Bike rack, trailer hitch mount, wobbles?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nvdeserted, Jun 25, 2009.
  1. Jun 25, 2009 at 9:35 PM
    nvdeserted
    nvdeserted [OP] Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Howdy,
    I got this old hitch-mount Yakima bike rack, for some reason it has just enough play/gap that the bikes end up swinging side to side about 6". I don't want to shim it because I don't usually have it on for more than a day at a time. Is there some kind of bracket that goes on and off quickly that will "snug" the rack? And yes, I currently use bungee cords to minimize the movement... I just want the rack to be ridgid.
  2. Jun 25, 2009 at 9:54 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    If the male part that slides in is just a little sloppy, lay a couple weld beads just in from the corners and hit it with a disc grinder.
    A couple test fits and you should be able to make it a nice snug fit.
    I do this to our boom stands on our truck cranes when they get sloppy from shaking back and forth
