biggest tire size on a 18in rim????
Discussion in 'Wheels & Tires' started by lovemytaco, Mar 29, 2012.
  1. Mar 29, 2012 at 3:30 PM
    lovemytaco
    lovemytaco [OP] Active Member
    Dana
    Savannah, Ga
    I have a 2011 dcsb im wanting to buy the FN BFD Wheels 18x9, 5" BS, 0mm Offset I was wondering wut 3in lift would give me the most lift (I need to buy from toytech to keep factory warranty) and wut is the biggest tire size for that wheel I really dont want to use the Goodyear Duratrac 275/65-18 I dont like the way they look. Would like to go with the BFG M/T 285/70r18 or 305/60r18 km2 or the Nitto Trail grappler M/T 285/65r18. need help lol let me know wut yall figure out thanks.
  2. Mar 29, 2012 at 6:54 PM
    Large
    Large Red
    "I was wondering wut 3in lift would give me the most lift"
    That's a contradictory statement, and adding a lift (any brand) will not void your warranty. If you are dead set on a 3" lift I suggest 285/65 on 18s, 285/70 on 17s or 285/75s on 16s.
  3. Mar 29, 2012 at 7:18 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    What weighs more. 100 lbs of lead, or 100lbs of feathers?
  4. Mar 29, 2012 at 7:19 PM
    1GR
    Scott
    BC, Canada
    If you want a wide tire, you're going to need 4.5" bs, not 5". 305/60R18 is a good size. Although they are heavy, will require trimming, mud flap removal, and a body mount chop. Questions?
  5. Mar 29, 2012 at 7:32 PM
    lovemytaco
    Dana
    Savannah, Ga
    the dealerships around here say that the lifts from toytech are the only lifts they will keep the warranty on. so I dont know. but back to the tires 285/65 on 18s if i go with the 285/70 on 18s wouldnt that be about a inch taller?
    285/70r18=33.7/11.22r18
    285/65r18=32.5/11.22r18
    so im looking at a little over a inch taller if i go with the bfg M/T. I dont have to have them but it is by far my favorite tire. i would settle for the nitto trail grapplers but if i can make the bfg's work i want them.
    any ideas of what 3in lift with or without going through toytech that will help me clear the 285/70r18????
  6. Mar 29, 2012 at 8:02 PM
    1GR
    Scott
    BC, Canada
    Any 3" lift is going to give you 3" of lift. :rolleyes:
    285/65R18 is good. 285/70R18 is going to require a LOT more trimming then the 65 aspect ratio.
  7. Mar 29, 2012 at 8:03 PM
    1GR
    Scott
    BC, Canada
    Remember OP, tire size clearance has nothing to do with lift. It's all about backspacing, and trimming.
  8. Mar 29, 2012 at 11:50 PM
    lovemytaco
    Dana
    Savannah, Ga
    im not wanting that wide of a tire just trying to fit the bfg's is all I think the 305/60 would be to wide for what i want how hard is the body mount chop?
  9. Mar 29, 2012 at 11:53 PM
    lovemytaco
    Dana
    Savannah, Ga
    what does the OP stand for I see its by my name im new to the whole forum thing so dont know what alot of this stuff means..
  10. Mar 29, 2012 at 11:55 PM
    lovemytaco
    Dana
    Savannah, Ga
    also the only reason Im going with this wheel size is bc its the only size they make I would much rather go with 17s it would be a lot easier.
  11. Mar 29, 2012 at 11:57 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    then go with 17's
  12. Mar 30, 2012 at 2:32 AM
    lovemytaco
    Dana
    Savannah, Ga
    the wheels I want only come in 18's :(
  13. Mar 30, 2012 at 6:02 AM
    Large
    Large Red
    Then go with 18s. You might not think that going from a 65 aspect ratio to a 70 on an 18" wheel would be that much of a difference but ask anyone here & they will tell you otherwise.
  14. Mar 30, 2012 at 7:40 AM
    lovemytaco
    Dana
    Savannah, Ga
    Well I'll probably go with the nitto's then so I'm sure they will fit thanks for the input.. That's why I posted on here I know more about the pre tacomas then the new Tacomas
  15. Mar 30, 2012 at 12:47 PM
    1GR
    Scott
    BC, Canada
    Here's the sizing steps you want depending on width for 18" rim:
    305/60
    285/65
    265/70
    Or even 275/65
    Anything bigger and that trimming is going to turn into removing pieces and cutting fenders.
