BigMike’s Big Journey: New 2016 Tacoma
Discussion in '3rd Gen. Builds (2016-2023)' started by BigMike, Apr 18, 2016.
  1. Jun 9, 2017 at 7:45 PM
    #241
    BigMike
    BigMike [OP] Applied common sense Vendor
    Fresno, CA
    2016 56-speed 580:1 Triple Marlin Crawler-equipped TRD Sport
    May 4, 2017: Fins & Things (continued)
    Stopping for lunch.
    dorton, Nickel and nDub like this.
  2. Jun 9, 2017 at 7:46 PM
    #242
    BigMike
    Fresno, CA
    I like the concerned girl looking up at my truck lol
    Cool pic with Mr Crawler
    With the front suspension loaded it seems the axle could have been designed forward a bit. No wonder 2nd and now 3rd gens have front tire to body mount interference
    Got my very first low oil pressure warning light! Too cool!
    And that was it for Fins & Things!
    dorton, mauidogg, ExplorHer and 3 others like this.
  3. Jun 10, 2017 at 7:51 AM
    #243
    BigMike
    Fresno, CA
    May 4, 2017: Vendor Night
    Back in camp while setting up for the Vendor show Marlin and I helped a FJ40 who was having alternator issues. This doesn't exactly count as a rescue but I was proud of my little baby boy Tacoma :)
    Ready to setup and meet a ton of people!
    It was so cool having my World's First Dual Case'd 3rd Gen Tacoma in our booth.
    Feeling better and better for the future of this Tacoma!
    Nickel likes this.
  4. Jun 10, 2017 at 7:53 AM
    #244
    BigMike
    Fresno, CA
    May 5, 2017: Flat Iron Mesa
    Friday morning we ran Flat Iron Mesa. The event has a Trail Rating system that I forgot to mention. The prior day's trail, Fins & Things, is rated a 4 out of 10 and Flat Iron Mesa is rated a 5/10. Like the day before, I had never wheeled Flat Iron Mesa so I was eager to check it out. After gaining a lot of confidence from the TacoBox, I was eager for something more difficult.
    Amazing weather, amazing turnout, gonna be another amazing day out wheel'n!
    There is about a 20 min drive out of town for this trail. Here I am cruising on the highway with my nice 12 PSI tire warning lights on
    dorton likes this.
  5. Jun 10, 2017 at 7:53 AM
    #245
    BigMike
    Fresno, CA
    The trail started out pretty mellow
    Nice views here and there
    After a while we finally got into some slickrock
    dorton and Nickel like this.
  6. Jun 10, 2017 at 7:54 AM
    #246
    BigMike
    Fresno, CA
    May 5, 2017: Flat Iron Mesa (continued)
    This was a tough line because you drop in from a sharp right turn. The reduced driver visibility of the Tacoma not helping here.
    It was fate that brought these two AccessCabs together and fate both registered for the same two back-to-back trails :D
    This was a nice little climb. I struggled at first but then found my footing by Crawling it very slowly in Dual low range.
  7. Jun 10, 2017 at 7:55 AM
    #247
    BigMike
    Fresno, CA
    On this drop off I was super tempted to run it hard driver because I love how the Crawler holds the vehicle back without using the brakes.
    But because I'm still open-open, if one tire on each axle is able to unload, then you can still slide forward despite the engine maintaining a steady idle in gear.
    That factor combined with the fact the front bumper sticks out a mile concerned me enough to stay a bit passenger.
    It ended up being a very basic drop-off.
  8. Jun 10, 2017 at 7:55 AM
    #248
    BigMike
    Fresno, CA
    This climb was pretty gnarly for open-open. I could have taken a simple dirt-road line to the far right but took the hard line up the middle.
    I couldn't climb it without lockers so I shifted the T/Case in High Range and the TacoBox (Crawl Box) into Low to use our 4.7:1 T/Case ratio, and in 8th gear (2nd gear + single 4.70) I was able to get enough tire speed to trigger the Auto-LSD computer. This was the first time using the Auto-LSD. It did it's job, only had to bounce a few times and once I felt traction I let up in a smooth enough fashion to not lose forward momentum and was able to do the rest with just the single Marlin Crawler Crawl Box. Having lower than stock gearing seemed to help here.
    This spot however was pretty nasty and I learned something I never knew before.
    Because Auto-LSD worked well above, I decided to run the same gear here: 8th gear with my Marlin Crawler in Low and T/Case in 4-High. It was a struggle. I revved the crap out of the truck and was spinning the tires so much that I was literally getting white smoke from my tires. (Such a dumb system Toyota.) Our Trail Leader was spotting me and he asked what gear I was in.
    Rear tire stuffs nicely.
    According to our trail leader, whose 200-series Land Cruiser is equipped with ATRAC, the computer runs a more aggressive VVT-i programming in Low Range. (I am very curious to know if this is true for the Auto-LSD system.)
    So I shifted out of the Marlin Crawler and put the T/C into Low Range and grabbed 11th gear (2nd gear + stock t/case). It still was not a pretty sight and at a higher final drive ratio I had more tire smoke and more bouncing. I probably should have given up but the Trail Leader was excited to see me make it and gave me the go ahead to keep trying
    Whew! Finally made it! Sorry slickrock and sorry BFG tires. Man oh man this is so not my style of wheeling. I won't go out again without getting the ARBs plumbed in that's for dang sure.
  9. Jun 10, 2017 at 7:56 AM
    #249
    BigMike
    Fresno, CA
    Next there was an optional long steady, sort of a narrow v-grove climb that lead up to a steep and nasty ledge/waterfall. At the base of the waterfall there was a ditch-out route so I went up as high as I could and then bailed. A few people in our group tried the waterfall and only one guy made it. I'd love to return here next year and give it a go!
    Here I am near the top of the v-grove section.
    Here is a pic of Marlin in the Crawler Truck approaching the waterfall. Marlin couldn't get up it despite multiple attempts. I think his tires were over inflated for this sort of obstacle plus he carries by far more dead weight recovery equipment than anyone I know. I'll have to conquer it next year in the Taco for him ;)
    Stopping for lunch
    Nice day for some wheel'n!
  10. Jun 10, 2017 at 7:56 AM
    #250
    BigMike
    Fresno, CA
    At this point it was already close to 3pm and I had a mission that I was on and needed to get up to northern Utah for business. So a few of us took a fireroad back to the highway (including Marlin who needed to get back for the annual Raffle).
    Man I jammed down that fire road. I almost hit redline in 6th gear stock low range a few times. When you open up this V6 and rev it out it's no joke; That sucka can move.
    Here we are airing back up. I am using ARB's new Maximum twin-compressor which works "decently well". It isn't as good as a York and certainly not as good as a RV2 (which I've got mounted to my 3RZ in my Hilux). But for an electric compressor it did well for my lil 33" tires. (I'll be installing a similar setup with an under-the-bed aluminum air tank for on-board air + ARBs.)
    Love that Moab red dust!
    And that was it for me and Cruise Moab 2017!
  11. Jun 10, 2017 at 7:57 AM
    #251
    BigMike
    Fresno, CA
    May 5, 2017: Road trip up to northern Utah
    Back at camp loaded up and ready to take off
    This truck is such a delight to drive on the open road
    I hit 10K miles! I'd normally be very excited but... man an entire year passed and it hit me that after such a strong start I only put in 10K my first year. I got a lot of catching up to do :D
    ShemRahBuck, dorton, nDub and 2 others like this.
  12. Jun 11, 2017 at 6:44 AM
    #252
    BigMike
    Fresno, CA
    May 15, 2017: Rubicon Preparation I
    After Cruise Moab it was time to get serious. Thinking of what I'd like to get done before Rubithon, which has been postponed to the 3rd weekend of July thanks to an excellent amount of snow this year, I decided to get the most time consuming item checked off the list first. :)
    On the road again!
    This time heading to a customer's house who is a good family friend of ours and incredibly gifted with auto body and paint. He has built some of the cleanest rigs I've ever seen and has a great attention to detail, something Marlin and subsequently myself pride ourselves on. I can do many things well mechanical but I'm not so good when it comes to body repair or finishing. I leave that to the professionals and this customer is certainly as professional as they come!
    Finally arrived!
    Hmmm that looks pretty good :D
    mac33, TheTacoma, ExplorHer and 3 others like this.
  13. Jun 11, 2017 at 10:43 AM
    #253
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    I hope those lines are cuts for bobbing the bed and not for painting :)
    BigMike[OP] and nevadabugle like this.
  14. Jun 11, 2017 at 1:36 PM
    #254
    kybluejeep
    kybluejeep Well-Known Member
    Bryan
    2016 TRD OFFROAD 6SPD Manual
    1st dual case 3rd Gen 1st bobbed you're making me feel lazy @BigMike
    BigMike[OP] likes this.
  15. Jun 11, 2017 at 8:50 PM
    #255
    BigMike
    Fresno, CA
    You guys got it! @kybluejeep I have much catching up to do with even the basic stuff :) Things will start coming together soon enough ;)
    May 18, 2017: Rubicon Preparation I: Bobbing the bed (continued)
    The man I have doing the bob is also named Bob ;) and three days later Bob (and his son helping) got to work on bobbing the bed!
    First step was to remove the bedsides. I think it's pretty neat how the bed is designed in this respect.
    Most trim and misc parts removed from bed
    Bob had to move the bed back to access front bolts
    ExplorHer, mac33 and TheTacoma like this.
  16. Jun 11, 2017 at 8:51 PM
    #256
    BigMike
    Fresno, CA
    May 22, 2017: Rubicon Preparation I: Bobbing the bed (continued)
    Because I'll immediately drive the truck home, I'll need my rear license plate. One option is to place it in the back window but beings I'll need to do some custom work to the rear bumper anyway, Bob had the good idea of just leaving the frame at it's original length with the rear bumper attached for the drive home. It'll surely look funny but that is a great idea. Now I'll be able to modify the frame on my own and also know what modifications will be needed with whatever aftermarket rear bumper I go with.
    So a few days later Bob sent me these pics of how they will trim the bottom trailing edge of the SMC bed (sheet-molded composite) to clear the frame rails.
    May 23, 2017: Rubicon Preparation I: Bobbing the bed (continued)
    The next day they had the bed sides off
    Very cool!
  17. Jun 11, 2017 at 8:56 PM
    #257
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
  18. Jun 11, 2017 at 9:32 PM
    #258
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Bob Labla's Bed Bob Job
    nevadabugle likes this.
  19. Jun 11, 2017 at 9:36 PM
    #259
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    I'm just hazarding a guess at how this is going to go:
    1) Buy 3rd gen tacoma
    2) Add crawler to drive-train
    3) Add lockers
    4) Remove back of truck
    5) Remove front of truck
    6) Replace middle of truck with hilux body
    Nickel, BigMike[OP] and nevadabugle like this.
  20. Jun 11, 2017 at 10:06 PM
    #260
    CLOUDL1GHT
    CLOUDL1GHT Well-Known Member
    Garrett
    North Houston
    2023 Tacoma SR
    this is awesome
