Billet Aluminum Thermostat Housing for 4.0L 1GR-FE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1GR-FE<3R, Oct 20, 2022.
  1. Oct 20, 2022 at 11:21 AM
    1GR-FE<3R
    1GR-FE<3R [OP] Well-Known Member
    Cody
    Our Billet Aluminum Housing!
    We are ditching the factory Toyota spring loaded thermostat for a readily available thermostat at any auto parts store with different temperatures available (Toyota stock is 180°, We will also offer a 160° for those who request it that are tuned/performance) Standard we will be including a high flow 180° thermostat. The thermostat we include is superior to a factory Toyota thermostat which relies on a rubber flap style seal. The thermostat included in our kit utilizes a brass seal design. The thermostat application is for GM 8.1L engines. They are readily available at any auto parts store in stock.
    We also ditched the leak prone factory flat style Toyota o-ring. Our billet aluminum housing uses a generic thick gauge heavy duty o-ring that provides a stronger seal then the factory Toyota o-ring. The o-ring for our billet housing is readily available at any auto parts or hardware store as well. We will be listing the replacement part numbers for o-ring and thermostat and make the info readily available to everyone should it be needed.
    I have changed a couple dozen factory Toyota housings due to failing plastic/leaking, allowing coolant to leak past the factory o-ring! In a couple cases I actually found the fingers broken that have the job of holding the thermostat in place! One instance lead to a blown head gasket due to the thermostat being sideways!
    Other benefits. Our housing does not use the factory Toyota alignment pin which requires a “tang”to be molded inside the thermostat housing. Our billet housing does not have this “tang” resulting in a more free flowing housing. Less pressure and strain on the water pump and cooling system. A small increase in flow through the cooling system has multiple advantages. Internal combustion engines have colder and hotter spots naturally inside the motor, an increase in coolant flow reduces the hot spots throughout the motor. Leading to an increase in engine durability; common head gasket failure is due to these hotter spots inside the engine. With a more balanced/cooler engine temperatures come increased performance. Detonation, knocking, and/or pinging are less likely to occur. When this occurs the computer makes an attempt to protect to engine, it will retard timing and increase fueling, leading to a drop in performance/power/mpg. In tuned applications, timing may be able to be advanced more due to this increased cooling system performance.
    And lastly we have a spot located for drilling and tapping our billet aluminum housing at request for an additional coolant temperature sender or switch!
    You guys need to see it in person to appreciate the quality. All made in the USA, all US materials by a family owned machine shop!
    Normal pricing we will be selling these for $150 free shipping plus tax on the store with thermostat of your choice assembled and ready to install.
    I have been given permission from the business partners to initiate a Toyota group & forum $10 off presale. We have our first batch of 100 one week away from being ready.
    Please send me a message, text or give me a call! 100% a normal car enthusiast stoked to have his part available to the world!
    Cody Anderson
    (805)432-1454
    $140 free shipping & no tax on the presale!
    Factory plastic housing
    B7D51A18-FBB9-4DD4-AAB6-837A672D7337.jpg FEF51135-6045-4C3A-A5E6-63E579989E50.jpg
    This is the plastic “tang” inside of the factory plastic housing.
    For those interested! The housing will not be listed on the website for some time…
    https://stores.unleashedcustommachining.com/
    It will also be listed on the eBay store here!
    https://www.ebay.com/str/reapercustoms805
    McHale, Dan 77, cmoore and 3 others like this.
  2. Oct 20, 2022 at 11:29 AM
    dezrtdood760
    dezrtdood760 Active Member
    Palm Desert, CA
    2008 Tacoma 8P4 AC 6SPD w/85k miles
    any more pics, with it installed? any data showing the benefits?
    1GR-FE<3R[OP] likes this.
  3. Oct 20, 2022 at 11:42 AM
    1GR-FE<3R
    Cody
    Of course!!!!
    9710772C-46AA-494A-8BAA-8ACAFBD501C3.jpg 515E4A31-FBD0-44E7-BF1C-2237ABAEF4AA.jpg
    We have completed a free flow test (unpressurized test) and our housing flows substantially better then the factory plastic housing! We are still waiting for the results on the pressurized test!
  4. Oct 20, 2022 at 11:46 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    How does this clear with a trd/Magnuson supercharger? Apr had cut a recessed part on the back of the t stat on their thermostat housing. I am interested for sure.
    TodayWasTHeDaY likes this.
  5. Oct 20, 2022 at 12:02 PM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I will be replacing my radiator, thermostat and hoses in the near future.
    I am interested.
  6. Oct 20, 2022 at 12:59 PM
    1GR-FE<3R
    Cody
    They are going quick! We have over 20 presold!
  7. Oct 20, 2022 at 1:06 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    When will these be available?
    1GR-FE<3R[QUOTED][OP] likes this.
  8. Oct 20, 2022 at 1:10 PM
    1GR-FE<3R
    Cody
    We will be shipping out all presale orders no later then 10/31! I am hoping to get them out sooner!
    They will not be available on the website or eBay until sometime in November!
    ARB1977[QUOTED] likes this.
  9. Oct 20, 2022 at 1:30 PM
    ARB1977
    North Texas
    Do you have any information about coolant temp differences between your setup and the factory setup? With your setup does the engine take longer to warm up? Thanks.
  10. Oct 20, 2022 at 1:43 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Interested also. Hoping it fits supercharged application.
    1GR-FE<3R[OP] and TodayWasTHeDaY like this.
  11. Oct 20, 2022 at 2:25 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    It’s a housing, it will have no effect on coolant temps. It’s the thermostat that controls the coolant temperature. The flow rate difference with oem is really the only factor to review. Maybe also the wall thickness. The price is not worth the tradeoff to me as there are no known issues with the oem housing. When I first replaced mine at 100K, it looked in good condition. I replaced with a Motorad model. At 200k I replaced that one with an Aisin model. Again, the Motorad looked in good condition.
    PzTank, ramonortiz55, wi_taco and 4 others like this.
  12. Oct 20, 2022 at 2:27 PM
    1GR-FE<3R
    Cody
    While running the Hi Flow 180° thermostat we have seen no issues! Vehicle warms up to temperature just as it should (we did time it!) The more free flowing design of our housing comes into play at once at operating temperature or under high load!
  13. Oct 20, 2022 at 2:28 PM
    1GR-FE<3R
    Cody
    You are correct with regard to the thermostat regulating the temperature!
    But I need to correct you with regard to flow. At operating temperature our housing will allow more coolant flow through the engine. Reducing engine hotspots. I don’t know how technically savvy you are on with tuning, timing, detonation, knocking, or pinging. I can assure you I am an ASE certified master technician with a pretty substantial experience completing general repair and maintenance of vehicles as well as serious performance modifications. Vehicles over 1000 hp. It makes a difference for longevity and performance.
    and what does wall thickness have to do with anything?? Here’s a fun one for you, I’ve seen a mechanical fan blade explode and shatter a plastic housing while out off roading. Obviously at the time our billet housing was not available, had our billet housing been installed, his cooling system would have been intact and he would’ve been able to limp out as opposed to being towed.
    The thermostat inside of our housing can be replaced for less then $10… How much did you spend on all of those plastic housings?
  14. Oct 20, 2022 at 3:03 PM
    Chuy
    Lakeside, CA
    Silver Taco
    I didn’t say anything negative about the flow rate - I said the flow rate between the two is what you’d want to review, and you addressed that in post #3, albeit without posting any data to review. Wall thickness is important as it pertains to housing strength. The pressurized test results should address any concerns about that. Unless you can duplicate a fan piece hitting your housing, you cant say it would not have broken in the example you provided. My money is on your housing, but, it’s no guarantee.
    I paid $27 for the Motorad thermostat, and $29 for the Aisin. I don't expect to replace it again, unless a fan piece hits it, but that’s why I kept the Motorad as a backup.
    Glueman, 1GR-FE<3R[OP] and Mully like this.
  15. Oct 20, 2022 at 6:19 PM
    1GR-FE<3R
    Cody
    Do you have a pic of your thermostat housing on your supercharged vehicle?
  16. Oct 20, 2022 at 6:40 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
  17. Oct 20, 2022 at 7:17 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    if this product works for this^^^ fella ill take one. his question is mine.
  18. Oct 20, 2022 at 7:24 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Make that another one
  19. Oct 20, 2022 at 7:28 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    go take a pic of yours man to confirm! ours look close:cheers:
  20. Oct 20, 2022 at 7:29 PM
    nudavinci64
    Robert
    I’m just using a stock Tacoma one at the moment. I have a 160 mishi I was going to use but this is much nicer
