bike rack attachment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nurseboy, Jun 2, 2009.
  1. Jun 2, 2009 at 9:28 AM
    nurseboy
    nurseboy [OP] Well-Known Member
    Jan
    Riverside, Ca
    I just bought beach cruisers for my girl friend and I and I was just wondering/wanting suggestions on where to buy bike racks. Should I go with the one that attaches to the roof rack or get the attachment like this one...
    this one cost $54 dollars I believe and I have to use the existing bed cleats for it. Any suggestions or comments? Will my beach cruisers fit this?
  2. Jun 2, 2009 at 9:36 AM
    argm31i
    argm31i Well-Known Member
    Try Rocky Mounts
    http://www.rockymounts.com/clutch
    Roughly the same price, and you don't have to use up a cleat.
    I've been using one of their clutch fork mounts and some extra of the hardware they talk about to integrate it to the tiedown system (bought a wheel holder and use the Rocky Mount hardware to attach it to the bed so it won't move around) for over 2 years, and I can't complain at all.
    EDIT: You want the Clutch SD towards the bottom. Also, if you call they will sell/send you some of the extra hardware. Also, their screws are torx, and that's better security because someone's unlikely to have one of those on hand to steal something.
    One other quick question: if it is a beach cruiser, you may want to be sure that your front wheel(s) have quick release axles. Otherwise, it will be a pain using a mount that requires removing the front wheel.
  3. Jun 2, 2009 at 9:41 AM
    nurseboy
    Jan
    Riverside, Ca
    Which one did you purchase? From what I read the Clutch SD has everything i need including the "extra hardware" you bought. I like this because I dont waste any of my bed cleats and this is like an extra tie down..
    NM. I answered it right when I was posting...thanks. I think the front tires comes off just 1 bolt. I don't think its like a quick release mechanism
  4. Jun 2, 2009 at 9:41 AM
    SuperWhiteDC09
    SuperWhiteDC09 Active Member
    Columbia SC
    2009 Tacoma Double Cab SuperWhite SR5
    Extang Tonno III, Toyota Tow Package, Reese receiver lock, and hopefully lots more soon.
    Hey if I were you I would make your own bike rack and save some money.
    Buy two of these
    http://www.performancebike.com/bikes/Product_10052_10551_1031488_-1_400019_400007_400172
    then go to lowes and buy washers (eight i used two washers per bolt)the same size as the metal part on the tie down clamps that fit into your bedrail. then use the bolt and nuts that come with the fork clamps and mount them right onto your bed rail. It looks really slick and saves you money. Send me a message if you have any questions.
  5. Jun 2, 2009 at 9:44 AM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    If you go the DIY route, I believe using 2 washers in the bed rail is key. I did this but only used 1 washer. After mounting the bikes on the mount and tightening down the bolt, the washers bent. It's definitely possibly to make your own though. I used JB Weld on mine to hold the nut to the back of the washer that the bolt threads into.
  6. Jun 2, 2009 at 9:47 AM
    argm31i
    Sounds like that would work, too.
  7. Jun 2, 2009 at 10:00 AM
    nurseboy
    Jan
    Riverside, Ca
    This is somewhat confusing? What same size bolts are you rtalking that fit into my bedrail for the tie down clamps? If you are talking about the bed cleats, those are not physical screwed into the rail with a bolt? and with this system, I don't see any holes in the product itself to bolt it down into the rail...can you take pictures of yours?
  8. Jun 2, 2009 at 10:05 AM
    SuperWhiteDC09
    Columbia SC
    I am talking about the bolts that would come with the bike clamps. You need to find washers that are the same size of the bed cleat that came with your truck so you can secure the bike clamp to the bed rail the same way that your bed cleats clamp to the bed rail.
  9. Jun 2, 2009 at 10:12 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Scored 2 of the locking rocky mounts clutch. Thanks above for the link.
  10. Jun 2, 2009 at 3:19 PM
    nurseboy
    Jan
    Riverside, Ca
    If you mount bikes to these type of mounts, don't you usually have to remove the front wheels anyways for the fork up front to attach to the bike mount?
  11. Jun 2, 2009 at 3:26 PM
    argm31i
    Yes, but most mtn. bikes have a quick disconnect front wheel. Unless you have that on your bikes, you'll have to have a tool (sockets, etc.) to remove the front wheel of the bike. The quick disconnect ones have a little lever that you just "open" (kind of like the mounts) vs. the ones that don't have it just have a nut on either end of a bolt that is the axle.
  12. Jun 2, 2009 at 3:28 PM
    nurseboy
    Jan
    Riverside, Ca
    K yea. I bought Paul Frank beach cruisers and both front tires don't have quick release axles to remove the front tires, they require you to bolt them on and off, but I don't really mind doing it. Its just a bolt per bike. And I don't want to spend hundreds on other bike mounts that can go on the roof rack that don't need the tires to be removed.
  13. Jun 2, 2009 at 3:35 PM
    argm31i
    Cool deal. Won't really be that big of a deal unless you're carrying them all the time from place to place. Was just making sure you knew it'd be more of a hassle than the roof mounts to use. Hope whatever you choose to do, it works well for ya!
  14. Jun 2, 2009 at 4:58 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
  15. Jun 17, 2009 at 4:41 AM
    tjbee2003
    tjbee2003 Member
    09 Off Road
    Isn't there a way to transport bicycles without using a rack and just use tie downs instead?
  16. Jun 17, 2009 at 4:46 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    To both of you I say get the motorcycle tiedowns that have hooks on both ends with the cleat thing in the middle that you just pull on to tighten. I use these for the cruisers I have or for any other bike when you just don't wanna pull the wheel off. They come in real handy when you just wanna jump in someone else's rig & they don't have any mounts too or for that 3rd bike facing backwards in the middle of 2 others already using the mounts. The hooks are coated & they are open enough to go over handlebars or grab to brake lever mount, many options on grab points. I'll try to find pic of them..........Here, cam straps, check these out, comes in different colors. Just hook hooks on both ends & pull tight.
    http://www.strapworks.com/ProductDetails.asp?ProductCode=MOTOCS2N
  17. Jun 17, 2009 at 8:13 AM
    nurseboy
    Jan
    Riverside, Ca
    how do these work? and I id want something i can lock down onto the truck so i know its secure if i ever have to walk away from it.
  18. Jun 17, 2009 at 8:27 AM
    tacomatx
    tacomatx Well-Known Member
    Sambeux
    ATX
    05 Black Tacoma Doble Ca w/ 3in lift
    3in lift Satoshi Grill blacked out head lights and tail lights
    I have the one in the top pic that mounts into the factory rail system and it works like a champ!!!
  19. Jun 17, 2009 at 8:33 AM
    sockmonkey
    sockmonkey Well-Known Member
    Greg
    Benbrook, SW Fort Worth
    2007 White Dbl Cab Pre-Runner
    Volant Ram Air intake,URD MAF calibrator, Mr Marv 10" sub box, Alpine HU, Alpine Amp, fog light mod, scan gauge II, RAAMmat front and rear doors, Wet Okole seat covers, blacked out dash. blacked out front bumper. American Racing Mojave Teflons wrapped with 265/70/16 Pathfinder AT. NST Lite Pulleys
  20. Jun 17, 2009 at 10:37 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    As long as you're not trying to haul multiple toys like this.............
    ...or let's say 2 kayaks on top. Handlebars to high with bedrail mounts. That's when you need the straps or the fork mounts mounted to a board on the floor of the bed. Options, gotta have options. No one thing works in every situation.
