BIGGEST tires: FJ SE wheels, Icon 3" lift, TSB lp
Discussion in 'Wheels & Tires' started by RacerAV, Oct 16, 2012.
  1. Oct 16, 2012 at 12:47 PM
    RacerAV
    RacerAV [OP] Well-Known Member
    OC, CA
    '09 DCSB4x4 (sold)
    I am trying to do the math, and I'm going nuts. Never understood tires completely.
    I have a base DCSB 4x4 with ICON 3" c.o's and the TSB leaf pack. (Going with a shackle flip and new leaf pack soon)
    On the FJ SE wheels, (silver, with the round holes all around) what's the largest size (width and height) BFG ATs I can run without TOO much rubbing? I dont have the COs all the way up in the front, as to not have the rear sagging too far below. But ASSUMING I'll lift the front to it's max, and get a new pack in the rear with adjustable shackle flips and all that...
    What size tire should I be ordering?
    Also, are online prices pretty comparative to in-store pricing?
    Thanks!
  2. Oct 16, 2012 at 11:32 PM
    RacerAV
    OC, CA
    '09 DCSB4x4 (sold)
    nada?
  3. Oct 16, 2012 at 11:58 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    What is the BS on the FJ wheels?
    I have a full 3" lift front & rear and run 255/85/16 BFG KM2s (33.3" tire) on 1st Gen TRDs (4.5"BS) without any cutting or rubbing.
    285/75/16s (a shorter but wider tire)with the proper BS wheel & a lot of cutting and you wont rub.
  4. Oct 19, 2012 at 12:12 AM
    RacerAV
    OC, CA
    '09 DCSB4x4 (sold)
    not sure on the BS for the wheels, I thought pretty low, zero? not sure...
    What cutting would I need to do? The body mount? Fenders? Can I roll them? Does the rubbing happen only at full lock and compression or something or more common?
  5. Oct 19, 2012 at 9:00 AM
    Large
    Large Red
    If its the 17s with the (7?) holes I did some research on them but can't recall the info off the top of my head. I would look it up but it's a PITA on my phone.
  6. Oct 19, 2012 at 9:02 AM
    Large
    Large Red
    Ok I read my previous post and sounds misleading lol. I made a thread about it on here.
  7. Oct 19, 2012 at 2:46 PM
    RacerAV
    OC, CA
    '09 DCSB4x4 (sold)
    I looked for your thread, couldnt find it.
    I dropped my new set of FJ wheels off to get their semi black powder coating today. Now I need to get a set of tires, and quick!
    I've seen the look of the tires I want, size wise, but no idea what they had to do to keep them from getting torn up!
  8. Oct 19, 2012 at 3:04 PM
    RacerAV
    OC, CA
    '09 DCSB4x4 (sold)
    my tires now are almost 32" in diameter, (stock FJ wheel/tire set up), can I go with a 33" tire? it doesn't seem to be close enough to rub...
    would that be like a 285/75/17 or so?
  9. Oct 19, 2012 at 3:18 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I believe the FJ's have 0 BS but I'm not positive. 285's pretty much equal out to a 32.6" tire cause thats what I have on my truck which are 285/65-18's. Your going to rub up front thats for sure but nothing a dremel cant take care of and removing the front mud flaps. I still rub on the body mount but only at full lock. I'm thinking you will need some wheel spacers also to clear the UCA's.
