BigMike’s Big Journey: New 2016 Tacoma
Discussion in '3rd Gen. Builds (2016-2023)' started by BigMike, Apr 18, 2016.
  1. Jun 1, 2016 at 6:41 PM
    #121
    Mattynokes
    Mattynokes Well-Known Member
    Madison, WI
    18' BLACK Off Road DCSB
    Prinsu Toprac TRD Beadlocks Century Shell
    I guess 4251 for the 81
    And 4201 for the 2016.
  2. Jun 1, 2016 at 6:46 PM
    #122
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    This isn't the price is right!:boink:
    BigMike[OP] likes this.
  3. Jun 1, 2016 at 7:29 PM
    #123
    Jthizz2006
    Jthizz2006 Well-Known Member
    Jesse
    16 black tacoma DCSB SR5 4x2
    That would be awesome
    BigMike[QUOTED][OP] likes this.
  4. Jun 1, 2016 at 9:43 PM
    #124
    LTacoman
    LTacoman Well-Known Member
    Luis
    Gilbert, Az
    2019 F150 Lariat EB
    My guess:
    81 - 4103 lbs
    16 - 4633 lbs
    :thumbsup:
  5. Jun 1, 2016 at 10:21 PM
    #125
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    81 - 3750
    16 - 4850
  6. Jun 2, 2016 at 12:26 AM
    #126
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    1981 Rock Crawler with Triple Transfer Cases and full USA DOM armor: 5275lbs
    2016 Bone-stock 4WD V6 Manual Transmission TRD Sport Access Cab: 4500 lbs
  7. Jun 2, 2016 at 10:37 AM
    #127
    BigMike
    BigMike [OP] Applied common sense Vendor
    Fresno, CA
    2016 56-speed 580:1 Triple Marlin Crawler-equipped TRD Sport
    Excellent guesses you guys :)
    Nickel
    1981 4,250 12.4 percent error
    2016 4,200 5%
    ExplorHer
    1981 3,980 5.3%
    2016 4,480 1.4%
    Mattynokes
    1981 4,251 12.5%
    2016 4,201 5%
    LTacoman
    1981 4,103 8.5%
    2016 4,633 4.8%
    nevadabugle
    1981 3,750 0.8%
    2016 4,850 9.7%
    JimBeam
    1981 5,275 39.6%
    2016 4,500 1.8%
    The correct weights are, drum roll please!
    1981 3,780 lbs
    2016 4,420 lbs
    ExplorHer had the closest average guess accuracy of 3.35% to actual so he gets the Hat! Haha that was pretty fun, I'll have to think of some more ways to do something like this with this build :D nevadabugle was only 30 lbs off from my Hilux! :eek: Nice guess
    I was thinking the Tacoma would be 500 pounds heavier. I knew my Hilux is on the light side. I built it to be light and efficient. It turned out to be 640 lbs heavier. According to some quick searches, a stock 1981 4WD weighed in at 2,975 to 3,065 lbs. So if we assume 3,000 lbs, then I've got 800 lbs of Rock Crawling equipment. The Tacoma could potentially become close to 5,250 lbs! Holy moly! From where I come from this is pretty heavy and any weight makes it that much harder to get up a trail. Gonna be fun wheeling this Taco! Seriously can't wait!!
    Hilux
    Tacoma
    I didn't realize I could have parked on two different cement slabs or else I would have gotten individual axle weights. Bummer.
    nevadabugle and JimBeam like this.
  8. Jun 2, 2016 at 1:05 PM
    #128
    ExplorHer
    ExplorHer Question Authority
    Near Pittsburgh
    2016 4cyl, 5MT, 4x4, 2 seats, dents, & rust
  9. Jun 2, 2016 at 1:33 PM
    #129
    BigMike
    Fresno, CA
    Wednesday, April 27, 2016: Rock Sliders
    First official day back at work and I got All Pro's brand new 2016 "Extreme Duty" APEX Rock Sliders installed. These are built from 1.75" x 0.125" USA-made DOM tubing with four x 2" square legs per side. Not only DOM but also 4% thicker walled than their standard sliders. On my Hilux I am running our old USA-made DOM sliders that are 0.120" and I have come down on them so HARD at times that once the impact killed the engine. Not sure why but it did. Yet they have only sustained small dents. USA-made DOM tubing is the REAL deal. None of this imported Chinese recycled lawn chair CRAP that other companies sell. (See my USA HREW vs Imported DOM tech article. You get what you pay for!)
    Knowing the Tacoma is heavier I wouldn't want anything less than these: In my opinion Rock Sliders are the #1 most important piece of body armor so on they go!
    The Tacoma enters our back shop for it's first time!!
    Had the sliders painted and ready to go on. First time ever installing "bolt-on" body armor and I thought the fit was pretty good. We had to elongate one hole on each side but otherwise it was pretty straight forward.
    The plan is to get these mounted and good to go with just spray paint, and then in the near future take them off and get em properly powder coated. You'll never know if some minor grinding is needed so better to just get em on now and worry about long-term paint later.
    SilverII likes this.
  10. Jun 2, 2016 at 2:20 PM
    #130
    BigMike
    Fresno, CA
    Weight is 73.2 lbs each. Probably 150 combined with hardware. Whew. They are available without the dimpled plate. I'm not a big fan of the plating, but, it adds more strength and as much as I don't like formed bumpers I'm probably not gonna have much of a choice. So might as well match the sliders to whatever bumpers I decide to run. (Currently I don't like any bumper I've seen for the 2016 and have already conceded that tube alone won't pan out.)
    Getting them in place and installing...
    I am certainly not a fan of this very large gap between the bottom of the door and the top of the slider. Rough measurement has this at a 2-3/8" gap. That is 2.375" of ground clearance... But, more on this later ;)
  11. Jun 2, 2016 at 2:23 PM
    #131
    BigMike
    Fresno, CA
    I do like the 2"x2" square legs. Pretty stout.
    You can see tapered hardware along the bottom. The hex head bolt is an OEM Toyota bolt. Obviously I'll need to convert that and any others to a low profile / tapered bolt. I think ideally they should be tac welded once I'm satisfied with everything. Don't know if I like the idea of bolts alone. Probably this is just my old ways clouding my thoughts.
    There is a stamped steel bracket whose sole purpose is to just hold two plugs. No wonder this truck weighs 4.4 thousand pounds! I'd like to scoure much of the truck for silly uncessary weight like this and get em removed. For now I just zip tied it up and out of the way.
    All done!
  12. Jun 2, 2016 at 2:26 PM
    #132
    BigMike
    Fresno, CA
    Took it out to the dirt for some pics :D
    I am VERY pleased with these. Very nice work AP!
  13. Jun 2, 2016 at 2:26 PM
    #133
    BigMike
    Fresno, CA
    I also like how the kick outs are muted. I was never a fan of the All Pro Hilux sliders because of how far out the kick out is on those but this is much less pronounced and I like it. Nice change.
  14. Jun 2, 2016 at 2:27 PM
    #134
    BigMike
    Fresno, CA
    Here is another shot of the gap between the door and the slider. I can stack three fingers between the two. Will discuss more on this later.
    The dimpled plate does look great once installed I have to admit.
    View from the rear door
    View from the driver's seat
    SilverII and Travis11 like this.
  15. Jun 2, 2016 at 5:53 PM
    #135
    dorton
    dorton rockcreekoverland
    Winston Salem NC
    2016 TRD Off Road
    Old Man Emu Nitro Chargers, CS047R leafs w/ D29XL extra leaf, CBI front and rear bumpers, CBI armor, rock sliders,ditch light brackets, and bed rack, Free Spirit Recreation Extreme Series roof top tent, VTX Viper wheels, General X3 Grabber tires, 4.88 gears front and rear, Kenwood TM-710G UHF/VHF radio. Icom IC-706MKIIG UHF/VHF/HF radio,KC Hilites 20" Flex Bar and ditch lights, Safari snorkel, BedSlide Classic, SnoMaster USA expedition series fridge.
    The sliders look great.
  16. Apr 12, 2017 at 12:06 PM
    #136
    ExplorHer
    Near Pittsburgh
    Any progress on this Tacoma @BigMike?
    BigMike[OP] and nevadabugle like this.
  17. May 2, 2017 at 10:53 PM
    #137
    BigMike
    Fresno, CA
    Hello TW!
    Ohhhhhhhhhh man. What. A. Year. Whew. I am sorry to say that I was only able to barely touch the Tacoma last year. The timing from the 261 day delay was horrible and I didn't line things up as quickly as I should have in preparation for the busy season. I took the Tacoma out on two trails and then the wheel'n, marketing, event sponsorship season kicked into high gear and I was too busy to work on it. Many more reasons preventing progress on the Tacoma such as a lot of restructuring here at MC and my wife and I purchasing our very first house!
    Over the last month I've been making some good progress preparing for this year's wheel'n season so let's get this thread back up to speed!!
    April 28 & 29, 2016: New Grille
    My 1987 MR2 has a white-black Panda theme which I like so the Chrome TRD Sport grille has gotta go :D
    I ordered a SR5 grille but when it showed up I discovered it had a grey shade to it...
    So I did some quick research and realized I should have ordered the "SR" grill. The next day I picked that up for comparison and was happy with it. Returned the SR5 grille.
    SR left -- SR5 right
    SilverII and nibrwr like this.
  18. May 2, 2017 at 10:53 PM
    #138
    BigMike
    Fresno, CA
    After work I swapped out the grille. Wow that was so easy. It is readily evident compared to my Hilux how things are better designed for mass-production.
    Old grille off
    New SR grille on
    I like this much better :D
    Lastly, not sure if I covered this, but I set-up my background image as a pic from Zion National Park
  19. May 2, 2017 at 10:54 PM
    #139
    BigMike
    Fresno, CA
    April 30, 2016: TLCA's Annual Bakersfield Land Cruiser Swap Meet
    Broke the truck's event cherry at the Toyota Land Cruiser Association's Annual Bakersfield Swap Meet
    Leaving Fresno. Love the LED driving lights. They dim quite a lot once the headlights are turned on. I plan to override this feature.
    At the Land Cruiser event in Bakersfield:
    We had the Tacoma parked next to our booth featuring our newly updated MC11 Tacoma/FJ Cruiser Dual Case Unit
    As you can see this one is for the 1GR-FE ("TACO BOX 4.0"). This should be very close to what will be installed in the new Tacoma, minus the nifty cutaway ;)
    Here is the Tacoma with Kay Spector, the widow of Marv Spector, who is essentially the Marlin of the Land Cruiser World (see our Marv Spector Tribute Album here).
    From left to right: Marlin, Kay, Christine, Myself
  20. May 2, 2017 at 10:54 PM
    #140
    BigMike
    Fresno, CA
    April 30, 2016 (continued): Road Trip to Los Angeles
    After the event my wife and I continued south to Los Angeles to pick up some Supercharger parts for my MR2. We've hit 3,000 miles in only ten days!
    Random lunch-stop pic
    Near Santa Monica, CA
    Finally back home. I have no other 6cyl truck experience but the fuel mileage through two mtn ranges combined with the idiot drivers who make up the notorious LA traffic was decent:
    Edit: fixed incorrect picture order
