Biggest tire with 3" lift without cutting bm
Discussion in 'Wheels & Tires' started by SkyHighTacoma, Oct 31, 2009.
  1. Oct 31, 2009 at 4:04 PM
    SkyHighTacoma
    SkyHighTacoma [OP] Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    What is the biggest tire size that you can fit with a 3" lift without cutting the cab mounts, i know that you have to trim the fender wich i dont have a problem doing. But i dont want to cut the body mounts to fit a 285/75/16 tire, at least not now. So what is the biggest tire size you can run without body mount trimming? I searched but didnt find what i wanted.. :)
  2. Oct 31, 2009 at 4:25 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Thats about the limit if you dont want to trim or cut into the cab mounts
  3. Oct 31, 2009 at 6:43 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    As far as I know, 33"s will rub the cab mount only during off-roading. With 32"s, you don't need to trim the fender and cut the cab mount.
    32" - either 265/75/16 or 275/70/16 (wider)
    My next tire will be 285/75/16 but I don't plan on trimming the cab mount as 80% of the time I'm on the highway.
  4. Oct 31, 2009 at 6:46 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Cut em if you got em!!!
  5. Oct 31, 2009 at 6:48 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    Hahaha. I can live with it.
    Happy halloween!
  6. Oct 31, 2009 at 6:48 PM
    HBMurphy
    Paul
    So California Coast
    None
    You know on a base model, you may not even need to cut them. Take a picture of your body mount and post it up! I've looked at a bunch of mounts before I cut mine, and I think, IRC, you don't need to cut yours. IMBW.
  7. Oct 31, 2009 at 7:07 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    Hmmm. I'm base model too.
    Subscribed. (I'll post pic if SkyHighTacoma won't).
  8. Oct 31, 2009 at 7:19 PM
    HBMurphy
    Paul
    So California Coast
    None
    One other thing... in addition to holding the cab, the cab mount is there for crash protection.
    In a front end collision it tries to keep the tire/wheel from crushing the passengers. In a side crash, it tries to take the impact of the other vehicle's bumper as to protect the passengers. When you do cut it, only cut what you need and then weld it back in. I haven't welded mine (I want to trim it more). I've seen a number of guys that run their trucks with it cut but not boxed (mine's not boxed yet - I wanted to make sure I trimed enough). Good until you use it - either in an accident or hit it good with a rock - like I did on my failed attempt on AFTERSHOCK! (ring & pinion failure and driver error :))
    The best cab mount chop and box I've seen are the ones that taper back about 30ºs.
  9. Oct 31, 2009 at 7:20 PM
    HBMurphy
    Paul
    So California Coast
    None
    MY mistake!!! When I saw 'base model' I thought it was a single cab. So sorry!!!
  10. Oct 31, 2009 at 7:58 PM
    HBMurphy
    Paul
    So California Coast
    None
    Oh yeah! Happy Halloween! Gonna go check out some downtown action here soon.
  11. Oct 31, 2009 at 7:59 PM
    HBMurphy
    Paul
    So California Coast
    None
    come to think of it, I don't think Mario ever cut his! I know I needed mine cut!
