Bili 5100/ eibach springs question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Card1, Jan 18, 2014.
  1. Jan 20, 2014 at 11:32 PM
    #61
    Card1
    Card1 [OP] Well-Known Member
    Georgia!
    96 taquito
    Doestch Spindles
    :cool::D On the hunt!
  2. Jan 20, 2014 at 11:35 PM
    #62
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  3. Jan 20, 2014 at 11:41 PM
    #63
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    If it has taken you this long to grasp this simple suspension concept I hope to god you never attempt an engine swap
    No. Would not make enough difference to Make it worth it.
    You should sell the shocks and coils (or return) and just buy a fat bobs kit or something if you are that set on lifting it
  4. Jan 20, 2014 at 11:51 PM
    #64
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    Thanks!
    Already have spacers, they've been on it for a damn while now. Should I replace them if I go with the S coils? They're cracked and probably beyond compressed.
  5. Jan 21, 2014 at 12:22 AM
    #65
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    "Much"?????? Why the hell would you intentionally jump a vehicle that is in no way shape or form, intended to be "jumped" even the slightest bit? The only reason it should be off the ground without the proper suspension and limit straps is if it's on a lift....a mechanical one.
    And why the hell would someone CUT a spring rated at 620lb, down to an acceptable length just so it'll clear the UCA and LCA? Why wouldn't you just buy the right shit to begin with????
  6. Jan 21, 2014 at 12:26 AM
    #66
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    Bro chill, I'm a highschool senior with a low asvab score, trying to have fun before I leave for parris island this summer. In the service, depending on where I'm stationed I'll either fully mod this truck or get a powerstroke
  7. Jan 21, 2014 at 12:33 AM
    #67
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    Somehow I'm predicting you would/ will buy a 6 liter too........
    Good luck in the marines though. Thanks for your intended service.
  8. Jan 21, 2014 at 12:37 AM
    #68
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    Thanks, I was thinkin 7.3 ;) haha or a newer taco. Depends on what's out there
  9. Jan 21, 2014 at 12:39 AM
    #69
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Why not?
    Good motors once you delete the EGR, put a turbo timer on it, and keep a eye on the EGT's
  10. Jan 21, 2014 at 12:48 AM
    #70
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    7.3's are more preferred. Taquito time though, has it been brought to extend the top hat/ section to clear bigger coils? I feel like it could work with the right measurements. I'd probably follow through with UCA's also.
  11. Jan 21, 2014 at 1:07 AM
    #71
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    Disregard. Custom tacos members are saying that the v6 springs pick up a reg cab. I'll probably get 1" lift shocks along with them for a smoother ride.. I've seen procomp has some but are there any better ones? PC I've heard are.. Eh. Stiffer than desired
    chirp *
    So total setup I'm thinking is the v6 coils, whatever shocks are best, bilstein 1" if I can find/ if they make some (they make for the rear but not sure if fits a 5 lug) where was I.. Coils, then shackles, and depending on how I like the stance I might throw on a 2" bodylift if I'm comfortable with 32's. The truck will be regeared with a locking diff. Perfect. How's it sound guys?
  12. Jan 21, 2014 at 2:22 AM
    #72
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    That's highly debatable...from both stand points.
    You're forgeting about the head gaskets and injector issues too.
  13. Jan 21, 2014 at 2:59 AM
    #73
    95 taco
    95 taco Battle Born
    Honestly OP, I'm not sure
    Head gaskets are fine as long as you don't try to mod the engine to much
    Injectors go out at about 200k on the cummins to (mainly because of the ultra low sulfur diesel) an the cummins injectors are 3x the cost I the ford.
  14. Jan 21, 2014 at 4:32 AM
    #74
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    I think i'll go for it. I know it's extremely unreccomended to stack coil spacers but what if i extended the housing up top so that nothing would be able to get out of whack? My thought would be the v6 coil, 2 coil spacers and a 2" lift shock. Not sure though, that sounds kind of sketchy but can someone good with suspension double up on this? I mean, it looks good in my mind but not sure how it'd actually pan out. I could draw it up to show how far the housing would come down
    Also if I went with the extra spacer, I'd probably follow through with aftermarket UCA's. Still not sure though.
  15. Jan 21, 2014 at 6:57 AM
    #75
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    First half of the sentence explains all this.. And the first word.
  16. Jan 21, 2014 at 7:16 AM
    #76
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    Aye you're not gonna live forever. Just tryina get in depth answers for truck questions. And I'm aware of the search bar
  17. Jan 21, 2014 at 9:16 AM
    #77
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Ok again you have no clue how your suspension works do you? If you put shackles on you will end up lowering the rear, if you put blocks in you will lower the rear. To lift the rear you need an add a leaf DESIGNED for your truck, or a new leaf pack.
    With your proposed hodge podge lift I don't think you will be able to clear 32s without a 2" body lift so you might be forced to get that regardless. And guarentee people will tell you they are shit....because they are. 1" is the highest bod lift you should ever go, but again I don't think it will be enough.
    Then there is the regear and locker...do you know how much that will even cost? Based on your budget concerns I don't think you will like the bill. Regardless of that even if you can afford it I think all of this is a giant waste of time and money that is going to be spent to on a 5 lug taco that was never meant to go off road. It's just stupid and not worth it. The way to do this correctly is to just sell the trucks and buy a 6 lug and start with the correct platform. Then at least when you order parts hahazardly without reading the big bold letters there is a better chance they will actually fit.
    Please just stop, really. Your posts are giving me cancer. Absolutely in no way shape or form should you stack spacers. That's fucking stupid and unsafe and I doubt it would even work or fit.
    fuck me that explains everything!! Good god
  18. Jan 21, 2014 at 10:24 AM
    #78
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    Who needs Netflix? :popcorn:
  19. Jan 21, 2014 at 10:45 AM
    #79
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    You ever heard of lift shackles? Read it up, fuck tard. I'm really sacrificing my life in the next few years for ignorant bastards that can't Bs with me on the internet? Fucking chill you douche bag.
  20. Jan 21, 2014 at 11:01 AM
    #80
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    Anyone actually interested in fabbing.. Other than this guy.
