4x4 Double Cab
    XD Monster Wheels 18x9 Nitto Terra Grabbers 285x60x18
    i have 285x60x18 on my stock 2011. 18x9 wheel. they are perfect with no rub.
    nitto terra grabber tires and XD monster wheels
  20. Sep 28, 2010 at 6:18 AM
    #60
    Timber6969
    Timber6969 New Member
    Ken
    Gainesville, GA
    2011 Black Tacoma 4dr 4x4
    jbl, BT, iphone adaptor, needed bigger tires
    Just joined. Just picked up my 2011 Tacoma last night. Fourth one I have owned. All were great. Ordered this one the way I wanted it. I would like to put BF KO's on it, the 285's. I have read what some say, and they "think" they may rube. Has anyone put them on and know for sure that they do rube, and if so how much?
    Thanks, Ken
    Also, the back up camera, I would like to put a switch on it to power it on when I want to see what I am pulling every now and then with out putting it in reverse, anyone done this or know what and where the wire for it may be?
    Thanks,
