Billet Aluminum Thermostat Housing for 4.0L 1GR-FE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1GR-FE<3R, Oct 20, 2022.
  1. Oct 20, 2022 at 7:51 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    possibly pass off more heat being aluminum opposed to the plastic oem. maybe imeasurable but im curious.
    1GR-FE<3R[QUOTED][OP] likes this.
  2. Oct 20, 2022 at 7:54 PM
    DJSpeed
    DJSpeed Well-Known Member
    i would buy one.. if you had a threaded hole on one said to install a aftermarket water temp sensor
    mav and 1GR-FE<3R[OP] like this.
  3. Oct 20, 2022 at 7:57 PM
    1GR-FE<3R
    1GR-FE<3R [OP] Well-Known Member
    Cody
    On the presale housings we will do a port at no additional charge!
    nudavinci64 likes this.
  4. Oct 20, 2022 at 8:01 PM
    1GR-FE<3R
    Cody
    This is a stock plastic housing with the alignment “tang” inside
    This is our billet aluminum housing, you can clearly see the difference.
  5. Oct 20, 2022 at 8:11 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    May have to get one and hope it works on the boosted ones
  6. Oct 20, 2022 at 8:30 PM
    1GR-FE<3R
    Cody
    Our billet housing should fit supercharged applications without issue! Magnuson is 30 minutes away from us!
  7. Oct 20, 2022 at 8:36 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i can see the difference for sure. was refering to the housing transfering heat better being aluminum.
  8. Oct 20, 2022 at 9:41 PM
    nudavinci64
    Robert
    I’m a good way or bad way?
    1GR-FE<3R[OP] likes this.
  9. Oct 20, 2022 at 10:20 PM
    1GR-FE<3R
    Cody
    It would be in a good way for heat transfer, the billet aluminum housing will disparate heat more efficiently then the plastic material.
    nudavinci64[QUOTED] likes this.
  10. Oct 21, 2022 at 7:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I'm in.
  11. Oct 21, 2022 at 8:51 AM
    nudavinci64
    Robert
    The therm are you are using is there a 170 option? We have a lot of chatter going on about preference to 170.
  12. Oct 21, 2022 at 8:56 AM
    v5ensx
    v5ensx CARB legal is not CALI legal
    You have any actual flow chart to show your designed flow better than factory?
  13. Oct 21, 2022 at 10:15 AM
    1GR-FE<3R
    Cody
    We are just waiting to complete the full flow test report! The free flow test is an easy one. The tricky thing is completing the pressurized flow test.
  14. Oct 21, 2022 at 10:19 AM
    1GR-FE<3R
    Cody
    There are 170° thermostats on the market. At this time we are not offering a 170° option. If you are not tuned I would recommend our high flow 180° thermostat. The use of our housing in conjunction with a high flow 180° thermostat provides better performance than a standard flow 170° thermostat.
  15. Oct 21, 2022 at 12:07 PM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    180° ordered and payment sent. :thumbsup:
  16. Oct 21, 2022 at 12:18 PM
    #36
    1GR-FE<3R
    Cody
    Got it!
  17. Oct 21, 2022 at 12:33 PM
    #37
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Agreed, stock tune will throw codes and not go into full closed loop fueling properly if temps dont reach 173-183 deg.
  18. Oct 21, 2022 at 12:42 PM
    #38
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Definitely interested in seeing that. I really like the idea of this and think the price is fair. I would probably already have ordered the 180 high flow if you where able to verify that it will work with a supercharger. I imagine most the supercharged guys will have some interest in this so hopefully someone gets one and can post if it works or not.
  19. Oct 21, 2022 at 1:35 PM
    #39
    nudavinci64
    Robert
    half the people commenting and buying right now are the Boosted guys. Seems like were giving it a go.
    SUMOTNK likes this.
  20. Oct 21, 2022 at 2:02 PM
    #40
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Mine was ordered earlier this morning.
    I have a bunch of upcoming work...Cam Sprockets, Thermostat housing, refinishing bicycle mounts in bed, making new nylon Amp Bed Extender straps, another application of CorrBan to the frame, rebuild the ICON rear shocks and no doubt more...already had the front of the bed motorcycle rack and Total Chaos bed stiffeners powdercoated, and replaced the pulleys and belt.
    Truck will be 13 years old the last day of the year, so it deserves it. Want it nice for whichever grandkid winds up with it.
    henryp, Torspd and 1GR-FE<3R[OP] like this.
