Biggest Tire on Stock Wheels VS Aftermarket Wheels
Discussion in 'Wheels & Tires' started by Jasper909, Nov 11, 2014.
  1. Nov 11, 2014 at 6:40 AM
    Jasper909
    Jasper909 [OP] New Member
    Alberta Canada
    2010 SR5 Access Cab 4x4
    Hey All, Long time lurker here.
    I plan on doing the OME 2" leveling lift kit to my 2010 SR5 Access Cab (16"wheel) and am getting confused with Wheels/ Tires.
    My plan is to run stock wheels (painted black) and a set of Wrangler Duratrax, and I am trying to figure out the max size I can go.
    My question is what size I can run on stock wheels, VS what size I can run on a set of aftermaket wheels. I am getting confused with backspacing and offset really. Will there be a larger size with aftermarkets, or is it the same as stock?
    Thanks guys! And newbie Alert joining the forum finally! :confused: :D
  2. Nov 13, 2014 at 11:24 AM
    DirtyTaco24
    DirtyTaco24 Well-Known Member
    Greg
    Ottawa
    '12 TRD DCLB Black
    Usually on tire rack it'll show the min and max Wheel width you can go with a specific tread width. ie. 285 tread will fit rim widths of min: 7.5" and max: 10"
    So if your rim width is less than 7.5" you won't be able to fit a 285 width tire.
    I'm not sure the size of your rims but mine are the TRD sport rims which are 7.5"
  3. Nov 13, 2014 at 11:30 AM
    DirtyTaco24
    Greg
    Ottawa
    '12 TRD DCLB Black
  4. Nov 13, 2014 at 1:36 PM
    Bender581
    Bender581 Well-Known Member
    AL
    Arkansas
    2012 4X4 Tacoma
    Gobi roof rack. Icon coilovers, Icon tubular UCAs, FOX 2.0 rear shocks, Icon 3-leaf progressive AAL.
