Biggest Tires?
Discussion in '1st Gen. Tacomas (1995-2004)' started by DaytonLax14, Nov 28, 2009.
  1. Nov 28, 2009 at 6:37 PM
    DaytonLax14
    DaytonLax14 [OP] Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    I already posted this in the tires/wheels section, but I didn't get much help or maybe I'm just impatient:p Anyways, I have a 1998 2wd TRD Off Road Prerunner, but it has the 4x4 suspension. What are the biggest tires I can fit on the stock wheel without any rubbing and fender modification?
  2. Nov 28, 2009 at 6:46 PM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    Red Prerunner AC
  3. Nov 28, 2009 at 7:08 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    265/75/16
    depending on the brand and tread pattern of tire and status of your suspension you MAY experience some rubbing
  4. Nov 28, 2009 at 7:15 PM
    DaytonLax14
    Corey
    Ohio
    minor rubbing is no big deal. would it be worth it to shell out the cash to get the bigger tires? Are they noticeably bigger?
  5. Nov 28, 2009 at 7:26 PM
    smuook
    smuook Daily Driver "Plus"
    Frank
    Loganville, GA
    2004 DC V6 PreRunner
    Billy 5100, Satoshi, MBW Wheels, All Pro Front Bumper with 3x PIAA 530, LED dash lighting, other stuff too much to list
    You can plug the numbers in yourself here...
    http://www.miata.net/garage/tirecalc.html
    It something to consider when you have to buy tires anyway... but it's not worth doing it early imo. It will probably get you about an inch or two... depends on your budget and your needs.
  6. Nov 29, 2009 at 5:21 AM
    DaytonLax14
    Corey
    Ohio
    I'm going to need new tires anyways, so I figured I might as well get some that will look better. What is an aggressive tire/pattern that I should look into? I don't do much off roading, mainly street driving, but I want a pretty aggressive look.
    edit-the tires that are on my truck now are 235/75/15 but I have 16" wheels. Does that make any sense?
  7. Nov 29, 2009 at 7:26 AM
    blegros
    blegros Member
    no
  8. Nov 29, 2009 at 7:46 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    thats not possible
  9. Nov 29, 2009 at 8:19 AM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    You have 15" tires mounted on 16" wheels? NOT Possible. Whatever your tires say, that's what your wheel size is. I have 31x10.50x15 on mine, and plan to replace them with 32x11.50x15 in a few weeks. Your truck is a 1998, so I would most likely bet your on 15" wheels. 01 to 04 came with 16" wheels.
    Are your wheels stock? Post a picture of them.
  10. Nov 29, 2009 at 8:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Something is wrong. A tire for a 15" wheel will not fit a 16" wheel....
  11. Nov 29, 2009 at 8:21 AM
    DaytonLax14
    Corey
    Ohio
    i swear that's what it is lol. I just have the stock wheels, they must be 15".
    What kind of tread should I get for an aggressive look?
    Edit-Werloc, you're right.
  12. Nov 29, 2009 at 8:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah...You have to have a 15" wheel if thats the tire size. A 265/75/15 is the size you should look for.
  13. Nov 29, 2009 at 8:24 AM
    DaytonLax14
    Corey
    Ohio
    Alright, thanks fellas.
    Should I just get A/T tread?
  14. Nov 29, 2009 at 8:26 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    does that size exist?
    i thought for 15s the tires are going to be in US sizes
  15. Nov 29, 2009 at 8:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. Its a 31X10.50-15
  16. Nov 29, 2009 at 8:28 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
  17. Nov 29, 2009 at 8:29 AM
    DaytonLax14
    Corey
    Ohio
    Alright cool, so I'll just look for 31" tires.
  18. Nov 29, 2009 at 10:08 AM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    You can get Metric in 15". Anyway, stock size for the truck on 15" wheels is 31x10.50x15. You should be able to fit the next size up which is 32x11.50x15 which is what I'm putting on my truck. I have a 2000 4x4, but if you have a TRD 2wd you "should" (I would double check) be able to get the same size. Just a little rubbing at Full Turn on front wheels. That's it. For me, I can live with that.
    As far as what tires? If you ask 10 different people, you'll get 10 different answers. This is just "MY" opinion. I've owned 4x4 pickups and 4x4 SUV's since I've been driving. I'm 46, so that's 29 years. I've had many different All Terrain tires, and for the passed 20 years, I've stuck with BF Goodrich All Terrain KO tires. Not a street tread, and not a full blown mud tire either, but a great aggressive looking all around tire. Great on road, and off road, sand, mud, snow, etc. Why do I love these tires? They last forever. On every vehicle I've had them on, I've got well over 70k+ miles on them with still half the tread left. 99% of my driving is on road, and very little off road. I just love them in the snow. Look them up. They're on the pricey side, but well worth it in the long run. You get what you pay for....;)
  19. Nov 29, 2009 at 1:01 PM
    DaytonLax14
    Corey
    Ohio
    Alright thanks a lot for the insight. The previous owner must have put smaller tires on the truck, so I'll look into 32" tires.
  20. Dec 5, 2009 at 10:38 AM
    DaytonLax14
    Corey
    Ohio
    i know my question has already been answered, but you can literally see daylight between the top of my tires i have now and the body of the truck, so would i be able to squeeze 33's under there? there is an 8" gap between the top of the tires and the bottom of the fender at the rear, and a 7 1/2" gap for the same thing in the front.
