Bili 5100/ eibach springs question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Card1, Jan 18, 2014.
  1. Jan 18, 2014 at 11:39 AM
    Card1
    Card1 [OP] Well-Known Member
    Georgia!
    96 taquito
    Doestch Spindles
    Hey guys, first post! I have a 96 2wd taco 2.4, already ordered the 51's and coils, they're currently chillin in the toolbox of my truck. The trouble i'm having is that my truck's front end suspension is mounted up with bar pins. My personal mechanic told me it couldn't work but i'm refusing to take that answer. I've heard of BPE's that zone makes and a few other companies.. I'm wondering if they're the same measurements though. I haven't come across someone (online) with another toyota that has bar pins. i'm seeing alot of jeep forums however and as i said, i'm wondering if they have the same dimensions. (2.5" from each bolt center):confused::confused:
  2. Jan 18, 2014 at 12:03 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Toytec says very clearly that their lifts do not fit 5 lug trucks
  3. Jan 18, 2014 at 12:09 PM
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    I found a few websites that said its universal for tacomas. The trouble is that (this is what local autozone told me) when they put together tacomas in their beginning that toyota used spare parts from the older pickups. Because when my brother (previously owned my truck) was replacing the brake calipers, none of the tacoma ones fit and he ordered (idr the year) but he ordered some for an early 90's yota and they bolted right up. i'm thinking this applies the same with my suspension issue cause my truck also doesn't have the 3 bolts above the strut mount. pics later if needed.
  4. Jan 18, 2014 at 12:13 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    as far as i know 5 lug suspension is totally different from 6 lug. Ive heard places like fat bobs garage make lifts for 5 lugs. Call toytec and ask but I'm 99% sure they def won't fit your truck
  5. Jan 18, 2014 at 12:19 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    That's why it won't work then haha
    You said yourself that it doesn't have the 3 bolts for the top hat, which 6 lugs have.
    There's just not a way for you to use 6-lug suspension without a lot of modifying. Sorry.
  6. Jan 18, 2014 at 12:51 PM
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    Not trying to be ignorant to what you guys are saying, i understand that. You can see with my truck that the top bolt is still visible and that's all that's required for the shocks to mount up (at the top)
    Now with the bottom end, my truck uses bar pins for the shocks to stay in place. This company (primarily for jeeps) makes a part that allows your rig to be universal to different kind of shocks. I've seen DIY options where people have a 90 deg. bent slab to mock this setup and a plate at the bottom to show that it's stable. But this is the basic setup. (please tell me this is coming together with you guys??)
  7. Jan 18, 2014 at 1:56 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Totally off topic, but do you work out at Freedom Fitness now Momentum Fitness?
  8. Jan 18, 2014 at 5:21 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    If you really want to try it go for it. But I'm pretty sure it won't work, seems like everything is just wrong about it.. My advice is return the lift and Pursue a lift designed for your truck. Try posting in the 5 lug section, you might get more advice in there
  9. Jan 18, 2014 at 8:41 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Can you take some pictures specifically of the lower shock mount, along with the upper and lower spring bucket/perch?
    My thought is that you can fit a spring in there, as long as the spring diameter is correct. I'd measure and see if the two match. Beyond that, look at your shock mount setup to see differences there...
  10. Jan 18, 2014 at 10:16 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Dude..
    your a 5 lug tacoma
    You only have 5 lugs holding your wheels on..your a 2wd truck with SUA rear setup and VERY different front end suspension.
    the 5100s/Eibachs will NOT fit on your truck. THe shock is like 2x as long as you need and so is the coil.
    Sell them and get something else.
    You won't be able to find much for lifts.
  11. Jan 18, 2014 at 10:23 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    This
    OP, i used to have a 5 lug and the only way to effectively lift a 5 lug is with spindles, body lift (not recommended), and coil spacer.
    Here's my 5 lugger build http://www.tacomaworld.com/forum/5-lug/239484-95-tacos-build.html
  12. Jan 19, 2014 at 11:41 AM
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    Ohhh ok i see what you guys are getting at now.. If i can mcgyver a BPE than i'll give it a shot and let ya know how it goes. Will take pics later of it.
    And yes, i'm the short, stout mf'er that goes with ben sometimes in the green yota/ grey s10 haha
  13. Jan 19, 2014 at 4:10 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    lol there's no McGyver method. no secret TacomaWorld mod. no effin way possible.
    the last "McGyver" that tried to ghetto rig his 5 lug got laughed out of three of his own threads.
    buy a 6lug, amigo :D
  14. Jan 19, 2014 at 4:15 PM
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    I mean, i would but i have way too much connection with this truck. Story time?
  15. Jan 19, 2014 at 4:25 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Build thread time! All were saying is that lift won't fit man. Good for you for being sentimental with your truck, I feel the same way about mine and I will never sell it
  16. Jan 19, 2014 at 4:39 PM
    95 taco
    95 taco Battle Born
    The ONLY way you'll get that lift to fit would be to cut your front suspension off and weld mounts in the same spot they are on a 6 lug, then stick 6 lug arms on it.
    But if you did that you might as well throw a solid axle under it.
  17. Jan 19, 2014 at 4:44 PM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    I know I know, same here. Ive been waiting to up to full 4WD but goddamn it I love my truck.
    if you want a different suspension you have two routes:
    1. solid axle swap
    2. full long travel
  18. Jan 19, 2014 at 5:03 PM
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    My buddy has a 98 taco and he's giving it an SAS. i've thought about long travel or i beam it.. probably long travel though cause i've heard you have more of a chance with breaking the bead on the tire while landing jumps. i don't jump much but yeah, long travel would probably be my best bet.
  19. Jan 19, 2014 at 7:56 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Thought so, I'm the guy who drives the lifted silver Tacoma (my profile pic)
    We should off-road sometime
  20. Jan 19, 2014 at 9:31 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    :facepalm:
    jesus christ dude. if a website that specializes in suspension parts for our trucks says it wont fit...why the hell would you buy it?
    almost everything about the 5 and 6 lug suspensions are different. you cannot use 6 lug struts on a 5 lug coil bucket
