biggest tire?
Discussion in 'Wheels & Tires' started by RDAY, Dec 29, 2008.
  1. Dec 29, 2008 at 5:53 PM
    RDAY
    RDAY [OP] Well-Known Member
    NY
    07 Tacoma SR5 4x4
    Whats the biggest tire u can fit on a stock off road tacoma wanna go 16" rim.
    Thanks Guys
  2. Dec 29, 2008 at 5:57 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    265/75/16 is the biggest you can go without a lift.
  3. Dec 29, 2008 at 6:06 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    would that tire look dumb when I eventually went with a lift next yr?
  4. Dec 29, 2008 at 6:07 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    cause i'm trying to figure out if i should just buy the new tires and rims now or just buy the rims and have them mounted on my stock tires and buy new tires once I get my lift
  5. Dec 29, 2008 at 6:14 PM
    rick
    rick `
    if you go with a 6" lift then IMO, yes it will look dumb. on the other hand if you get a 2.5" - 3" lift it will look nice. (not as nice as 33's) of course thats just my opinion also
  6. Dec 29, 2008 at 6:48 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    265/75/16. Looks great with no rub or trimming needed
  7. Dec 30, 2008 at 5:17 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    what is my stock tire tho i think it is 265/75/17? ill have to check its the offroad package
  8. Dec 30, 2008 at 5:19 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    stock size in the or package is 265/70/16.
  9. Jan 6, 2009 at 8:48 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    My '08 has 265/75/16 on it stock. Wondering if I can go slightly larger with the TSB and the Bilstein 5100's set at the .85" setting which actually got me 1" of lift all the way around? Got a few miles to research it until I need new tires.
  10. Jan 6, 2009 at 10:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hmmmm..........they must have started using 265/75/16 as oem size for 08 and up then. those will still be the biggest you can run in a 16 without more lift.............a 275/75/16 may fit....not too sure, but a 285/75/16 will definitely not.
  11. Jan 7, 2009 at 5:34 AM
    4x4x4trd
    North Texas
    Will your right and I need to read my notes better. :eek:
    My truck does indeed have the 265/70/16 tires on it now and I had planned to replace with the next size up 265/75/16 after the slight lift I added.
