BigMike’s Big Journey: New 2016 Tacoma
Discussion in '3rd Gen. Builds (2016-2023)' started by BigMike, Apr 18, 2016.
  1. May 7, 2019 at 7:52 PM
    #861
    BigMike
    BigMike [OP] Applied common sense Vendor
    Fresno, CA
    2016 56-speed 580:1 Triple Marlin Crawler-equipped TRD Sport
    March 31, 2019: Mounted CB Radio & Created a constant Vdd power source (Post 1 of 2)
    Last year I spent some time on TW looking at other 3rd gen owner CB installs and came across a compact Uniden CB mounted under the driver's seat. I spent some time searching for the original post where I saw this, but thank you to the community for posting the many suggestions.
    Uniden CMX760 Compact Mobile CB, Black
    https://www.amazon.com/gp/product/B06XJG6NYB/
    I picked up the CB last July which since then has been floating around in the cab with wires attached. I finally got it mounted under the seat which was so ridiculously easy that even it's mounting bracket lined up with existing Toyota holes :)
    No drilling/modification required
    The allure for me is that the unit is complete hidden; Nothing for would-be thieves to spy through the window. The plug for the hand-held remote is near my center console, and the remote is stored in the glove box. Very happy with how this turned out.
    Next, I've been using a small cigarette lighter-powered refrigerator (some cheap truck-stop brand) which I've wanted to keep turned on while in camp. I hard-wired the cig lighter in my '81 Hilux which was nice but I wanted to take this a step further with the Tacoma so I picked up an adjustable Low Voltage Disconnect (LVD) unit and went to work
    CZH-LABS Electronics-Salon Low Voltage Disconnect Module
    https://www.amazon.com/gp/product/B018TK5WIM/
    This is connected via constant hot power source to the original/factory power outlet located inside the center console. Will be posting more info about this later.
    I tested it overnight with my fridge turned on and it worked great. Using the 10.7 V mode as shown, morning voltage at the battery was 11.2. (The load on the circuit causes an early disconnect.) I know this is unhealthy for a 12 vdc battery but have decided to keep it on this setting to test it over the upcoming wheeling season. For reference, my battery is a Bosch Platinum Advanced AGM 24F-710BAGM rated at 710/850 CCA/CA with a 120-min reserve. It was only slightly weaker during cranking and the alternator was working hard all the way to work haha
    I figure with the amount of time spent with the engine on during a trail ride that it won't be any issue at all. Time will tell and I'm sure I'll be commenting more about this later in the year.
    Here is the steady-state amperage draw (under 10 mA)
    And here is the amp draw with my CB in monitoring mode (~ .3 amps)
    This is post 1 of 2 on this subject. More to come soon
  2. May 7, 2019 at 7:53 PM
    #862
    BigMike
    Fresno, CA
    April 4, 2019: Finally decided to balance my tires
    I've yet to balanced the 40s (seriously!) but due to wearing out the inner tread (mentioned earlier) I decided to have them checked. Weight was added to each wheel but I can't say if I notice the improvement or not. Man... these trucks are just so dang heavy...
    mcharfauros likes this.
  3. May 7, 2019 at 7:53 PM
    #863
    BigMike
    Fresno, CA
    April 7, 2019: Finally began working on interior switches! (Post 1 of 4)
    Next I addressed my interior switch situation. I never properly installed my ARB Rocker switches and as a result the cover for both my compressor and front locker would break off nearly every trip out. Such a weak design. So I decided to go with cheaply-made-yet-expensive factory-style push-button type switches. I'll be posting about these for a few replies. I got most of them from ch4x4.com, a few from Amazon, and a few from eBay. They are in the $15 to $20 range, which seems like a lot for a switch made in China for pennies, but retail on an ARB rocker + cover is $15 so.... whadda ya gonna do
    Replaced this temporary mess lol
    With this awesomeness!
    ...and eliminated a ton of ARB wiring/crap in the process!
    (ARBs come hardwired to only allow front locker operation in combination with the rear, which reduces the stress and therefore risk of front axle breakage on rigs with a factory t/case, but this protection is entirely useless when you have a Marlin Crawler T/Case due to our new level of control and zero bouncing.)
    On this date I *finally* installed a very well hidden Kill Switch (silent type + not in the driver area) which for obvious reasons will not be shown here ;) Which is a bummer because I'm quite proud of how it turned out :D
    old55guy and PB FAB like this.
  4. May 7, 2019 at 7:54 PM
    #864
    BigMike
    Fresno, CA
    April 8, 2019: Finished Constant Vdd power source (Post 2 of 2)
    Here is the finale to my constant power source mod!
    Ripped the console back apart. This pic shows an anti-static bag I put the LVD device in. I could have used some small hobby box but I couldn't be bothered.
    The keen eye will notice in the above image that I've installed a switch next to the factory console power outlet I worked on 3/21. The switch is one of those nice heavy duty 20A metal switches
    Heavy-Duty Electrical Toggle Switch, SPST
    https://www.amazon.com/gp/product/B00004WLK5/
    The current throughput (A) is as follows:
    Switch rating @ 12vdc: 20A
    Low Voltage Disconnect Module rating @ 12vdc: 20A
    Constant power inline fuse: 15A
    (same as factory power outlet fuse)
    All good!
    The switch is thoughtfully positioned as follows:
    1. Down position = off, prevents accidental activation, and
    2. Located to the left side of the power outlet such that it doesn't take up any extra space when the little door is open and the little door helps prevent the switch from being accidentally turned off
    Next, I miss the constant USB power I've installed in my '81 Hilux so I finally got that added to the Taco. Now I can charge my GoPro & cell phone overnight without needing the key in the ACC position.
    X never ever marks the spot. - Dr Jones
    Installed! There are a few of these QC3.0 USB outlets on Amazon and I went with this brand based on reviews.
    The reason I wanted this style device is because I am running this through the Low Voltage Disconnect device set to 10.7v, I can use the digital read-out to check on the current battery circuit (loaded) :)
    YonHan Quick Charge 3.0
    https://www.amazon.com/gp/product/B07FXH5ZZK/
    However at the moment I cannot quite yet recommend this device. Both power outlets work and my iPhone detects amperage at 2.5 A which is good, but the voltage display is off.
    When the YonHan device reads 12.1 vdc (unloaded, steady-state), my multimeter reads 12.38...
    I verified the same 12.38 volts exists at both my dash-mounted power outlet I installed more than a year ago (via ACC key position) and directly at the battery.
    So the YonHan is defective. I've requested a replacement from Amazon and will update this post later
  5. May 7, 2019 at 7:54 PM
    #865
    BigMike
    Fresno, CA
    April 9, 2019: Interior Switch Work (Post 2 of 4)
    The next day I continued work on my ARB & other interior switches by finishing up a 6-port left-of-column switch plate.
  6. May 7, 2019 at 7:56 PM
    #866
    BigMike
    Fresno, CA
    April 10, 2019: Interior Switch Work (Post 3 of 4) and Changed my Engine Oil
    The next day I installed my new 6-port switch plate!
    I forgot to mention that I've seen a few switch plates offered around the Interweb but haven't seen one for 6 switches yet. I'm good with Solidworks and we have a 3D printer, so :D
    Switch plate done and installed!!
    I designed the plate to snap into place so all that was needed was to follow the same horizontal top-and-bottom lines of the original center opening with a Dremel and in it went. Any jagged edges or mis-cuts are concealed by the large flange. This is v1.0 of this switch plate and it works flawlessly. There are a few things I could improve but it turned out well so it stays!
    ARB wires all cleaned up!
    I did have to cutout these parts from the dash on both sides of the original switch opening, which on my Access Cab are not even used. It was a no brainier
    And wa-la! :cool:
    Currently only the ARB/locker switches are connected. More to come soon!
    (Update since then: I moved the three Locker-related switches [the most important of them all] to the far left so my steering wheel doesn't block line of sight to them.)
    Finally, to round the day off I changed my engine oil & filter, and replaced 30K factory transmission gear oil with synthetic Redline MT90, my favorite gear jam'n oil of all time
    Red Line MT-90 Synthetic Gear Oil
    https://www.marlincrawler.com/chemicals/red-line-mt-90-synthetic-gear-oil
  7. May 7, 2019 at 7:57 PM
    #867
    BigMike
    Fresno, CA
    April 11, 2019: Reverse Light Anytime Mod
    The next day I did what I've always wanted to do to my Hilux but never got around to it, and that is install a switch to turn my reverse lights on.
    The purpose for this is that 1) I usually setup my tent directly behind my truck, and 2) my tailgate serves as my camp (dinner) table. Because I've got those high powered 16 watt / 1000 lumen (each) LED backup lights (installed last June), I've been dying to get this done!
    Installed a mini toggle switch here (up is on), hidden and readily accessible when the tail-gate is down and I'm enjoying an evening at camp
    I didn't take any pictures of the install, but here is what you do:
    1. Route a constant hot wire back to either one of your tail lights (fused, I am using a 7.5A but the draw for this setup is only 2.7A @ 12 vdc)
    2. Add an inline switch anywhere on this hot wire you'd like
    3. Tap the other end of the switch into either of your reverse light's red power wire
    This works for both reverse lights because that same red wire is connected to both lights. So it doesn't matter which side light's red wire you tap into.
    DONE!
    But there is an issue:
    If your truck has a backup camera then I found an issue in that if your key is in the ACC or ON position, not in reverse, and you enable the switch, your back-up camera will turn on. This is because your reverse camera display unit "detects" that the transmission is in reverse and brings the camera screen. The only way to avoid this is to trace the red wire beyond between the cab and where it splits to both reverse lights, and install a diode to prevent voltage going back up-stream.
    This issue doesn't apply to my needs:
    My purpose for this is that I used to do the following when I got to camp: Park the truck, engine off, then switch key to ON position and shift into reverse. Lights come on. So instead, now I can leave the lights on for many, many hours (for sure they could be left on overnight without any problem) without having to have the key in the ignition!!
    Click here to view the FSM Reverse Light circuit for reference (PDF). There are two versions for Manual & Automatic. Trace the red wire from the top of Page 2 back to Page 1. This is the circuit we are injecting power to. The reverse camera part of the circuit is not shown in this diagram.
    Reverse lights in action with keys not in the ignition! LED Campground lighting for days!!
    bagleboy, old55guy and mcharfauros like this.
  8. May 7, 2019 at 7:57 PM
    #868
    BigMike
    Fresno, CA
    April 15, 2019: DRL Anytime Mod (Switch Post 4 of 4)
    A few days later I did the opposite which is a forward-facing lower power & high output LED Anytime Mod
    Ever since I saw the 3rd gen's LED DRL back in 2015 I've wanted to do this, these things have just been a very low priority.
    This was so easy to do it was painful. These steps only apply to 3rd gens with LED DRL
    Step 1 of 3: Remove this terminal from the smaller fuse box located in front of your brake master cylinder
    This wire is what the DRL relay uses to send +12 vdd to both LED DRL, and specifically, is the high / full brightness LED circuit.
    ps. I used this el cheapo terminal remover set to get that terminal out. It was a bugger so be patient and don't force it
    Step 2 of 3: Add a new wire directly to this terminal and reinsert the terminal back into it's slot
    Step 3 of 3: Connect this to a switched GROUND and DONE!
    This is the Ground-side terminal of the DRL rely, which itself is (1) already fused (10A) so no additional fuse needed, and believe-it-or-not the other side of the relay is already 100% hot all of the time!!
    Normal operation is that this red wire is grounded by the ECU. So verifying functionality is very easy: Just touch your new wire to any ground source (exposed piece of metal) or run a ground wire straight to the same red terminal under the relay. This will ground the constant-power relay, and thereby turning the full-bright LED circuit on.
    Click here to view the FSM Headlight circuit for reference (PDF). DRL circuit with Relay is on the left side of Page 3.
    Whew those suckers are bright!! Gonna have a lot of fun with this and reverse LEDs for many camping trips to come!
    Got some work to do!
    Extra note on this:
    I first connected this switch to send a GROUND when activated, but later discovered that the switch's light will only "turn on" or illuminate with the DRL when it has a POWER out, not GROUND out. So I had to leave it as a +12 vdd output, which I ran to a relay in order to then have a GROUND output for the DRL anytime mod. This only applies to a picky switch like this...
    The Blue light is bright enough that I cannot miss it even in the daytime when I swing my legs out the driver door. It's right in my face. So having a light to notify you that the DLRs are on of course is a good idea.
    Extra note is that they can be enabled at anytime when you are driving or not, engine on or off, key in or out. They are quite bright and flood all over at night, illuminating street and freeway overpass signs. I'd recommend not using them when driving to prevent shining at other drivers on the road.
    mcharfauros and canadian bum like this.
  9. May 7, 2019 at 7:58 PM
    #869
    13txtaco
    13txtaco Well-Known Member
    Katy Texas
    2013 Tacoma 4x4
    How much air you running on those tires
  10. May 7, 2019 at 7:58 PM
    #870
    BigMike
    Fresno, CA
    April 19, 2019: Some new lighting and..... the Start of a new Era
    I don't have any pictures of the install process, and the pic of my switches above gave this away, but I fitted both 2 x driving/spot lights near my existing Fog/flood lights and dun.. dun.. dun!!! a 22" light bar above my Marlin Crawler winch fairlead. I am planning to install a winch this year and intend to keep the light bar here. There is still plenty of room to reach my hand around to operate the winch clutch, but time will tell...
    Marlin Crawler is a new HardKorr Lighting distributor, give us a call at (559) 252-7295 for inquiries, thanks!
    XD Series 20W LED Work Spot Light (XD140)
    https://hardkorrlighting.com/en-us/product/xd-series-20w-led-work-spot-light-xd140/
    XD Gen3 Series 22″ 168w Dual Row LED Light Bar (XDD550-G3)
    https://hardkorrlighting.com/en-us/product/xd-gen3-series-22-168w-dual-row-led-light-bar-xdd550-g3/
    Got it connected to my new lightbar push button switch and WOW it's really bright!!
    My friends immediately criticized me for installing a lightbar but I figured SlowestTacoma has to have at least one feature that fits in with other rigs lol
    The lightbar is at least relatively low-key for an exposed/visible lightbar and came out nice in my opinion.
  11. May 7, 2019 at 7:58 PM
    #871
    BigMike
    Fresno, CA
    April 19, 2019 (continued)
    That same day a new era for SlowestTacoma began...
    While you guys thought all I was doing was messing around with lights and switches...
    I had been spending MANY late nights, weekend after weekend after weekend...
    Hours and hours and hours...
    This has been so much work. I have 2,065 build pictures since the beginning of this year that the thread will never see.
    The things I could share... The struggles... The improvements...
    Truly, this has been an incredible journey.
    Thank you to my beautiful Wife for putting up with the multiple thousands of hours I've spent on this project.
    Hm.
    Hmm..
    Hmmm...
    Hmmmm....
    Hmmmmm.....
    Hmmmmmm......
    Hmmmmmmm.......
    Hmmmmmmmm........
    You guys have no idea how long I've wanted to say this...
    It has been since September of 2017........................
    OVER 600 DAYS
    To... finally... say...
    GOOD!!!! RIDDANCE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    IT IS FINALLY GONE, LONG GONE!!!!!!!!!!!!!!!!!!!!!!!!!
    OHHHHHH MAN LET'''SSSSSSSS GOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  12. May 7, 2019 at 8:02 PM
    #872
    BigMike
    Fresno, CA
    Thanks for the Q.
    In the city/highway: 34 to 35 PSI, which is high for tires this size, but I prefer to wear out the centers which are less important to me off-road
    While Rock Crawling: 4 to 5 PSI
  13. May 8, 2019 at 12:54 AM
    #873
    canadian bum
    canadian bum Well-Known Member
    Alberta, Canada
    2005 SAC DCLB
    Spacer lift with 42s
    Looking forward to seeing the next stage of your suspension.
    old55guy and BigMike[OP] like this.
  14. May 10, 2019 at 9:32 PM
    #874
    vookie91
    vookie91 Well-Known Member
    Bay Area, CA
    2017 TRD OR DCSB 4X4
    nice
    BigMike[OP] likes this.
  15. May 16, 2019 at 8:28 PM
    #875
    BigMike
    Fresno, CA
    Late April, 2019: RCLT HD Prototype V2.0 is installed!
    Well ladies and gentlemen!! After a crap ton of work I am extremely pleased to announce...
    RCLT HD Prototype V2.0!
    Featuring more than 100 (mostly small) improvements, the biggest being a one-piece integrated double-sheer & angled steering arm--to--wheel hub--to--brake caliper cut via CNC from billet steel to form a 100% solid lower knuckle assembly. Something I couldn't say before is that my original design called for a one-piece CNC billet steel lower assembly but due to time constraints imposed by the King Of The Hammers competition, I had to scramble and whip-up hand-welded plate-steel components which left much to be desired.
    I have also greatly increased strength at the LCA uniball area, with even a bit more strength landing with V3.0.
    Manufacturing for V2.0 was also greatly aided by using full one-piece jigs I designed & created for all six components: D/P LCA, D/P UCA, & D/P HD Knuckle. As a result, despite about a final 20 remaining (mostly small) issues, Rocky and I finished V2.0 in only TWO days as opposed to the nearly 30 days it took to build V1.0 free-hand with the countless issues a first prototype yields.
    As RCLT HD stands currently, I am nearly finished with V3.0 which I am 90% confident will be the final prototype before we make the major shift towards full production.
    Prototype V3.0 is already past Feature Lock with the largest improvements being an enclosed LCA V-Groove saddle (eliminates the need for water drain holes), stronger limit strap mount, dual shock mount (which has been a royal pain in the ass to design on an angled LCA designed for maximum ground clearance), and equipping the 7/8" TREs with larger 5/8" hardware (V2.0 shown here is running 7/8" heims with 1/2" hardware, which is 126% stronger than the single-sheer factory TRE, but we can achieve +253% at no extra cost so whynot).
    I reached Feature Lock for V2.0 two months ago and looking at these pictures now makes me sick to think of all the issues V1.0 had... Such an inordinate amount of work to get to this point and we're only on the second prototype. This project has been no joke folks and it has taken a lot of time, energy, and money to get this far. I'll probably cry the first time I see a kit out in the wild haha It's ridiculous but true :p
  16. May 16, 2019 at 8:30 PM
    #876
    BigMike
    Fresno, CA
    Late April, 2019: RCLT HD Prototype V2.0 is installed! (continued)
    Out with the old, in with the new! We are now an OFFICIAL Radflo distributor!! Please give us a call if you're in the area or looking for a deal on Radflo suspension products! (559) 25-CRAWL / 559-252-7295
    These are custom designed and optimized for RCLT and we will be offering them once things go into production. That said however, other LT coilovers should be compatible so long as they have an upper heim joint mount.
    SWOOOOON!
    DOUBLE SWOOOOON!
    Check out how the axle shaft runs nearly in-line with the lower shock mount at near full down-travel. I love how everything comes together to work as one with RCLT's design!
    The amount of downtravel being demonstrated here wasn't remotely possible with RCLT HD V1.0; So many issues resolved with V2.0. That said, V2.0 still has not yet realized the full downtravel capability of RCLT HD :eek: :eek:
    This is also the improved V2.0 MarRack design (Heavy Duty Rock Crawling Steering) that was featured in this year's King Of The Hammers competition :D :D
    Front axle pushed forward yet another inch over the initial prototype LT setup I've been running since July 2017! Great Scott! Has it been that long...
    Speaking of which, the former Long Travel Kit I've been running since 2017... honestly... was a huge pile of crap. I had NO idea how bad it was until I began comparing measurements with what I am doing.
    This is why I wrote, GOOD RIDDANCE, and I CANNOT WAIT to finally experience RCLT HD myself!!!
  17. May 16, 2019 at 8:32 PM
    #877
    BigMike
    Fresno, CA
    April 30, 2019: RCLT HD Prototype V2.0 is installed! (continued)
    RCLT HD V2.0 IS ALIVE!!!!!!!
    OHHHHH MAN!!!!!!!! I AM SO EXCITED ABOUT THIS!!!!
    THE FIRST OF ITS KIND EVER INSTALLED INTO A TACOMA!!!!!!!
    THE ONLY BOLT-ON IFS SYSTEM STRONG ENOUGH TO
    ROCK CRAWL WITH 40" TIRES AND TRIPLE T/CASE!!
    COME ON NOW!!!!!!!!!! LET'SSS GOOOOOO!!!!!!!!!!
    Testing it on my wild daily driver Rock Crawler setup means it's gonna be bullet proof for everyone else
    Just driving it out to the dirt area next to our building and I was CrAzY eXcItEd!!!
    Updated pic with my Supercharged 6spd MR2 <3
    Finally my front IFS is at least as wide and hopefully wider than the rear. This has been bugging the heck out of me for a long time as I feel Rock Crawlers should always have a wider front than rear to prevent clipping objects during sharp low-speed trail cornering.
    So the front end is now our new & unique +2.75" mid-range Long Travel wider per side, which is +5.50" wider than factory. Right in the middle of +2" & +3.5".
    ..and for the rear I have 1.25" wheel spacers on each side which is +2.50" wider than factory
    Honestly it only looks so wide because I've removed the factory flares. In my opinion the bodies on these "midsize" trucks are just so freak'n wide it's long past ridiculous Toyota, seriously...
  18. May 16, 2019 at 8:32 PM
    #878
    BigMike
    Fresno, CA
    MOAR RCLT HD PORN!!!
    (please ignore the upside down TRE bolt: At the time I was still figuring out limit strap geometry and could only reattach steering after the wheel was installed)
    COME AWN IFS!!!! LET'S DO THIS!
  19. May 16, 2019 at 8:33 PM
    #879
    BigMike
    Fresno, CA
    A NEW MARLIN CRAWLER IFS PRODUCT IS BORN
    Now would be a good place to ask if anyone noticed my sweet Heavy Duty Cam Tab Gussets and Heavy Duty LCA Flange Braces??? Better look again!
    Marlin Crawler has built another FIRST for strengthening the Toyota IFS system for greatly improved performance with Rock Crawling, Desert Racing, Mud bogging, Snow wheeling, or just soild peace of mind for the daily driver!!
    I present to everyone the all-new Marlin Crawler Heavy Duty LCA Frame Brace Kit!
    This kit goes far beyond simply gusseting the Cam Tabs and is so advanced that it is already patent-pending!
    The retail for this kit will be $129, and we'll have a limited time introductory price for only $99
    We are already gathering interest online and preparing for the first production run that will be ready to ship on or before June 7. :thumbsup:
    Please click to view this new product online, and please use the "Notify when in stock" button to be notified once available:
    → Heavy Duty LCA Frame Brace Kit | Marlin Crawler, Inc. ←
    We will create a product announcement thread which will include full details of this AMAZING kit, that in my opinion blows the doors off anything I've seen before
    Initial applications include:
    2003+ 4Runner
    2003-2009 Lexus GX470
    2005+ 2WD or 4WD Tacoma
    2006+ FJ Cruiser
    Many more applications will be coming soon!
    No drilling 24-spot welds and chiseling off 8 camber plates. It can even be installed WITHOUT removing your control arms or altering your alignment :cheers:
    And if you already have upgraded 1/4" cam tabs, no problem, just lightly massage about 1/8" of material off and directly install to your rig. :cheers:
  20. May 16, 2019 at 8:34 PM
    #880
    BigMike
    Fresno, CA
    40" tires? CHECK
    FIRST EVER PATENT-PENDING ROCK CRAWLING IFS SYSTEM? CHECK
    MARLIN CRAWLER TACOBOX T/CASE SYSTEM? CHECK!!!!
    V2.0 is my first Prototype that we needed to ensure proper alignment, so this was my first stab at it.
    To provide a good range for driver preference, I've designed RCLT HD to have 3-degrees caster @ 0-degrees camber when all four eccentrics are rotated up in the neutral/center position. The tech, however, was only able to get 2-degrees caster @ 0-degrees camber with the cams pegged. A few more mouse clicks and I'll have it improved for V3.0 :thumbsup:
    I am however done with this alignment shop I've been using (Discount Tire Center, North-east Fresno). Because I've "modified" my front suspension :rolleyes::rolleyes: they have revoked my 3-year unlimited alignment deal. :rofl: Sucks, but such is life, and now I'm on the look-out for a reputable alignment shop in the Central California area so please let me know if you know of one, thanks!
