Biggest tire without rub
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yota4life, Jul 1, 2010.
  1. Jul 1, 2010 at 5:06 PM
    Yota4life
    Yota4life [OP] Member
    Caleb
    Mississippi
    04 Prerunner TRD SR5
    Recently I have put a 2'' leveler on front of my yota and 1'' spacers in back to even everything out. I still have stock 16'' rims and was wondering what would be the biggest tire i could fit without harmful rubbing taking place. Thanks 4 the help.
  2. Jul 1, 2010 at 5:10 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Not sure as I have a second gen but I would guess a 275 series. Had 3" spacer on mine with 285s and they rubbed once in a while.
  3. Jul 1, 2010 at 5:15 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    265/75/16 will fit without rubbing theyre an inch taller then stock. 285/75/16 will require some trimming
  4. Jul 1, 2010 at 5:16 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    if you had 15'' rims youd be able to fit 32's without rubbing to,theyre a little bigger then 265/75/16's
  5. Jul 1, 2010 at 5:17 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    265/75R16...any wider you will need spacers.
  6. Jul 2, 2010 at 7:26 PM
    Yota4life
    Caleb
    Mississippi
    yeah, some 265/75/16 bf goodys are sounding pretty good right now...
  7. Jul 2, 2010 at 8:40 PM
    CO_Steve
    CO_Steve Active Member
    Monument,CO
    11 SR5
    I have Goodyear 265-75-16 on my 01 and the left front rubs the frame on a full lock turn.
  8. Jul 2, 2010 at 10:11 PM
    Yota4life
    Caleb
    Mississippi
    did you have any sort of lift on yours?
  9. Jul 3, 2010 at 12:37 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I noticed this also with my Toyo MT's in 265/75R16. A little rubbing on the frame on the front left side in back with a 2" lift. I'm still planning to move up to Duratrack 285/75R16 in the future, but I'll need to get new wheels as well, but I'm expecting to need spacers and do a bit of trimming also.
  10. Jul 3, 2010 at 5:06 AM
    CO_Steve
    Monument,CO
    11 SR5
    Nope, it's all stock.
  11. Jul 3, 2010 at 10:30 AM
    Yota4life
    Caleb
    Mississippi
    oh ok... Im thinking i should be good with the small lift I have then. I doubt I could pull off a set of 285/75/16 without trimming and stuff like that though.
  12. Jul 6, 2010 at 9:20 AM
    RebelRider201
    RebelRider201 Well-Known Member
    J
    South, AL
    PreRunner
    5% tint, black emblem/grille/etc, 10k hids, Flowmaster super 44, Tuff Country 3", 1700w amp, Kicker L7 12.......and on
    If you have atleast a 2" leveling kit with aftermarket shocks/and or 1-2" blocks on the rear you can run 285/75/16's easily with the pinch weld-mod, after a week or two of rubbing out the edges once your tires are mounted you will more than likely no longer hear rub, just my .02, despite the advice and criticism I recieved from others I run 285 with simply a leveling kit and rear 3" AAL's off of a '94 Tacoma on my '03(lined up just perfect)
